duncan webster | 01/01/2021 20:09:20 |
5307 forum posts 83 photos | I got the box for my Milling Machine Table Drive from Farnells at a very good price, I think they are end of line, see my post under workshop progress 2020 August sometime |
Robert Atkinson 2 | 01/01/2021 20:57:58 |
![]() 1891 forum posts 37 photos | Thread drift (again) but analog meters like the AVO 8 (I have the GPO version of the SEI Selectest Super 50 which is similar) do have a couple of advanages that have not been mentioned: They are good for assessing changing voltages because A. they average faster changes and B. your eye and brain can average slowly changing ones. DMM just give random numbers. They are good when making manual adjustments o circuits. The visual feedback is almost immediate. Some DMMs have bargraph displays that help in these situations but the implementaton and usefullness varies considerably, even from good manufacturers. Quite a lot of digital power meters and the Fluke 8920 TRMS digital voltmeter still have analog displays to assist with adjustments. Have more digital meter than analog but there is still a place for both in a well equipped workshop. If the only choice was the quality large scale analog like an AVO 8 / Super 50 or a cheap ebay/maplin/screwfix DMM I'd take the analog everytime. Note as well that the midscale accuracy of the AVO / Super 8 is similar to a basic 31/2 digit DMM. Robert G8RPI |
James Alford | 02/01/2021 09:17:50 |
501 forum posts 88 photos | Posted by pete hammond on 01/01/2021 13:52:54:
Hello James (Sorry to others for thread drift) Thought I was an isolated island of madness! (Near The New Zealand) Although partly written tongue in cheek I really am looking for a box about the size of an AVO or slightly larger - think desk top PC as maximum although experience of actual PC cases is -never quite suitable.. But for COVID and my shed is COLD I would welcome you for a coffee now - hopefully sooner rather than later! Pete
I have sent yo a private message. James.
James Alford | 02/01/2021 09:56:06 |
501 forum posts 88 photos | Posted by John Haine on 01/01/2021 11:21:15:
Posted by James Alford on 01/01/2021 10:05:35:
Just a quick update. Thank you for all of the advice and help. I have replaced the BC547 transistors with the 2N2222 type. It is all working as designed now. The next step is to put it all in a box, along with the Arduino Uno, the RTC, digital display and the relays and make sure that it runs properly for a prolonged period. Assuming that it works as hoped, the next stage is to build a mechanical clock for the relays to operate. Regards, James.
James, maybe a silly question, but presumably the relays will supply some sort of solenoids in the clock, in which case why not drive the solenoids directly from the transistors? What did you have in mind for the clock? To put it in perspective the clock I described here uses a converted quartz movement as a display driven directly from the Arduino pins via a 270 ohm resistor.
John. I am a way off from starting the clock itself as I am still vacillating over the design. However, I have programmed six pins on the Uno to operate at different intervals. One will operate each second, one each minute and one each hour. A fourth will be used to strike the quarter hours, a fifth to chime the hours and the last one will mark the days. I have used a RTC to ensure that it keeps proper time and it has a LCD display to check the time. Mechanically, there will be a lifting solenoid connected as the load on each transistor. This solenoid will pull a lever which will advance the hands, strike the hours, ring the chimes and mark the day appropriately. This stage is well in the future still. Regards, James. |
SillyOldDuffer | 02/01/2021 10:31:17 |
10668 forum posts 2415 photos | Posted by Robert Atkinson 2 on 01/01/2021 20:57:58: ... Note as well that the midscale accuracy of the AVO / Super 8 is similar to a basic 31/2 digit DMM. Robert G8RPI Out of curiosity I looked up what sort of digital multimeter you could get for the new cost of an Avo8. In 1953, the latter was advertised at £23.50, equivalent to about £660 today. (Source Richard's Radios)
Today, that money would get you a calibrated 5½ digit Siglent SD3055 Dual Display bench multimeter (DC voltage accuracy 0.015% of reading per year and 0.003% of range), plus many other goodies and change. Not tempted - my ordinary Maplin analogue and basic 3½ meters do all I need, and I occasionally roll out the Avo too. Dave |
John Haine | 02/01/2021 10:44:54 |
