Class 22 Diesel (next project)
Ron Laden04/08/2021 16:23:15
2320 forum posts
452 photos
Still no track test I,m afraid I haven't been too well recently in fact I haven't been in the shop for over 6 weeks but on the mend now. I was hoping for this Saturday but the forecast is wet sad just my luck.
Anyway I found a nice set of cast beam furniture which will save a lot of work, an hour with some needle files should see them ready to fit as they are quite clean, the hook and links I will make myself.
Jeff Dayman04/08/2021 16:54:57
2356 forum posts
47 photos
Great looking casting set Ron. Hope you are better and able to get out on the track soon. Cheers!
Ron Laden17/08/2021 16:06:37
2320 forum posts
452 photos
Hi guys,
I decided to get another diesel sound card for the loco (wiring diagram below), its a different type to the old one I had which went pop.
I think I have said before I am ok with basic wiring but when it comes to electronics I am a bit dull to say the least. The motors, batteries, speed controller and isolator are fine thats how I have them wired already. I understand that the pair of 10K resistors to the motor control prevent the voltage from exceeding 24 volts and the sound card is fed with 12 volts. I,m ok with the rest of the wiring but what I dont understand is how the 16v capacitor, 1K ohm and 100 ohm resistors and the way they are connected to the amplifier stereo jack are working. It would great if one of you guys can explain what is happening there, it would just be good to know.
Ron
Ron Laden28/09/2021 14:03:10
2320 forum posts
452 photos
Apologies for the thread dragging on but life and health (don't ask) just got in the way especially of late. However I did manage a few productive hours in the shop last week and the loco is as finished as its going to be. I still have the two cabs to fit out but they can wait.
So all been well if I continue to improve the track test is not far away and I hope to get some video of how things go.
Picture below of it desperate to be sitting on some rails.. smiley
Ron Laden28/09/2021 15:29:00
2320 forum posts
452 photos
A bit better focus I think.
Roger Best28/09/2021 21:39:46
406 forum posts
56 photos
Awesome. Great job.
I know most readers will be more interested in steam engines but having driven a similar-sized battery electric engine at Basingstoke &DMES I can fully appreciate both the modelling and the fun of operation that this model offers. laugh
Jeff Dayman29/09/2021 00:24:47
2356 forum posts
47 photos
It's looking great Ron. Hope you get your rails wish soon! Cheers
Ron Laden29/09/2021 07:24:22
2320 forum posts
452 photos
Thanks Jeff/Roger
Ron
Ron Laden15/10/2021 10:17:26
2320 forum posts
452 photos
The loco passed its track test it runs very well, good traction, quiet, good throttle response and very stable on the track, really pleased with it.
The only thing I need to change is the gear ratio, its too high which I suspected it would be in using the pulleys that came with the motors. At full throttle its scary fast just too much so a smaller motor pulley should help cure that and possibly a max throttle stop.
A very short clip of a club member enjoying some circuits in the sunshine
Jeff Dayman15/10/2021 13:03:36
2356 forum posts
47 photos
Looks and runs fantastic Ron! Well done! The driver looks happy on it, too. Did you have a few runs on it yourself? looks like a perfect day for it. Plenty of time later in the cold days to do the gearing adjustments.
Ron Laden15/10/2021 17:28:01
2320 forum posts
452 photos
Thanks Jeff,
Yes I lost count of the number of runs I had there was only 3 steamers and me so a quiet day loco numbers wise, the steamer guys finished early so I had the track to myself and it was a lovely day. I have to say that I was taken by surprise at the acceleration and the top speed when I opened her up on the back straight which is not that long. It really pushed me back and guesstimating top speed at 15+mph and with the club speed limit at 5mph obviously far too much.
The motor pulleys that came fitted to the motors are 16T giving 4.5/1, I have some 12T pulleys which would give 6/1 but they are not one piece the toothed section is turned to a spigot with the boss pressed on and with a 8mm bore to fit the motor shaft the boss would come adrift. I could remove the armatures from the motors run between centres and turn them down to 5mm which would leave enough meat on the 12T pulleys but that is something to consider for the winter months. In the mean time it just needs some throttle control to keep things sensible.
Ron
JasonB15/10/2021 18:47:36
25215 forum posts
3105 photos
1 articles
Running well Ron.
Ron Laden16/10/2021 09:31:29
2320 forum posts
452 photos
Thanks Jason, just pleased the design worked out OK.
Ron
duncan webster16/10/2021 12:11:58
5307 forum posts
83 photos
If you're into electronics it should be possible to make a unit that monitors and limits speed but still gives full chat for starting, hill climbing etc
Ron Laden16/10/2021 14:12:58
2320 forum posts
452 photos
That's a good idea Duncan but I,m afraid I am not into electronics to that level. I am OK with basic wiring and ok with simple electronics if I am shown what to do but I don't have the understanding to design a unit as you describe.
I still want to change over the ratio from 4.5/1 to 6/1 which will increase the pulling power and offer some reduction in top end speed.
Ron
Edited By Ron Laden on 16/10/2021 14:15:34
Roger Best16/10/2021 16:14:13
406 forum posts
56 photos
Its always better to get the ratio right for the characteristics of the motors. Less likely to burn them out.
The weathering looks great on the video.
SillyOldDuffer16/10/2021 17:44:50
10668 forum posts
2415 photos
Posted by Ron Laden on 17/08/2021 16:06:37:
Hi guys,
... what I dont understand is how the 16v capacitor, 1K ohm and 100 ohm resistors and the way they are connected to the amplifier stereo jack are working. ... it would just be good to know.
Late answer, but here goes.
The 100Ω and 1kΩ resistors form a potential divider. It's purpose is to match the output of the sound board to the level required to drive the amplifier. Most amplifiers are quite sensitive and if the input signal is excessive, the amplifier will clip and otherwise distort the audio sent to the loud speaker. The divider's ratio is 10:1, which would be right, for example, if the amplifier input expected 1mV and the sound board output a 1V signal. It's a fixed volume control.
A useful property of capacitors is they block DC current whilst allowing AC to flow. The 16µF capacitor is a isolating precaution: it stops any DC that might happen to be on the sound board output from confusing the amplifier.
The divider and capacitor ensure the right level and type of voltage are fed from the sound board to the amplifier. The combination will also act as a tone control, but like as not the effect has been ignored by the designer. If the output sounds a bit shrill, or lacks bass, try increasing the size of the capacitor. Anything up to 220µF should do.
Although the amplifier is stereo the Sound Card is mono. The Potential divider drives both Right and Left Channels, a mild bodge. Reason for this is likely cost. Small stereo amplifiers being common as muck are often cheaper and easier to source than their mono equivalents. It's nothing to worry about.
Ron Laden18/10/2021 16:21:26
2320 forum posts
452 photos
Thanks Roger, I must admit I am a fan of weathering providing its not over done or done badly. If done reasonably well I think it can add realism to the subject, though its not everyones cup of tea and I think the majority prefer their locos looking pristine which is fine, everyone to their own.
Dave, thanks for the explanation on the amplifier circuit and what each component does.
I learnt something today by chance whilst watching a video, although a lot of switched circuit breakers look the same there is AC and DC types and they are different animals not to be interchanged. Not knowing there is the two types I just ordered one at the time and I cant remember any reference to AC or DC unless I missed it. So I think it probable I have an AC type in the loco when of course it should be a DC so will have to get one on order.
Goes to prove that too little knowledge can be dangerous.
