MJEng Fowler A7 - what CAN'T I do on an ML7?
William Ayerst24/11/2022 08:08:47
264 forum posts
Having spoken to Alan at MJ Eng, and Tim Watson, and a few chaps on the TT forum - it seems that maybe I should really consider a 3" engine - in that the items which are too big for the ML7 and Centec for a 3"-scale are the same items which are too big in 2" scale, so not net difference in that aspect? Or am I oversimplifying things?
JasonB24/11/2022 10:10:08
25215 forum posts
3105 photos
1 articles
You may find a few more of the 3" parts that could be tight on the Myford such as brake drum, winding drum, 3rd shaft gear and the cylinder will also be quite a lump so allow for more parts needing larger machines plus the long term how will you transport the engine and some form of driving cart.
If Fred on TT chips in he made a very nice 3" on a myford and warco mill and borrowed a friends machines for the larger items
Edited By JasonB on 24/11/2022 10:11:24
SillyOldDuffer24/11/2022 10:23:07
10668 forum posts
2415 photos
Posted by William Ayerst on 24/11/2022 08:08:47:
...it seems that maybe I should really consider a 3" engine - in that the items which are too big for the ML7 and Centec for a 3"-scale are the same items which are too big in 2" scale, so not net difference in that aspect? Or am I oversimplifying things?
Just an observation as I've never built a traction engine but, it's straightforward to make components that fit on the lathe and mill, and straightforward when a component far too big - then you have to have it machined by someone else, £commercially, or by making friends at a club. It's the middle ground that gets exciting because an experienced and imaginative machinist can often get tight-squeeze jobs done with ingenious set-ups. This opens the door to different answers.
  • Person A with basic skills looks at the plans, and realises that some parts are too big, therefore the job can't be done.
  • Person B with advanced skills and is familiar with that type of build, identifies the difficult parts, and has a clever experienced think about ways and means. This chap might well be able to do a job too difficult for Person A!
In the past people achieved remarkable things with Myford lathes because they had to. But it took time and and thought. I'd describe myself as being Person A who is slowly and painfully learning to become Person B. On the plus side, I have semi-relevant work experience, an interest in the history of engineering, an extensive library and much help from the forum. Not so good, I'm self-taught. In consequence, my machining skills are full of odd gaps and I make a lot of avoidable mistakes! Theory is very helpful, but it doesn't provide hands-on skills. To get them, it's necessary to cut metal, thus discovering and extending the limits of the machine and the operator. Practice!
The best way to become Person B is moot. I prefer to start small and methodically extend my skills by tackling more complex work in a series of small steps, a sort of self-imposed apprenticeship. Others are motivated by challenges, bigger the better, and learn best by jumping straight in at the deep end. Trouble with the latter approach, is it has a high failure rate: the second-hand market is littered with part-built locomotives, and it was once joked that most workshops had a half finished Quorn under the bench. The problem is these things take thousands of man hours, and take even longer if a learner has to feel his demoralised way at every step.
If it were me, I'd take the uncertainty about 2" versus 3" traction builds as a warning that I might be out of my depth. I wouldn't mind 'wasting' a year building something smaller just to gain experience. Against that, note Dave Shield's answer, and his comment 'Go for it, the problems have a way of sorting themselves out as the build progresses'. He's right, but I suspect Dave is more experienced than me. Noting that most jobs are much easier when you know what you're doing, I'm less confident because I know I have gaps!
Bazyle24/11/2022 11:28:13
6956 forum posts
229 photos
Don't forget the finished model is going to get heavier by the cube of the dimension and assemblies you can lift on a small one cause a slipped disc on the bigger one, Also bits dropped on your foot do more damage.
Meanwhile Fred's model above looks superb. Another item on my wish list.
Martin Johnson 124/11/2022 12:55:41
320 forum posts
1 photos
The 3" Fowler makes a very nice model and is OK for rally use (a friend has one). Not the simplest engine to build, but very faithful to prototype. I have just responded to your post on TT as well.
Martin
JasonB24/11/2022 13:11:35
25215 forum posts
3105 photos
1 articles
I've e-mailed Fred to check what parts he could not fit on his Myford and also asked him to post a picture of the scratter mill that he built as you asked about something for the engine to drive, he will hopefully reply on TT
Worth saying that Fred had only built a Stuart oscillating engine before the Fowler which he has done a great job on, there is also a riding cart, water bowser and waggon all of which it will tow along with him.
Weary30/11/2022 10:27:39
421 forum posts
1 photos
Note that MJ Engineering cannot currently supply rolled steel wheels.
I have just spoken with Mr Barsby who has given me this information.  He is currently looking for someone who can roll the rims, so if anyone knows of a company who can do-so then perhaps let him know - or even post here so that we can all take advantage!
Phil Roe
Edited By Weary on 30/11/2022 10:43:05
Edited By Weary on 30/11/2022 10:44:46
JasonB30/11/2022 12:58:30
25215 forum posts
3105 photos
1 articles
I know the company that he used had a few changes but people have been able to get them to roll wheels and other items. I think the owner retired and his sons now run the business.
