from a 3.5 inch Gezina to 5 inch tramway Plettenberg locomotive
a conversion from a narrow gauge to tramway locomotive
duncan webster07/05/2019 09:43:02
5307 forum posts
83 photos
Unlike a meeting of an average UK club, the majority of the drivers in Werner's video seem to be younger. What's the secret?
Must say that Werner's loco has got me interested in rehashing the Tich I started nearly 50 years ago as a tram engine. It's been 'finished' several times, but you can always do better. Haven't touched it for probably 35 years, but I think I know where it is!
Werner Schleidt07/05/2019 19:51:22
158 forum posts
180 photos
Hallo Kerrin,Duncan,
The Plettenberg runs very good .She is able to haul two adult persons. On our narrow curve with 6 m radius there is some wheel slip, but for a loco with 28 kg it performs very good. I am impressed that the small boiler have no problems to hold the pressure during driving. The only thing is to carefully look to the water level ,because the water came then out of the chimney. With some experience it is all manageable. The number 2 injector is a good fit and runs perfect. I found a mistake in the donkey pump. I got this with other valves and stuff by chance for a good price. At higher pressure as 3 bars there was only less flow. The comercial who build this has a teflon piston on the water side with a bad fit. I added an o ring and now there is much flow under pressure.
That is all fine tunning. I think it was a great idea to work with the 3,5 inch parts and build a new 5 inch chassis.
Duncan to your first question. The young guys are in the age of 14 and above. They are from familys where the father love trains . The youngster with the BR 24 at the beginning pulls his father to the trains. Now the are both in love with trains.
This was not an open day with public so all could go in a relaxed way. The BR 24 had his first succesfull run. I show the youngster and his father how to adjust the walscherts motion control. Before they can only drive forward. I show him the principle how to adjust the motion control . And with a little luck then it was perfect running. They bought this loco and it does not run under steam before.
Since the new managing comittee is working,I am a member of it , we try to transfer experience in a firendly way.
So the youngsters find physics very usefull and they have a lot of fun with gaining more experience. And this is nice to see. And they are better in school . One of them searched a job for practical training. He was one of hundred . As he told the personal boss what he do as his hobby, he was selected and he was very proud to learn mechanical things.
We have in the club special locos for the youngsters, but we let them also drive club trains under the control of an adult person. So they are proud to do this. And this starts the fire in them for the hobby.
But it is difficult to get offspring. You have to pull the father with them. And this is very difficult. There are so many other possibilities to do without getting dirt at the finger.
I think Tich parts are good to convert,too. Give it a start and it is a good winter project. smiley
Werner
Werner Schleidt25/06/2019 17:59:00
158 forum posts
180 photos
Hello all,
I had some work on a hot day with more than 30°C. Since some time agao I worked on a mesurement test equipment and the unpainted Plettenberg is a good test object.
I wanted to measure the pressure in the cylinder and the displacement of the piston. I want to see how this diagram is compareable to pubished charts in books. And in next steps the measurement of indicated power in relation to the force on the draw-hook and the driving speed will follow.
Today it was a little bit tricky , because I had jobs for 3 persons but I have to done it by my own. My Laptop and my camera had heat problems. It was good to have a back up.
The pressure sensor with adaptors.
The cylinder cover where it was connected.
Now installed.
The selfmade displacement sensor.
The time diagram green is pressure, red ist piston travel. From start to driving a few meters.
The full piston travel during start.
Starting and driving with closing of the steam valve to slow down a little bit.
Start and driving as above in xy diagramm
Werner
Werner Schleidt25/06/2019 18:14:15
158 forum posts
180 photos
Hello all,
I made a documentation video of my tests.
Werner
Werner Schleidt01/07/2019 11:05:03
158 forum posts
180 photos
Hello all,
I want to update some findings.
I looked in the theortical steam diagrams and so I had some doubts about my measurements.
I double check the electronic and all was correct. The doubt came up ,because the pressure at the beginning have to be high and then a steady phase and then To the end lower pressure.
In my measurements it is more in the opposit direction. So I asked me where this come from. The only involved part is the exentric. I measured the excentric and compared it to the 3,5 inch Gezina drawing. I saw there is an error in the dimension. It have to be 19.5 mm and it was 18 mm. I looked more into the system and had the opinion that 21 mm are correct. So I made new excentrics with 21 mm.
Than I test the loco with pressured air. In the first step the steam engine runs in forward direction much smoother than before . Backwards it was not so good but better as before.
I decided then to measure with pressured air to see how it changes.
this looks now more as a "Zeunert" Diagram . The pressure comes from the beginning some steady phase and a pressure drop to the end.
The steam engine runs smooth under this condition. With the reverse lever one step to the middle position it looks like the following picture.
