Dave Halford | 03/06/2020 12:21:26 |
2536 forum posts 24 photos | It's the same as undoing a stuck nut or bolt, when you get that springy feeling, stop pulling. If you are feeling nervous you can calibrate your pulling finger/s by using a spring balance on the end of the spanner. In your case I would leave it as is for now and when you finish wet the gaskets with washing up liquid, block the exhaust port, apply compressed air at running pressure and see if it blows bubbles tighten till it just stops. This way you get a margin for years in the future to get them undone. |
