Drummond B type refurbishment
The refurbishment of a Drummond Bros. B type lathe
Nobby11/02/2014 17:39:57
587 forum posts
113 photos
Hi Guys
Done some research MY Drummond lathe is an early before 1912  Pre-B-Type flat bed . the photo shows another x slide I fitted
I still have the original x slide and tool post
Nobby
Edited By Nobby on 11/02/2014 17:41:18
Carl Wilson 411/02/2014 18:43:48
670 forum posts
53 photos
Hello Nobby,
It is a lovely machine that you have, and the photos you show are inspiring me to make a good job of the restoration I'm doing. Have you seen the information pack that Tony Griffiths (lathes.co.uk) does on Drummonds? It includes a number of useful drawings.
I have just come in from cleaning all the parts in a bath of toluene and then applying nitromors to all the painted surfaces. Once the paint is off and then these parts are degreased in the toluene the whole lot will be ready to go in the Deox-C.
I've started examining the piece parts now that the dirt is off. So far I've discovered that my bull wheel has a crack right across the grub screw hole.
ian cable11/02/2014 20:15:32
40 forum posts
hi Nobby , I once had a similar problem all I did was ,clean the collar with a bit of wet and dry then turn up a press fit 1/4 thick steel collar to go over top and drill a new grub screw hole opposite the old one
Carl Wilson 411/02/2014 21:12:05
670 forum posts
53 photos
Hello Ian, it isn't Nobby who has the cracked bull wheel, but me, Carl. Thanks for your post, that is a good idea for a repair scheme.
