Clarke CL300M motor axis diameter
new timing pulley for CL300M needed - what is the right diameter?
not done it yet02/05/2023 12:39:38
7517 forum posts
20 photos
I might suspect the belt is a slight mis-match for these replacement pulleys? 20mm diameter does seem to be somewhat beyond the lathe specification?
Howard Lewis02/05/2023 14:41:34
7227 forum posts
21 photos
Have to say that asking a low power motor, about 400 watts, is asking a lot.
The older original mains powered pistol drills used 350 watt motors and the limit was about a 3/8 or at most a 1/2" (say 13 mm) twist drill.
So 20 mm will call for a lot more torque, and feeding too rapidly will make matters worse.
This is a low power hobby machine, not a 20 hp industrial lathe.
How would you feel about driving a 20 mm drill in a breast drill?, Not a liught job!
Have you read the manual which should tell you the recommended maximum capacity?