5563 forum posts 322 photos | Thanks James, so the relays are just representing the solenoids? I don't know if you're familiar with the old Synchronome clock which used an electromagnet driven ratchet motor to operate the dial impulsing every 30 s with a very audible clunk. In the case of the observatory version it clunks every second, and every 30s too. Also the master clock clunks every 30s as the impulse is delivered to the pendulum. In my version of the Synchronome the original EM drive to the dial was instantly vetoed by the domestic authority because of the noise, so I converted the dial mech to use a small stepper motor instead to drive the minute hand. The dial is now virtually silent in operation. This might be a point to consider - stepper motors can be cheaper than solenoids and at "clock" speeds virtually silent. |
James Alford | 03/01/2021 09:30:33 |
501 forum posts 88 photos | Posted by John Haine on 02/01/2021 10:44:54:
Thanks James, so the relays are just representing the solenoids? I don't know if you're familiar with the old Synchronome clock which used an electromagnet driven ratchet motor to operate the dial impulsing every 30 s with a very audible clunk. In the case of the observatory version it clunks every second, and every 30s too. Also the master clock clunks every 30s as the impulse is delivered to the pendulum. In my version of the Synchronome the original EM drive to the dial was instantly vetoed by the domestic authority because of the noise, so I converted the dial mech to use a small stepper motor instead to drive the minute hand. The dial is now virtually silent in operation. This might be a point to consider - stepper motors can be cheaper than solenoids and at "clock" speeds virtually silent. John, I confess that I have used relay and solenoid loosely. Originally, I was going to use realys, but then looked at the type of solenoid which has a sliding plunger to push or pull the mechanism. My wife's comments when I had it running with just one such solenoid made it clear that alternatives would be needed due to the noise. I have now settled on the type of solenoid which is just a round electro-magnet without any form of plunger or arm. I propose to design and build a mechanism which retains a tiny air gap between the face of the magnet and the activating arm to avoid noise. I toyed with the idea of stepper motors, but I really like to the idea of a clock with lots of levers and arms rocking away. It might all prove to be unworkable, but I shall give it a go. We used to have synchronised electro-mechanical clocks at the telephone exchanges where I worked. I cannot recall the make or any details, other than that they were not exactly silent. Regards, James. |
John Haine | 03/01/2021 10:14:06 |
5563 forum posts 322 photos | Aha! They would be PO Type 36 clocks! More details here. Very collectable these days. Based I believe on the Gents Pulsynetic system. I worked for the PO in the last days of Strowger and I guess the noise of the switching more than drowned out the noise of the clocks! Do you mean a rotary solenoid? I have thought of using those but not found a cheap source and they don't look easy to make. |
James Alford | 03/01/2021 10:30:17 |
501 forum posts 88 photos | John, Like you, I worked in the old Strowger exchanges in the later years, moving into "traffic" in 1986. They were noisy places. I am sure that my hearing was dulled by the constant racket. This is the type of solenoid Lifting Solenoids which I plan to use. I bought one from e-Bay as an experiment and have found someone in this country selling five more unwanted solenoids for a very reasonable price. Regards, James. |
John Haine | 03/01/2021 16:35:42 |
5563 forum posts 322 photos | I only had to visit them as I was in research but spent some weeks out in Gloucester area on training, of which the most interesting bit was going out in vans with the installers or in the exchanges trying to hear a TO explaining how a register-translator worked - fascinating! |
duncan webster | 03/01/2021 18:14:45 |
5307 forum posts 83 photos | PO type 36 was a Hipp clock, so nothing like as noisy as a Synchronome. Confusion arises because the GPO owned the design (I think) but had them made by several manufacturers, Gents included Type 46 was similar but had 1/2 second pendulum, much rarer |
James Alford | 03/01/2021 20:14:06 |
501 forum posts 88 photos | Posted by duncan webster on 03/01/2021 18:14:45:
PO type 36 was a Hipp clock, so nothing like as noisy as a Synchronome. Confusion arises because the GPO owned the design (I think) but had them made by several manufacturers, Gents included Type 46 was similar but had 1/2 second pendulum, much rarer That takes me back, somewhat. |
