david liggins | 01/06/2014 17:23:32 |
7 forum posts | i agree the cones on the bb shell would be better most of the time but this frame will run 14.5 inch chainstay, a 2in tyre and triple chaining. so i want to tack the pipes with chainrings in place. the 1st frame actually runs this on 14in stay but this is a bit short and the tyre rubs under power |
david liggins | 01/06/2014 17:55:32 |
7 forum posts | 24in wheels! the bolts are purely for location not support on the jig. anyone know if cromwell tools sell series taps? |
JasonB | 01/06/2014 18:02:02 |
![]() 25215 forum posts 3105 photos 1 articles | When I designed my frame I went with oval section fork blades for teh chain stays to get a bit more clearance, but things have moved on a bit since then, don't think Rockshoks had been invented back in '89. You would be better off making a bolt with a plain section that will be a good fit in a hole in the jig and then the M8x1 thread beyond that, something like this. By adjusting the fit of teh die you will get a good fit in the crank axle. J PS good to know you were not trying those stay lengths with a 29" wheel
Edited By JasonB on 01/06/2014 18:07:33 |
david liggins | 01/06/2014 21:16:49 |
7 forum posts | thanks, il look at m8x1 dies |
