Noise from Crompton Parkinson 3 phase 1/2 HP motor
Andrew Tinsley07/04/2021 16:43:08
1817 forum posts
2 photos
Hello Howard,
I must admit that things like the noise in reverse that get my attention. If I can't see any good reason for it then I do get somewhat wound up. The bearing that I removed was in good condition, once I was able to get a good look at it. I measured 3 thou as the clearance between the shaft and the old bearing. The new bearing and reduced diameter shaft had the same clearance! I can't see why the deep score on the shaft could cause the noise in reverse.
Still a result is a result.
Thanks ,
