Drawing a saw blade - help!
SillyOldDuffer30/08/2022 11:18:01
10668 forum posts
2415 photos
Many thanks to Gary for his comprehensive description of how to kerf teeth on a hole saw with Fusion360. My next job is to replicate it in SolidEdge. (Almost certain the method will work, but I'm finding SE harder to drive than Fusion.)
Made progress on the third problem which is getting a pattern repeated cut to follow a wavy line projected on to a cylinder. This example punches a series of holes up, down and around a cylinder, and in principle it should work with teeth profiles:
Huub's suggestion of FreeCAD's Curves Workbench is on my To Do list, and I agree with him that planning with a spreadsheet is a good idea. The teeth don't line up in my attempts because I winged the dimensions rather than doing the sums.
I've already had a go at Howard's suggestion but - so far - not found a way in SolidEdge of bending a straight strip with teeth into a circle. I'm going to try again this morning. Feels like something the tool should be able to do.
Thanks to all
SillyOldDuffer30/08/2022 15:51:57
10668 forum posts
2415 photos
Re Howard's suggestion - drawing the teeth on a straight strip and then rolling it into a circle. Turns out to be possible with SolidEdge Sheet-metal but not as I expected!
The trick is to:
  1. Draw a circle with a break in it.
  2. Extrude the circle with 'Flange Extend' to create a cylinder (with break)
  3. Unbend the cylinder (a button) , producing the flat strip needed to make it
  4. Add teeth to the flat strip
  5. Rebend to put the flat strip back into circular form. (another button)
Image shows the Rebend action just before confirmation:
unbend.jpg Dunno what's going on today, people keep me ringing up and banging on the door. Feels like family, friends and Postie have organised themselves to cause maximum disruption.
JasonB30/08/2022 16:27:52
25215 forum posts
3105 photos
1 articles
That was my first suggestion too, to draw it flat and roll it up like they are made.
Can rolling it up include the set of the teeth?
SillyOldDuffer30/08/2022 17:27:50
10668 forum posts
2415 photos
Posted by JasonB on 30/08/2022 16:27:52:
Seems not! So close and yet so far...
Back to the drawing board!
Model Enginerd03/12/2022 00:02:32
22 forum posts
1 photos
This was an interesting study. I tried an approach using expressions so the user could pick the TPI and diameter and the geometry would auto gen. I had 16 TPI in this one, which is pretty tight. Another design consideration was the outside diameter measured from the outboard cutting edges didn't necessarily match the pitch, so the pitch was adjusted slightly to meet the O.D.
Another thing is that I don't know how Alibre handles arc lengths. It doesn't do radians. I did manage to create geometry but was unsuccessful in automating all of the inputs.
In retrospect, as someone else mentioned, it would be better to force the TPI and the diameter together, so when the steel is rolled and welded, the teeth will be offset at the weld.
SillyOldDuffer03/12/2022 09:34:15
10668 forum posts
2415 photos
Posted by Model Enginerd on 03/12/2022 00:02:32:
Nice! My mind is mathematically weak and I hadn't thought of expressions.
Now the idea has been demonstrated, this might be the best way to do it. Kerfed teeth on a curve are a general problem like gears. They're drawn with a macro or built-in program doing the maths, rather than the operator tracing curves manually.
David Jupp03/12/2022 11:24:43
978 forum posts
26 photos
Alibre does do radians - but it will display in your chosen preferred angular unit.
Alibre works internally with radians, like many computer systems do - so an arc length is simply given by
arc length = radius * angle
Alibre's equation editor is VERY FUSSY about variable typing, which can lead to some unexpected problems if you are not aware of them.
This page may be helpful - it's on an old system, so could vanish (I can provide it as a PDF if needed).
Model Enginerd04/12/2022 21:21:03
22 forum posts
1 photos
Awesome. Thanks for the tips. I'm still pretty new with Alibre.
