peak4 | 11/02/2022 20:08:21 |
![]() 2207 forum posts 210 photos | There's other reasons for running the Myford backwards as well as screwcutting. |
Mitch Lees | 11/02/2022 20:56:05 |
17 forum posts 3 photos | Peak4, thanks for that insight. My Pratt Burnard Chuck has a bore the same as the spindle and so I cannot fit a washer for a draw bar. Consequently, when I was going to cut threads in reverse, I had decided to buy a new, larger chuck with a correspondingly larger bore so allowing the draw bar washer to bear on the backplate. This seemed like an expensive solution! Also, the 125mm chucks ( which is the min size I would have needed to allow the washer) looked very big on the Myford, and I was concerned that the Chuck my have been too heavy (c 5kg) and damaged the spindle bearings?? I am now in the process of making a spindle handle, but I want to incorporate a through bore so that if I do decide to change chucks and have a draw bar, I can use it with the handle. thanks for the help mitch |
Neil Lickfold | 11/02/2022 21:19:37 |
1025 forum posts 204 photos | Posted by Mitch Lees on 07/02/2022 18:47:29:
I want to have a go at screw cutting on my Super 7 and it seems that by running the lathe in reverse I can cut away from the chuck - hopefully less stressful! However, I have read that the chuck can unscrew with disasterous consequences! Is some kind of draw bar arrangement the only answer, or is there another solution. Stupid question: is there some way to fit a camlock type chuck - would this help. Any ideas most welcome. Beginner so please bear with me. Mitch You still need the tool to be close to the chuck, either internal or external threading. While reverse cutting seems easier because the power feed is away from the chuck, the initial part of getting the tool to the shoulder and then reversing is still there. One advantage of threading in normal rotation towards the chuck, is when you have an older lather or one that has slop in the whole assembly. Starting early takes away that slop and you have a great thread right up until the end. Either option will require a thread relief area. Sometimes it is easier to just turn the machine over manually, with either a hand crank or just turning the chuck with your hands. There is no wrong way to do something. Just that some ways pose more risk or danger than other ways. With internal threading and boring, I often either use a marker pen or paper tape, to visually show the max depth of the part to the cut as a guide. In regards to reducing the chuck from coming loose on the Myford S7 , I have often thought of making a ring collar, with a set screw, and then drilling a matching hole through the back of the chuck body, and use a brass or copper plug to make it lock onto the spindle, like some of the Hardinge chucks have with their screw on fixtures etc. The 4jaw for a Myford S7 would need to be drilled right through for this to be effective, something I am reluctant to do myself. If I find that I need a largish work piece that needs to be cut in reverse and would be putting enough load onto the chuck that a risk of it coming loose could happen, then I would drill a hole through it to make a locking pad. The only reason for making an outer ring to carry the set screw, is to not be distorting the chuck body in some some way with the small diameter flange that is on the chuck backplate. Most of all, enjoy the model engineering and have fun doing it. It is a great hobby, and many people who are not professional machinist often have great ideas and ways of doing things . |
Mitch Lees | 11/02/2022 21:45:23 |
17 forum posts 3 photos | Neil, thanks. It’s great that so many of you have responded so quickly, and with really positive and helpful advice, I cannot quite visualise what the collar you suggest would bear on, I will try and find a picture of a Hardinge lathe chuck arrangement. mitch
peak4 | 11/02/2022 21:45:41 |
![]() 2207 forum posts 210 photos | Posted by Mitch Lees on 11/02/2022 20:56:05:
Peak4, thanks for that insight. My Pratt Burnard Chuck has a bore the same as the spindle and so I cannot fit a washer for a draw bar. ................. I am now in the process of making a spindle handle, but I want to incorporate a through bore so that if I do decide to change chucks and have a draw bar, I can use it with the handle. thanks for the help mitch Mitch, re the handle/drawbar thing, I'm not sure you would really need to use both at the same time, as, by design, everything will be happening slowly. |
Mitch Lees | 12/02/2022 09:29:37 |
17 forum posts 3 photos | Bill, you are right, and it will be easier to make the handle without bothering with the through bore. My 4 jaw is the threaded version without back plate, but the 3 jaw does have a back plate. I had not considered boring a recess in the back plate because I did not think I could get the washer in without separating the assembly each time. Although I will probably not bother with the draw bar for now, I may machine the recess anyway and experiment with filing flats on the washer and inserting it as you say. I suppose there are always solutions! A lot cheaper than buying a new Chuck. Than you, Mitch. |
Hopper | 12/02/2022 11:24:18 |
![]() 7881 forum posts 397 photos | Posted by peak4 on 11/02/2022 20:08:21:
Could you not have cut on the back of the job, but turned the toolbit upside down and run the lathe in the forward direction? IE like a rear parting tool. |
SillyOldDuffer | 12/02/2022 11:51:14 |
10668 forum posts 2415 photos | Posted by Mitch Lees on 07/02/2022 18:47:29:
I want to have a go at screw cutting on my Super 7 and it seems that by running the lathe in reverse I can cut away from the chuck - hopefully less stressful! However, I have read that the chuck can unscrew with disasterous consequences! ... Power threading away from the chuck is wonderful because you can cut at top-speed without any risk of smashing into the headstock or the spinning chuck. Unfortunately the technique is risky on lathes fitted with a simple screw-on chuck because the forces tend to undo it, which spoils the thread, and might even cause the chuck to fall off. All machine tools have limitations, and screw-on chucks are one of Myford's! Although they work well in most circumstances:
I'd only consider modifying a Myford for guaranteed safe reverse threading if a lot of threading had to be done in a hurry. For occasional work, it's easier to slow down and thread carefully. In the forward direction avoid crashing the carriage, in reverse don't cut so hard that the chuck unscrews. Modifying the chuck and spindle mechanically is one option, an Electronic Leadscrew is another. Or admit the Myford is a poor choice for this particular application and replace it with a lathe fitted with a bolt-on or cam-lock chuck. Dave |
peak4 | 12/02/2022 13:02:28 |
![]() 2207 forum posts 210 photos | Posted by Hopper on 12/02/2022 11:24:18:
Could you not have cut on the back of the job, but turned the toolbit upside down and run the lathe in the forward direction? IE like a rear parting tool. Certainly yes, and from what I can recall, I did look at that, but because of tool and toolholder sizes, I would have had to raise the QD holder too far up the Dickson style toolpost, such that I couldn't clamp it properly. |
