Here is a list of all the postings Iain has made in our forums. Click on a thread name to jump to the thread.
Thread: Speedy bore and rings |
24/02/2013 14:20:00 |
Hi Fizzy You can go to the best design and get hold pf Clupet Rings I think they still exist somewhere in the UK |
Thread: Black hole |
07/01/2013 14:19:52 |
We have the same in SA Lost an 8 BA spanner about a year ago since then have removed and refloored the workshop Black Hole still there! |
Thread: First lathe |
19/12/2012 14:22:54 |
As a gear Engineer lets just get the Phospher Bronze / EP oils Question out the way ( Wormboxes use PB Rims). Some EP oils will damage PB but remember oil technology changes al the time New EP oils don't damage PB but the older oils can Hence the warning on EP oils from the Morris handbook I still advise clients to stay away from EP oils if they have not been passed by a qualified Tribologist as being suitable. Also don't mix synthetics with Mineral oils. The major oil companys of today are giving you the best (You don't need to put in an additive If it was any good somebody like Shell or Petronas have already added it to their oils)
Thread: 5" Gauge Boilermaking - Heat Required For Silver Soldering |
05/05/2012 15:14:24 |
Try and get Alex Farmers Book:- Model Locomtive Boiler Making he makes two torquay manor boilers in it. Uses OXY/ACET |
Thread: Myford ML7 questions |
14/03/2012 14:14:53 |
Also have ML7 wouldn't part with it for the world. I have tried carbide tools Good for cutting through casting 'skin' annd flash but prefer HSS tools for good finish. Do yourself a faour a QC toolpost is the best ever |
