Universal thread cutting
Joseph Noci 105/07/2021 17:18:28
1323 forum posts
1431 photos
Posted by JasonB on 05/07/2021 12:26:31:
Can I ask what the ELS users do about returning the carriage for th enext cut when doing say a metric thread on an imperial leadscrew equiped machine? Do you still have to leave the half nuts engaged and then use the driven screw for a fast rewind after retracting the tool.
As Tony said, yes. Although the point of metric with imp. leadscrew etc becomes moot with the ELS - you simply don't bother with needing to know any of that - keep the halfnuts engaged - the ELS takes care of the rest. Thread start point and end point are user settable then remain fixed till you are done - you just take care of retracting the threading tool and putting on cut for the next pass - don't have to clinch as you approach the dead shoulder, etc, metric, imperial threads or a 1.95mm pitch thread if you wish..
And if you use a lever retractable cutting tool, it's even simpler.threading holder and blank shaft.jpg
DC31k05/07/2021 19:09:50
1186 forum posts
11 photos
Posted by Andrew Johnston on 05/07/2021 09:53:08:
The value of 127 is indeed tied to the definition of metric and imperial conversion, but the fact that it is prime is no coincidence. It's the result of decomposing the conversion value into its prime factors.
I am not convinced of your reasoning.
Five inches is exactly 127mm. There is no need for factors there. The definition is what it is and just happens to land on a number which is prime.
In an alternative universe, we might have a definition of the inch where 5 inches equals 126mm. There, 126t change gears might be rather more common. There, the definition just happens to land on a number which is even, and thus not prime.
JasonB05/07/2021 19:13:50
25215 forum posts
3105 photos
1 articles
You could also say 10" = 254mm but a 254 tooth gear is going to be a pig to fit to most lathes so make it smaller in which case 127 fits the bill.
5" equalling 128 is a nicer one to work with or the 25.6mm inch
Edited By JasonB on 05/07/2021 19:16:32
Bazyle05/07/2021 20:20:33
6956 forum posts
229 photos
Posted by JasonB on 05/07/2021 19:13:50:
We can't have that - it would make Britain smaller. With Brexit we should go for 5" = 100. laugh
Andrew Johnston05/07/2021 20:45:23
7061 forum posts
719 photos
Posted by DC31k on 05/07/2021 19:09:50:
You wouldn't need 126, you could use 63, 21, 7 or even 3!
It's a fundamental theorum of mathematics that any positive integer can be factored into primes, and only primes. So whatever the conversion factor there will be a need for a gear with a prime in it somewhere. It may have to be a multiple of a prime as small numbers of teeth wouldn't be practical.
John Haine05/07/2021 22:12:57
5563 forum posts
322 photos
From Wikipedia:
"As a result of the definitions above, the U.S. inch was effectively defined as 25.4000508 mm (with a reference temperature of 68 degrees Fahrenheit) and the UK inch at 25.399977 mm (with a reference temperature of 62 degrees Fahrenheit). When Carl Edvard Johansson started manufacturing gauge blocks in inch sizes in 1912, Johansson's compromise was to manufacture gauge blocks with a nominal size of 25.4mm, with a reference temperature of 20 degrees Celsius, accurate to within a few parts per million of both official definitions. Because Johansson's blocks were so popular, his blocks became the de facto standard for manufacturers internationally,[27][28] with other manufacturers of gauge blocks following Johansson's definition by producing blocks designed to be equivalent to his.[29]
In 1930, the British Standards Institution adopted an inch of exactly 25.4 mm. The American Standards Association followed suit in 1933. By 1935, industry in 16 countries had adopted the "industrial inch" as it came to be known,[30][31] effectively endorsing Johansson's pragmatic choice of conversion ratio.[27]
In 1946, the Commonwealth Science Congress recommended a yard of exactly 0.9144 metres for adoption throughout the British Commonwealth. This was adopted by Canada in 1951;[32][33] the United States on 1 July 1959;[34][35][36] Australia in 1961,[37] effective 1 January 1964;[38] and the United Kingdom in 1963,[39] effective on 1 January 1964.[40] The new standards gave an inch of exactly 25.4 mm, 1.7 millionths of an inch longer than the old imperial inch and 2 millionths of an inch shorter than the old US inch.[41][42]"
Nigel Graham 206/07/2021 00:05:30
3293 forum posts
112 photos
Millionths..... I'm lucky to find a thousandth!
For practical purposes I cut threads to near-depth then finish with a die, to form the profile as much as anything.
brian jones 1106/07/2021 03:57:35
347 forum posts
62 photos
growing up in the days when we still had an empire, I know what a thou looks like and know what tenths are and how the undamaged finger can feel a ridge of a few tenths
I struggle to force myself to think in microns = eg 100mu ca 1/2 thou, 10mu ca 5 tenths
CNC goes to 1mu and as for finishing well ...............
repeatability on a Myford 1 thou if you are skilled with a light touch.
As for mils thats for the cousins
modern machining techniques leave me totally in awe
John Haine06/07/2021 09:52:01
5563 forum posts
322 photos
I wonder if it crossed Johansen's mind that defining the inch as 25.4mm would result in a fairly low integer ratio for change gears?
Martin Connelly06/07/2021 11:30:30
2549 forum posts
235 photos
Johansson's choice was similar to what Whitworth did for his thread standard. Collated information about what the various threads being made in the area were like with regard to angle and TPI and based his new standard on what seemed closest to the average. It is probably impossible to know what drove their choices one way or the other when they made them but they were both businessmen so were probably thinking about the bottom line not the future ramifications of their choices. I know that when I have been creating a drawing of something at work I often tweaked designs to get nice round figures on the dimensions, not because it was necessary or better for the part, more for the fact it just made it look like I had put a lot of thought into the part (CAD has made this easy). I often had discussions with the design departments about why they had done something one way or another and often they did things vertical, horizontal or at 45° just because everyone else did and so it all looked well thought out. It was rarely about the engineering needs or the built in cost of their design.
Martin C
duncan webster06/07/2021 12:38:10
5307 forum posts
83 photos
From my days working on a real live drawing board, angles were as far as possible multiples of 15 because there was a quick release button that locked the rules in 15 degree increments.
And yes on occasions I did have to draw in Indian ink on linen to modify old drawings, but not with a quill pen. Spring bows were a nightmare, Rotring pens much more forgiving
