Myford Super 7 Tailstock Micrometer Dial
Graham Meek06/11/2018 10:15:37
714 forum posts
414 photos
Thanks to Steve I am able to share with you a photograph of the Metric dial assembled onto the Tailstock. Looks as though it has always been there.
Gray,
Mike Crossfield06/11/2018 10:28:19
286 forum posts
36 photos
Gray
Just a small aesthetic point. Was there a good reason for not matching the reduced diameter of the base to the diameter of the tailstock casting?
Brian Oldford06/11/2018 10:35:35
686 forum posts
18 photos
Posted by Graham Meek on 06/11/2018 10:15:37:
. . . . . . . Looks as though it has always been there. . . . ..
A perfect complement to the saddle handwheel.
Graham Meek06/11/2018 11:10:05
714 forum posts
414 photos
Posted by Mike Crossfield on 06/11/2018 10:28:19:
Gray
Hi Mike,
I and my helpers have deliberated over this very point. One problem which exists is the eccentricity of the tailstock casting. On some tailstock bodies the eccentricity is very pronounce and this would show up even more if the abutment face was larger in diameter. Trying to match the two would be impossible and would always leave a step somewhere around the diameter. To make the backplate just a plain diameter would I feel detract from the current set-up and make the assembly look bulky. Of course there is no reason why anyone making the attachment cannot add their own flair in this region.
Nothing is carved in stone with my designs.
Another point in favour of the reduced diameter comes when fitting this attachment to the 254 lathe. It appears from the photographs I have seen that Myford have "spot faced" the tailstock in this region to take the same part as is fitted to the S7, so a larger diameter here would be a problem.
This then was some of the rational behind why I have done what I have.
Gray,
Mike Crossfield06/11/2018 15:55:52
286 forum posts
36 photos
Thanks for that explanation Gray. I knew it would not have been unconsidered.
Looking forward to seeing a write up somewhere and making my own copy!
michael m19/11/2018 15:35:30
61 forum posts
3 photos
There has been some recent interest in the proposed Myford Super7 tailstock micrometer dial design by Graham Meek. I'm fortunate in owning one of the imperial version prototypes made by Graham himself and thus am able to report on same.
The design, in similar fashion to Graham's saddle handwheel dial design, uses a gear train built into the assembly to rotate the dial such that tailstock barrel travel can be accurately determined from the dial graduations. As Graham has mentioned in one of his posts the gearing methodology is perhaps counter intuitive but he has cleverly achieved the required ratio in a reasonably sized unit. The unit incorporates needle roller thrust bearings which in addition to the Myford tailstock thrust races, which are retained, give a silky smooth handwheel action. The dial can be positively set to zero with a smooth action using a friction arrangement as on the saddle wheel. Perfectly reliable.
Aesthetically the design is very pleasing, and is complementary to both the lathe and the saddle handwheel micrometer dial. It doesn't look like a bolted on after thought. Note that a complete turn of the handwheel gives 0.3" travel to the barrel whereas a complete turn of the dial indicates 0.5" travel of the barrell. This sits readily with the 1/8" graduations on the barrel. No alteration is required to the tailstock feedscrew or barrel nut.
Graham has been described elsewhere as a worthy successor to the late George Thomas. He also designed a tailstock micrometer dial but I believe that Graham's design is an advance on that with a larger parallel dial that improves readabilty and an improved correlation between the dial and the barrel graduations. The friction lock for the dial is much simpler.
In conclusion I happily recommend the dial for those in pusuit of accuracy, those who have the saddle wheel version will not need telling.
My understanding is that Graham will eventually myford tailstock dial.jpgpublish a constructional article, possibly MEW would be an ideal candidate. There is also a possibilty that someone, albeit not Graham, will take up commercial production.
Michael
Graham Meek08/01/2019 17:00:41
714 forum posts
414 photos
Posted by Mike Crossfield on 23/09/2018 13:28:12:
Gray,
What a neat solution. I built your Super 7 carriage handwheel a couple of years back and find it invaluable. I look forward to seeing construction details for the tailstock dial in due course. Where will the article be published? ME, MEW, or elsewhere?
Hi Mike,
Just to let you know the article is finished and has been offered for publication, no further news at the moment as to where that will be.
Gray,
Mike Crossfield08/01/2019 17:35:15
286 forum posts
36 photos
Thank you for the update Gray.
Graham Meek13/01/2019 13:27:09
714 forum posts
414 photos
Hi Mike,
I shall be sending the article to Neil over the next couple of days.
Gray,
Steamer191504/05/2019 21:33:12
171 forum posts
42 photos
For those of you that will be attending the Doncaster exhibition next weekend, I will have on show one of Gray's prototypes that is fitted to my S7 tailstock. This will be on the Hull and District SMEE stand and I also hope to have the dismantled Metric version (again, Gray's prototype) available so that people can see the working of the gear sets.
I should be around most of the three days to answer any questions.
It is hoped that these will be available to buy later in the year.
Best regards,
Steve.
Hillclimber05/05/2019 08:09:13
215 forum posts
51 photos
Posted by Steamer1915 on 04/05/2019 21:33:12:
Best regards,
Steve.
Steve, as to that timing, should I be putting one of these on my birthday or Christmas lists?
Cheers, Colin
Steamer191505/05/2019 08:34:01
171 forum posts
42 photos
Hello Colin,
I would say Christmas... ...unless your birthday is in January, February, March or April...wink
My best regards,
Steve.
Steamer191502/06/2019 10:58:20
171 forum posts
42 photos
I attended the Doncaster exhibition and there was a lot of interest in Gray's Tailstock dial that I have fitted to my own S7 Tailstock. I was able to demonstrate the gearing of the dial using the Metric version that was set up on Gray's test rig.
I was intrigued to see the "similar" offerings on the Myford stand, which leads me ask the question "Has anybody bought one of these items, fitted it and made any sense of the graduations?"
Unlike Gray's design, these dials (fitted to a shiny new handwheel) have no internal gearing and are sold as a direct replacement for the existing handwheel. The links to the eBay listings are here for the METRIC version and here for the IMPERIAL version.
One turn of the S7 Tailstock handwheel moves the barrel along by 0.300" or 7.62mm. This applies to both Imperial and Metric S7s
Taking the Imperial version first, I'm struggling to understand how 0-60 graduations relate to the 0.300" lead, much less relate to the graduations that are engraved on the barrel.
The same applies to the Metric version, which is graduated 0-3mm and again bears no relation to the engraving of the barrel on a "Metric" lathe.
Rather strangely, the Metric dial would give a better degree of service as an Imperial dial, given the 0-3 (mm) divisions. Indeed, the chap on the Myford stand tried to tell me that "They have just been swapped over mate" until I pointed out that the Imperial dial would not be marked 0, 0.5mm, 1mm, 1.5mm etc. His reply was "Don't know then mate"
Am I missing something obvious here? I don't think so but I'm happy to be corrected.
Best regards,
Steve.
Edited By Steamer1915 on 02/06/2019 11:05:42
Edited By Steamer1915 on 02/06/2019 11:06:45
