Basics
John Kinman | 29/03/2012 16:51:06 |
16 forum posts |
Posted by Im Indoors. on 28/03/2012 10:58:12:
Hi John To respond to your question about purchasing a stationary engine. I started down the road of model engineering a couple of years ago by buying and assembling a Mamod traction engine, which I have steamed. The engine part is an oscillating cylinder and assembly of the whole thing took me about half an hour, 10 minutes of which was spent searching for a miniature Allen key. I followed this with a Wilesco traction engine which is a world away from the Mamod having a double acting valve controlled motor and a more complex chassis. I spread assembly over a couple of hours and I have not steamed it because I didn't want to spoil the polished brass finish on the boiler but I have run it on air. Both these projects are little more than tinplate toys. For an insight into how a steam engine functions and to allow some experimentation with valve timings I would suggest something like my third project, a Stuart Models ready to assemble kit, (I built a 10H), or something similar from Cotswold Heritage or the like. Having built one of those I was encouraged to get my workshop up and running, make an oscillator from stock material and I'm now machining a Stuart 10V from the castings kit. I haven't yet got a boiler, a project for later, so I run my engines on air. This gives me the satisfaction of seeing them working but I understand that there's nothing as good as water and heat to bring an engine to life so ultimately that's what I will use. Jim Thanks I have purchased a Wilesco D16 on ebay and awaiting deleivery.....I would like to switch between running on steam and compressed air.......is there an easy option or does it involve pipework being altered ?.......Thanks
John Kinman | 29/03/2012 17:18:31 |
16 forum posts | I see on the internet one person is running a D18 on compressed air by modyifing the water filler intake on the boiler with a screw fit connection for compressed air hose .Is there an off the shelf connector available please .Or can someone make one for me for price please ? |
Terryd | 30/03/2012 07:25:18 |
![]() 1946 forum posts 179 photos | Hi Jim, It sounds as if the person you are referring to is using compressed air to pressurise the boiler. I personally would no way contemplate that. It would be very easy to over pressurise the boiler with catastrophic failure using a compressor. When generating steam in the boiler the pressure is raised steadily and the safety valve operates if the pressure exceeds it's working level. By connecting a source of compressed air, especially from a pre pressurised receiver it is al too easy to fill at a higher pressure than the safety level of the boiler due to the speed of the transfer the safety valve, designed for steam, would not be able to spill air quickly enough. Do You know the safe working pressure of the boiler? To run engines on compressed air you should connect directly to the engine. I may be wrong but I wouldn't risk it. Why not steam it? Terry |
