Thread identification
Honda CX500
Nick Clarke 301/07/2020 08:42:51
1607 forum posts
69 photos
Posted by Lee Rogers on 01/07/2020 06:00:47:
Another pitfall for the unaware was the ''Phillips '' screw heads on Japanese bikes. They weren't Phillips they were JIS, Japanese Industry Standard form. They were usually torqued up to the max from the factory and a Phillips would just mangle them even with an impact driver. Hence the aftermarket allen screw kits that were so popular at the time.
Edited By JasonB on 01/07/2020 06:57:11
Often found on laptops, other computer equipment and cameras as well, but in such small sizes, and in the case of cameras often sealed with threadlock or paint, they are even easier to mangle.
Howard Lewis01/07/2020 10:34:55
7227 forum posts
21 photos
For a long time, French cars, certainly Renaults, used a TACL screw head, a sort of enclosed diametral slot, with a small central female spigot. At least a narrowed thick conventional screwdriver would deal with those.
Then the continental motor industry started using Torx heads on cylinder head bolts..
To retain aftermarket exclusivity some manufacturers used really odd fixings. The governor shaft on the Bosch EPVE was retained by three sided fixings (Guess what was the only place you could buy a socket to fit? )
I came out of a meeting with a potential fastener supplier, having just said "Nothing special, we don't want five sided heads" to find a Japanese cartridge type injection pump with five sided heads!
Presumably all in the name of tamperproofing; or exclusivity?
Nick Clarke 301/07/2020 11:23:24
1607 forum posts
69 photos
It may well be apocryphal but I have heard it suggested that the reason the GPO used (in pre British Telecom days) 3/5/7/9 ba fixings rather that the more common even numbered ones was so that people didn't pinch the bolts etc
An urban myth? Probably!
Mark Rea07/10/2020 10:30:24
32 forum posts
7 photos
The threads on japanese motorcycles are metric.
M4 x 0.7
M5 x 0.8
M6 x 1
M8 x 1.25
Anything above m8 will have either a 1mm or 1.25mm pitch.
The diameters of all threads will be a nominal size, so allowing for clearance/wear/damage etc a thread od not measuring a whole number will probably be the next highest whole number.
If you want to measure the pitch measure across the tops of 5 or more threads then divide the measurement by the number of threads.
Peter Jones 2028/12/2020 09:06:50
63 forum posts
9 photos
This will be far to late for OP but anyone else looking for information may find it useful?
I worked in Honda dealers in late 70's, find the general information manual online, it fills in 'gaps' in factory service manuals. I've seen a lot of complaints about service manual not giving full details. It's because they were written for dealer staff, not someone with little experience or training
Japanese screws are JIS, correct screwdriver fits and doesn't bugger up the 'cross' (JIS = Japanese Industry Standard)
Google it for more information. It's been around since 1966 or so (previously there were different metric standards for threads, fit, etc) DIN may use same thread form but bolt head sizes are different
Honda use standard diameters but fine thread versions.
Finer pitch gives a larger core diameter plus ability to apply more torque
Usual pitches are 0.8mm, 1.0mm, 1.25 and 1.50mm irrespective of the diameter. (24x1.0 is actually quite common on steering stem as is 14x1 and 16x1 on crank ends)
1mm pitch is most common on 6mm and 7mm bolts but can be 'anywhere' (Honda normally use 7mm chain adjuster bolts on >250cc)
1.25mm pitch most common on 8 and 10mm engine bolts and clamp bolts (8mm standard ISO size)
1.50mm -, usually axle bolts
The only thread I found incredibly surprising was on spoked wheels where Honda were using 1/8" WHITWORTH until at least the late 1970's (Harley Davidson were using 3 or 4mm metric at the time,)
Comstar wheels were designed to flex but the rivets at rim will loosen over time (hell, they came loose while some bikes were still under guarantee)
A metric thread pitch gauge will be useful, I've had some since early 70's and haven't bought any new since early 80's
On a machining site I wouldn't have thought anyone wouldn't know how to measure any thread they saw?
Peter Jones 2029/12/2020 00:29:30
63 forum posts
9 photos
Posted by Howard Lewis on 01/07/2020 10:34:55:
A large part of the reasoning is fines manufacturers have gotten from EPA and CARB in the USA (California Air resource Board)
A few years ago, Yamaha were fined around $23,000,000 for selling bikes in California that had been converted to California spec from 47 state models. They had not been imported as Cali spec and even though met all the standards required still resulted in massive fines and court costs.
The 'standard' fine for modifying a vehicle fuel system was around $10,000 per vehicle if done by a dealer and $5,000 per offence if done by an individual.
Honda went so far as to make not just sealed units but non adjustable units.
EPA did a lot of good things even though most 'petrol heads' hate them, we wouldn't have the high performance fuel efficient vehicles if it wasn't for EPA regulations.
CARB on the other hand, seems to be a beaurocracy designed to find fault and extort the maximum amount of money from people