The engine runs faster with less air usage, so the pressure increased a little bit,but the engine runs not so smooth as before.
In backwards direction the engine behaviour is not so good. The pressure increased to the end of the travel and the timming is not correct.
But it is better as before the change.
With the reverse lever to the middle position there was some compression to the end of travel. The engine behaviour is not so smooth as forward.
After the mesurements I change the position of the exentric a little and the behaviour was then better.
In the next days I will make a test run under steam to see how comparable is the experience with air to steam.
With steam it have to be much better. But if the principle adjustment with air is the same as with steam it is more easy to do and to measure.
Werner
Werner Schleidt04/07/2019 20:00:40
158 forum posts
180 photos
Hello all,
I made now the tests with steam. Steam tests are more complicated with my one man show. Where I have 3 jobs locomotive driver, video guy and measuring man.
In the measuring files I saw that the mesurement have to collect with dry steam and warm cylinders .Otherwise there are some peaks in the pressure measurements. You can see that in the pressure displacement curves over time. With warm cylinders the steam measurements are comparable to the air pressure diagrams. With this small model with wet steam and small pressure is this my finding.
With super heating and high pressure it is different I think. The next thing is ,the small model have no intensiv cut off in the steering.
My conclusion is to set the link motion and to control it it is Ok to do it air pressure this makes it more comfortable. I all is in good condition a steam test make sense. and doing all alone on a small track is not advisable. The test have tob done with more load.
In the video I found a mistake the last diagram was made with steam not with air.
I made a short video of all .
Over the winter I have to look if I can speed up my measurement system to a higher data rate. The rate of 96 measurements per second is Ok ,but multiplied by 2 ore 3 is better. But at the time now it is difficult to handle the amount of data. It is advisable to think about a procedure for the work.
I hope you can enjoy my work
Werner
Edited By Werner Schleidt on 04/07/2019 20:07:21
Neil Wyatt04/07/2019 21:01:34
19226 forum posts
749 photos
86 articles
Thanks for posting that Werner, it's interesting reading.
Harry Wilkes04/07/2019 21:35:07
1613 forum posts
72 photos
Interesting video and engine
H
Werner Schleidt05/07/2019 12:58:44
158 forum posts
180 photos
Hello all ,
I think the knowledge base how indicator diagrams look like in the model range is small. The diagrams of big locomotives are more common.
I found these diagrams in a 100 years old thesis.
Tis one is more like the pulications I know .
It is from a Ball type engine
And this one from a robinson engine.
The robinson type looks more like my model engine.
It will be interesting to have a knowledge base and more than the loco runs good.
Werner
Werner Schleidt25/11/2019 07:57:32
158 forum posts
180 photos
Hello,
here is an update of my painting and assembling activities of my PLettenberg Loco.
After summer i decided to paint my loco. So i disassembeled all and cleaned all surfaces with soap water and brake cleaner of the frame and so on.
But it was in october to cold to paint outside. So I build in the basement a paint cabin from cardboard and on top there was attached a computer fan with a hose to the basement window. With this setup I painted wit spray cans all surfaces several times. This was a straight forward time consuming job.
As I put the frame together I had a better feeling as I see that it looks more than a locomotive again.
It is always an adventure to puzzle all the parts and screws to the right places back.
The frame is ready to attach the boiler. As i want to screw the ashpan and grate attachment i saw that i had assembled the fixing bars in the wrong way. I found the easiest way was to bore three new holes for the screws.
Werner
Kerrin Galvin25/11/2019 08:24:12
44 forum posts
9 photos
Hi Werner,
Coming together nicely! Great to see an update.
Cheers Kerrin
Werner Schleidt01/12/2019 08:18:06
158 forum posts
180 photos
Hello all,
here is the next update.
The chassis is completed again for testing with air pressure.
What colour made a difference - In the front on the left the steam pump and right the hand pump. Down the footplate the oil pump.
And now with the housing . It was an intensiv work to paint all parts and line the edges with black colour.
The window is moveable so it is possible to fill the oiler with a doctor syringe.
It looks nearly like the original,
This is the driver view with some compromise for a good use for all handles.
Original and copy.
Some trim parts are still missing ,like the brake hose and the coupling hooks.
This is the night view with all lamps on.
The lamps are made with LED pulled out of defectiv 230 V LED lamps. They run with 5 miili Amps of current.
The driver side with illumination of the pressure gauge and the water glas.
The front , the rear and the inside lamps are separate to switch on and off. A 9 Volt battery gets the power for about 12 hours continously. All is installed in the coal box in the left side.
