Graham Meek | 16/10/2022 11:56:59 |
714 forum posts 414 photos | I am with Baz, the sound is the same as the machine I had some years ago. The problem can be worse when the Gibs are too tight, especially when lowering the knee. Regards Gray, |
John P | 16/10/2022 12:06:09 |
451 forum posts 268 photos | Posted by John D 15/10/2022 21:51:34 Does anyone know if it might be possible to obtain the elevation gears for the Myford Wondering if they are all like this? Photo of gears cleaned up and with the retaining washer and nut removed. -------------------------------------------------------------------------------------------------- Those gears look about normal and are much the same on my Warco Even if you find a supply of new gears they may fit exactly the same if When i got my A2f from Warco these 2 gears were very rough in operation, You could turn off about 1/8" off the top of lead screw gear and refit it with
Edited By John P on 16/10/2022 12:07:02 |
John D | 16/10/2022 13:46:09 |
37 forum posts 9 photos | Thank you so much for the replies. Knowing it is likely normal experience means that I can leave it for now and focus on completing the DRO install. John, I would prefer to avoid cutting the paint on the gear shaft sleeve. The backlash must be a feature of the fore/aft position of the horizontal gear in relation to the lead screw gear. I’m therefore hoping that it would be possible to adjust this without removing the sleeve / housing. It was all much more accessible when I had the knee off. Perhaps the same take up in free play could be achieved by doing what you suggest regarding skimming and fitting a washer but in the process making the washer a shave more than the amount taken off. Or reversing the gear and doing the same. Edited By John D on 16/10/2022 13:48:09 |
