Lathe Drive Systems and Belts
Howard Lewis11/08/2023 16:00:05
7227 forum posts
21 photos
Roy, it always possiblke that my wi fi keyboard missed the 1 and /, so don't feel too sorry.
One of the few devices where i can beat a computerr for speed!
James Alford11/08/2023 18:50:26
501 forum posts
88 photos
20230811_183628.jpg20230811_183637.jpgIf it helps, this is the drive on my Flexispeed. Ignore the dust: I have been refitting the bathroom for ages and have not touched the lathe for months.
Edited By James Alford on 11/08/2023 18:51:25
Edited By SillyOldDuffer on 15/08/2023 21:01:25
Andy_H15/08/2023 20:32:35
56 forum posts
4 photos
Posted by Dave Wootton on 11/08/2023 13:20:56:
Update to above post. the motor is indeed 1/6 hp and is from a bacon slicer! the belts are round silicon he thinks 8mm dia and are orange. previously he used green ribbed belt that worked ok but was prone to part at the joints, possibly he admits through faulty heat jointing. The small motor is he says is probably slightly underpowered but pefectly adequate for what he does, his model of simat has back gear which he uses for cast iron wheels. He has just bought a Flexispeed Venus milling machine, which is a new one on me, after looking at the lathes website it looks ideal for the smaller gauges, crying out for a little vertical head attachment!
Thanks for checking these details, really useful
Andy
Andy_H15/08/2023 20:50:43
56 forum posts
4 photos
Posted by James Alford on 11/08/2023 18:50:26:
Thanks for this James.
I like the idea of that jockey wheel as that's obviously the tension adjuster and there's then no need to rig up a method of adjusting the countershaft position. The same principle can be used on the motor to countershaft belt.
Am I right in thinking you have assembled that jockey wheel from roller bearings mounted on a bolt or threaded stud?
The restoration is coming along reasonably well. I think I will be seeking some advice on a few final points but will raise them separately to avoid taking this post way off topic!
Andy
James Alford16/08/2023 08:01:21
501 forum posts
88 photos
Andy_H.
Yrs. The jockey wheel is about four cheap roller bearings on a long bolt, bolted onto a length of flat steel bar. The other end is screw to the block of wood that supports the counter shaft. It is all looks very crude, but it is effective. The belt firm the motor to the counter shaft is simply taut and has no tensioner. It never slips.
James.
Andy_H07/09/2023 08:07:57
56 forum posts
4 photos
Posted by Adrian R2 on 10/08/2023 16:23:47:
I tried out a recycled cordless drill motor which worked OK but I didn't like the aesthetics of it.
Out of interest what did you use as a power source in that setup?
Andy
