Build thread of an Alyn Foundry RLE Hit & Miss Engine
JasonB | 18/08/2023 19:20:11 |
![]() 25215 forum posts 3105 photos 1 articles | The spigot on the bottom of the carb takes a non return valve that sits just off the bottom of the fuel tank. This is a fairly simple turning/milling job from a piece of brass stock I started by turning down one end of some bar to 8mm dia and threading M8 x 1 then drilled a cavity for the ball that acts as the valve. Next I milled a 10mm AF hex. |