Werner
Johannes Grabsch22/12/2019 16:50:13
22 forum posts
2 photos
Hallo Werner
Gratulation zu diesem vollen Erfolg. Es ist eine schöne und vorbildgerechte Lok geworden. Und wie bei Dir üblich, testest Du die Lok auch wie gehabt, genauso wie bei der Feuerwehr.
Nun weißt Du auch, wo ich jetzt häufig aktiv bin...
Alles Gute Johannes
Werner Schleidt24/12/2019 06:12:46
158 forum posts
180 photos
Hallo Johannes,
danke für das Lob ,ich habe dir eine PN geschrieben.
Gruß Werner
SillyOldDuffer24/12/2019 10:05:34
10668 forum posts
2415 photos
Posted by Werner Schleidt on 04/07/2019 20:00:40:
Werner
Somehow I missed this thread in April, so an early Christmas present this morning!
Very interesting, especially the indicator diagram highlighting a problem with the locos valve gear. Perhaps clubs should consider ways and means of applying Werner's tests to their member's locomotives?
Coincidentally I'm reading Duncan Webster's draft essay on valve-gear. Duncan uses computer simulations to graph the characteristics of many different types of gear from Stephenson to Brown : I find his discussion of the theoretical and practical advantages and disadvantages of each type fascinating.
I can't help wondering if the understanding and insights could be applied more widely to models. LBSC died 50 years before the technology to do this was readily available: no excuses today, as Werner and Duncan demonstrate! I doubt applying scientific method to model locomotives would result in massive improvements across the board but it might explain why some engines perform better than others, and it would certainly keep me amused!
Keep it coming Werner!
Thanks,
Werner Schleidt25/12/2019 13:20:59
158 forum posts
180 photos
Hello Dave,
nice to see your interest in my work. After painting and reassembling all, I made test runs with air pressure. In the reassembling i made all bolts in the motion setup new to reduce lash. The position of the cylinders at the frame where not absolutly at the same place as before. So I had to readjust the walscherts motion link.
I made this by looking to the steam ports and I do not know why on the right side the behaviour was as before painting very good. Perhaps it was by chance and the fit of the attachment to the frame is better.
On the left side there where problems the Loco runs ,but not as good as before. So I decided to measure again.
Another reason was, I made optimizations of my software and with each step it is more usefull now. And in 2020 I will measure a big K1 of a club colleage.The Plettenberg is my test loco to improve all.
Here is my presentation and findings.
All measuremments have been performed wit a low air pressure of 1bar ,because my compressor is not strong.
The spring can come, I made my homework,it will be an interesting year 2020.
with christmas greetings
Werner
Edited By Werner Schleidt on 25/12/2019 13:25:51
Edited By Werner Schleidt on 25/12/2019 13:27:03
Edited By Werner Schleidt on 25/12/2019 13:28:23
Werner Schleidt22/01/2020 17:16:43
158 forum posts
180 photos
Hello all,
on monday there was a very cold and sunny wheather . So I decided to make a photo rollout.
On the track
On the turntable
I think this was a nice build project. It made me a lot of fun. It was a good idea to awake the 3 1/2 inch parts to a future 5 inch gauge life.
with best regards
Werner
Werner Schleidt24/06/2020 09:02:20
158 forum posts
180 photos
Hi folks,
I had some time to test my Pettenberg Tramway Locomotive under steam after disassembling and painting over the winter time.
I did some optimization of my garden railway and so it was good time to test the locomotive. I had some trouble with the safety valves , because of to early openning. After setiing correct the fun of driving starts. The engine runs very well under steam . Injector and the steampump worked perfect . The crossheadpump and the oilpump were in a good order too.
It is a good feeling when a project is ready .
There is an impression of my test ride .
Please enjoy it
Werner
Edited By Werner Schleidt on 24/06/2020 09:02:41
Werner Schleidt27/08/2021 07:41:07
158 forum posts
180 photos
Hi all,
I had some time to make driving tests at our club track .The Plettenberg tramway locomotive is my smallest locomotive i have,but she is powerful enough to drive with two adults. The weight of her is about 27 Kg. And she is equiped with injector and a steam pump and a automatic helping blower valve.
I forgot that i made a special coal shovel for her and so it was a little bit fiddling to get the coal in the small fire hole. But with some experience this was not a problem. It was a very enjoying day to drive her. I made the video by my own and so it was a little bit tricky to record myself driving.
I think the video give a good overview of the driving behaviour of this smal locomotive. I am ver astonished how good this small oiler behaves . The cylinder and boiler was from a former 3,5 inch locomotive and was then converted to the Plettenberg.
I found a video from the original which is located by the Deutsche Eisenbahn Verein in Bruchhausen Vilsen in northern Germany. It is a nice video with german explanations , but the pictures are in international language.
please enjoy the videos
Werner
