Lathe halh nuts
Articles
Joe M13/11/2012 21:36:34
19 forum posts
Hello. I have been able to acquire a pair of Half Nuts for my Hobby lathe. Thanks to everyone who offered advice and help. The ones I bought are aluminium and I look forward to trying to fit them over this coming weekend and if not, over the Christmas holidays.
If anyone has ever repaired / fixed half nuts on a similar lathe, I would apperciate any advice on how to re-assemble.
Many thanks
Joe M
Andyf14/11/2012 00:50:02
392 forum posts
Hi Joe,
As they say in the car manuals, re-assembly is the reverse of disassembly crook.
I don't know your lathe at all, but on mine the procedure is to put things back together and then move the leadscrew up, down or sideways until the half nuts will close easily on it at the headstock and tailstock ends.
Up and down is dealt with by loosening the leadscrew bearing block fixing bolts at one end, clamping the half nuts up at that end, then tightening the bolts up. If the leadscrew doesn't rotate freely, the holes in the bearing blocks may need enlarging to allow a bit of wriggle room. Then repeat at the other end of the leadscrew.
Sideways adjustment can be accomplished, if there is sufficient wriggle room on the bolts which hold the apron to the saddle, by loosening them, closing the half nuts, and then tightening the bolts up again. If that doesn't work, shims behind the bearing blocks, or skimming a bit off their backs, may be necessary.
You can often diagnose what treatment is needed by closing the half nuts half way along the leadscrew, while observing closely to see if it flexes at all. If so, the leadscrew will be put under severe strain when the carriage gets near one or other (or both) of the bearing blocks.
Andy
mgnbuk14/11/2012 08:28:31
1394 forum posts
103 photos
Out of interest & for the benefit of others who will eventually be in the same position, where did you manage to source the replacement parts, Joe ?
Nigel B.
(I would have italicised the quote, but the "editor" won't let me ?)
Joe M16/11/2012 21:53:23
19 forum posts
Hello.
Thanks to everybody who offered advice to help repair my hobby lathe I'm hoping to make a start this weekend Sun 18th and if not, over the coming weekends. I was eventually able to acquire the half nuts from Excel Machine Tools, Coventry. After a lot of searching around they eventually found some in a factory unit they own across the road. I'm just glad to have them...
Once again .
Thanks to everyone.
Joe.
PS I could be looking for a very cheap small used single phase surface grinder in the near future.
Terryd16/11/2012 21:59:15
1946 forum posts
179 photos
Posted by Nigel Barraclough on 14/11/2012 08:28:31:
Nigel B.
"Hello. I have been able to acquire a pair of Half Nuts for my Hobby lathe."
I managed the quotation marks and italicisation despite the so called shortcomings of the software smile p
Best regards
Terry
mgnbuk17/11/2012 10:07:16
1394 forum posts
103 photos
I don't normally have a problem & it worked fine on the post I made before the one in question - it also worked on this reply. It steadfastly refused to work on the post in question, though, hence the comment.
Nigel B.
Joe M25/11/2012 19:43:49
19 forum posts
Hello. Does anyone have a cheap small surface grinder for sale. Around 12" X 5" Single phase. It may need a little help. cheap please...
Joe M
Joe M24/12/2012 08:53:55
19 forum posts
Good Morning.
Thanks to everyone who had an imput in trying to help me repair my Hobby lathe this year.
I've made a bit of a start on putting the new half nuts back, but things have slowed a bit due to family circumstances and I hope to continue this Christmas holiday. So thanks to everyone who offered help.
To everyone on the Model Engineering website.
Wishing all thats good for Christmas, New Year, 2013 and beyond.
Regards.
Joe M
