peak4 | 26/03/2020 01:55:37 |
![]() 2207 forum posts 210 photos | Richard, lubrication, and main bearing adjustment, was the reason I was wondering if you had a manual. I gave the main spindle bearings a squeeze from a grease gun when I got it; the previous owner had already started cleaning it up when he decided to sell it.
I spotted the 720 advertised locally and was seduced by the gearbox, power X feed and a brand new inverter motor package. It came at a good price and was installed in the new house in Buxton. Bill |
Richard Black 2 | 03/04/2020 13:00:29 |
4 forum posts | Sorry Bill, Didn't see this on the next page! I dismantled the spindle to check the bearings as I realised I hadn't lubricated it for a very long time. I was rather amazed to find the taper rollers in fairly good condition with minor signs of wear and still grease in them. I replaced the bearings with the same make and number which was ridiculously cheap and cleaned it all up and put it back together. I haven't re greased the bearings yet as I am nervous about overdoing it and getting grease everywhere. The minor irritation is the lack of any flats or similar on the threaded collar to adjust the spindle bearings. I wasn't sure whether or not to put a pre load on them. In the end, I just set them up with no play but no pre-load. Seems ok. I did find that the gearbox had been greased rather than oiled but all seems to be in good condition. I have cleaned out all the grease and keep the box topped up and pump oil into the grease nipples now. It will be interesting to see if it is better. I haven't stripped the saddle yet so have no idea what has been used for lubricating that. I suspect it is full of grease though. I agree about the clutch. A bit scary and I haven't relied on it. I will try your idea and see if it is better. The other thin about it is the feed lever on the saddle. Mine has a spring and a clip to stop it dropping into gear and engaging the drive. It really does do that and it is scary. I saw the grub screw through the collar on the cross slide goes onto the thread and I can't get it off at the moment due to damage to the thread. It is all on hold a bit at the moment as I can't get the imperial nut (mine is brass or bronze and quite worn) as Myford are closed due to the virus. A chap has a nut and lead screw on ebay but it is over £120 and metric which I don't really want. I saw a neat mod for it using thrust roller bearings on either side of the bracket to eliminate back lash but also allow free movement without drag. I might do that when I rebuild it. Also need the washer between the lead screw handle and the micrometer dial. Currently it locks it up when you tighten the handle. I bought mine about 30 years ago when my workplace replaced the Warco with a genuine Super 7. It had been fairly abused for a few years by the workshop before I got it but it is still pretty good. I only paid £75 for it! I have finally decided to rebuild the bits that needed it. Thanks for the info. Richard.
