Here is a list of all the postings Bazyle has made in our forums. Click on a thread name to jump to the thread.
Thread: Oh dear - not quite right - again! |
19/05/2023 16:09:04 |
Posted by vic newey on 19/05/2023 11:48:16:
Pirates say Arr not Are
I wonder if you have missed the point of the cartoon? |
Thread: George Adams 2 1/2" Precision |
19/05/2023 11:48:50 |
By the way before you get puzzled by the headstock bore if it seems to have an obstruction or you are wondering what Morse taper it is note that some came with an insert to take 8mm watchmakers' collets. It is removable but might be best leave in situ as one seldom really needs to insert a MT in the headstock. An ideal size for clockmaking, boat engines, and locos up to G1. |
Thread: Whats the best material to withstand impact? |
17/05/2023 21:50:36 |
A couple of points wrt PETG that have just been raised on the gaugeone3Dcircle is that as it prints at a hgher temp than PLA it can give problems with warping off the bed so an enclosure is to be recommended to keep it all warm. Then having solved the adhesion problem it can be too good, to the extent of being impossible to get off a glass bed. If you are just after making a box then nothing beats wood. |
Thread: First workshop |
17/05/2023 18:20:14 |
Check your town for a flooring/carpet company. I have a local one that is continually filling a skip with offcuts of new carpet and wood flooring. With such a small space I could easily just change the carpet every week instead of sweeping. |
17/05/2023 09:47:40 |
Be aware that although it seems dry when you are in there breathing more often for longer periods damp will condense in the darker corners. |
Thread: Stuart 10 Machining Steam Chest |
15/05/2023 10:16:00 |
That is an absolutely ludicrous waste of material. Mass production jig instead of learning what can be done with a standard lathe. Typical youtube stretch it out and blow it up to make a video. |
Thread: Workshop floor advice please |
14/05/2023 11:16:34 |
My comment about leaving time was not about the strength but moisture as the excess in the concrete evaporates. Also if not dry any rubber based coating might come adrift as water can't get out. |
13/05/2023 17:10:38 |
Since you need to let the concrete dry out for a few months you have time to start collecting a lot of pallets and stripping them to provide about 3 layers under a top of chipboard/ply and lino. |
Thread: What did you do today? 2023 |
12/05/2023 22:21:56 |
The Exeter DMES had an outing to our local steam engine (model) trader, Berrybrook Steam A fantastic display of Traction engines being reworked or ready for sale from Mamod up to 6" and their full sized one in steam which at teh end of the evening was driven onto a low loader to go to a show at Trago over the weekend. The truck was facing down a bit of a hill so it meant some skilful driving to get up the ramp then stop on the down slope and you know what sort of brakes a TE has. |
Thread: homemade nickel plating with coins |
12/05/2023 22:08:58 |
But isn't a bit of actual nickel sheet cheaper? |
Thread: Syncronome Clock magazine article |
12/05/2023 22:05:37 |
Thanks for your intervention John I seem ot have access to Synchronome1 at groups.io too. |
12/05/2023 12:16:48 |
!987 'An Electric Master Clock' 14 parts from Feb 87 but a pause after the clock is complete with the last 3 from March 88 covering the slave. Unfortunately my copies are 250 miles away - if only you had asked yesterday. There is the Synchronome1 group on groups.io but he keeps ignoring me when I ask to join. You may have better luck. Also the Facebook Synchronome group didn't like me as I didn't know the secret handshake. However the mysterious (because it doesn't come up on a search on groups.io) electric-clocks group gave me access in minutes and they do have some some members from this forum. |
Thread: Rose indexer |
12/05/2023 10:27:26 |
Thread: Bulkhead Penetrators (Getting a good vacuum seal) |
12/05/2023 10:23:57 |
Flange and seal on outside so that the pressure is compressing it not trying to push it out of the gap.. |
Thread: Book Of The Week - Watchmaking. |
09/05/2023 23:13:13 |
The ultimate book for an engineer horologist has to be Watchmaking by George Daniels. |
09/05/2023 20:20:39 |
Yesterday we decided to delay taking down the church Union Flag 'cos it was raining. So today it was rainig harder. |
09/05/2023 20:20:38 |
Thread: David George's Retracting Toolholder |
09/05/2023 13:58:07 |
How about a swing clear operating on the rear upside down (for normal threads) with a release trip. The cutting force would then lift it off the cut as well as having a spring to throw it back out of the runout groove. |
Thread: Improved Experimental Pendulum |
09/05/2023 00:33:04 |
I take it you get NTP over the internet. is that cable modem, landline or mobile? You might like to run a parallel ping test to see how that is varying with your NTP data. The internet was never designed to send time critical data and is only kept vaguely in line because gamers whine so much about ping times, edit - you could also mess your head up by comparing NTP from different servers, and mobile v other modem. Edited By Bazyle on 09/05/2023 00:34:57 |
Thread: Quorn Tool and Cutter grinder |
08/05/2023 15:30:19 |
BTW we are assuming the geometry ensures distance moved by the arm equals distance moved by the tool. Otherwise we are back to 'a tad' and one could make small adjustments by inserting bits of paper under the screw contact point. What is the thickness of MEW pages? |
