Member postings for Robert Thompson 3
Here is a list of all the postings Robert Thompson 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: Smoke Generator 5
12/05/2018 13:05:13
Thanks for the heads up on that Trevor i will certainly give it a look
Robert
12/05/2018 12:42:48
Good Point John, but i havent seen a Diesel locomotive without smoke from its exhaust to date.
My locomotive is of Western Campaigner D1010 currently preserved on the West Somerset Railway, and she definitely smokes .
Robert
12/05/2018 12:34:19
Thanks Murray I must admit i hadn't thought of that option but will investigate. My only reservation would be the duration between fills as the locomotive is used for public running. The Harbor Models has a duration of about 3 Hrs.
Robert
12/05/2018 11:57:54
Good morning,
I have a 5" gauge Class 52 Western Diesel and would like to fit a smoke generator capable of producing as realistic an effect as is possible.
The Drive system is 4 motors @'24 volts DC powered from 2x 12 volt traction batteries 50Ah each.
The only one i have seen to date is from Harbor Models in the USA which appears to fit the bill but they are not answering my E Mails.
Does anyone know of a similar unit available maybe in the UK, or have had any dealings with Harbor Models??
Many Thanks
Robert Thompson
Thread: 31/2" Canterbury Lamb building instructions
11/01/2015 09:50:19
ok thanks for that
09/01/2015 14:29:56
hi Fizzy Thanks for the warning
Bob
09/01/2015 07:06:45
Hi all,
Does anybody have the "words and music" for the 31/2" Canterbury Lamb Invicta that i could purchase As described in Vol 107-108
Many Thanks
Bob Thompson
Thread: Boxhill Terrier Build Notes
26/05/2012 12:30:47
Thank you Julian , you have obviously researched the subject well. Thanks for sharing your info. and knowledge with me.
i will have a good look when the sun goes down.
Cheers
Bob T
26/05/2012 11:56:41
Wow Thanks for that Julian
Bob T
26/05/2012 11:54:08
Thanks Julian,
I see a Trip to the Bluebell looming,
Thanks for your help enjoy the sun
Bob T
26/05/2012 11:13:03
Thanks Julian,
I have already machined the cylinders and covers and drilled for the fixing bolts. Just got the tricky bits on the underside of the bolting flanges to do.
I took a print of Norman Barber's drawing showing his drain cocks so hopefully can get it right. I take it the 5th drain cock would go on the underside of the steam chest at the rear end and linked to the same linkage.?
I too had thought to get rid of the pump, presumably a similar take off from the turrett would be needed for the steam and the second injector connected to the other clack.
Many thanks
Bob T
26/05/2012 09:24:40
Hi Julian,
Me again with a couple more questions if you can help?
Firstly can you advise on size of drain cocks ( as in thread size)
Secondly do you know what duty injector is suitable for Boxhill?
Thanks and regards
Bob T
16/05/2012 21:04:30
Thanks again Julian
Bob T
16/05/2012 20:24:44
Thanks Julian, I knew i could rely on you and thanks for the tip, i was a bit concerned at applying all that pressure to what is a relatively delicate assembly. My boxes are not split but yes i was wary of pushing ahead and leaving them off, easily done.
Cheers Julian
BobT
16/05/2012 16:00:22
Hi All,
I am about to fit the wheels to my Boxhill. I have succesfully quatered and pressed on the front and rear wheels.
When it comes to the driving wheels and the quatering of the same, what is the position relative to the crankshaft. The crank leads on the right hand side by 90Deg so are the wheels in sync with the crank or do they lead the crank by 90 or 180 Deg ???
Many thanks
Bob T
Thread: Any "Beginners" building 5" gauge Boxhill?
09/04/2012 10:05:03
Thanks Peter thats very helpful indeed. As you say pictures always explain so much better than words. I will drop you a line.
Cheers
Bob Thompson
08/04/2012 13:10:06
Thanks Julian excellent service
Bob
08/04/2012 12:46:46
Hi all, a question for you. I am looking at the crank shaft in particular the webs. The build notes call for 1"x5/16" material but all the drawings show 1 3/16" x 5/16" and i cant see a clue as to which is correct. Can anyone help?
Thanks
Bob Thompson
Thread: Boxhill Boiler Construction
03/03/2012 12:31:49
Hi Julian, and thanks for taking the trouble to expand so thoroughly on the subject . By coincidence Ihave just received the construction notes very kindly copied and sent to me by Dennis Rayner so now I should have a much better idea on what is needed. No doubt i will be on again in the future but once again many thanks, this really is uncharted territory for me.
BobT
02/03/2012 09:31:00
Thanks Julian, that removes some of the haze but one of my biggest problems was the stays that are shown on Martins drawing? namely 23 on each side, 8 shown on the firebox tubeplate and seven on the backhead and where these connect at the other ends? sorry if that sounds a bit of a thick question but most of out little gas fired boilers ive been used to have no stays and even the coal fired 16mm boilers may have at most 2.
Cheers
Bob T
