Member postings for Neil Greenaway
Here is a list of all the postings Neil Greenaway has made in our forums. Click on a thread name to jump to the thread.
Thread: taps&dies
01/05/2012 17:56:03
hi there,one of my previous employers used a lot of tungsten carbide taps etc on exotic alloys such as high grade stainless materials,monels and inconels.they were used in machine centres normally, with feed,speed and torque control, and even then they had breakages!neil.
Thread: Exothermic Cutters
20/03/2012 21:28:03
Hi There,
I have used a 40A plasma cutter for cutting panels and chassis repairs in a landrover - thicknesses range from 1.2mm to about 3mm. Handheld use can be tricky as it will cut the shape including every shake of your hand - especially if you are in an awkward position under the vehicle and reaching!! This is even worse when sparks land in your ear or down your back, and thats even with a welding mask and flame retardant overalls!! With a guide/straight edge the results can be good. The electrodes/tips can be eaten up quite quickly especially with dirtier materials I find however. With the 40A machine I have cut up to 12mm plate also, but the cutting is a lot slower at that thickness.
In previous employment we had a contractor use thermal lances to cut through an aluminium melting furnace outer casing and then through the refractory and oxide layers that built up during extended use. Diggers with heavy breaker hammers couldnt even break through the oxide layers but the thermal lance could. The results were not pretty however.
Thanks,
Thread: myford ml10 lathe gear quadrant or banjo arm
11/03/2012 18:11:57
If you dont manage to find one you could always have one laser cut from steel plate - if you have the broken pieces at least you would have enought as a pattern and a laser cut part would only require minimal finishing?
Many thanks,
Neil.
Thread: 3 phase motor rotation direction
02/03/2012 16:18:18
Hi All,
I feel I have to add my thoughts here as some others have. I have worked in a variety of industrial situations where I have been/am responsible for new electrical installations/replacement installations of old equipment. We always use qualified electricians for the on-site work, and often consult with competent individuals (consultants) for design phases. I have experienced on occasions situations where our trained electricians are unfamiliar with some of the types of technology often mentioned in this forum e.g VFD's or servo drives etc. Obviously they are first class at installing new equipment, installing containment (cblke protection systems), specifying suitable cable sizes for power capacities, cable runs, installation method etc etc etc. They are very capable of installing new distribution boards etc or terminating new supplies. They do come stuck where it comes to some electronic controls, and this is where specifically trained electricians come into play. I take on board the opinions of "Kinlet Hall", however if an individual is familiar with the nature of the work and carries out the design/installation according to the 17th edition IET Wiring regs there can be little room for error. Surely the thankfully rare cases of fire are generally caused by poorly installed circuits, poorly terminated cables (with a high resistance/low continuity) or a badly selected cable with too low a current carrying capacity.
I know and work with many electrical engineers and electricians, who work in very different circumstances - domestic, industrial, local utilities, automation etc, and I have to say there is no one size fits all electrician, and as a result you may find that your NICEIC electrician may not have an awareness about things such as motors, drives etc.
It has also been mentioned about levels of Public Liability insurance cover - there are normally various levels of cover depending upon the level of risk and the loss that can be incurred - I was in the belief that NICEIC required up to £2M PL cover. Of course if a contractor were working in a large factory where losses can be higher then PL may need to be more. The potential losses under other works may be a lot less.
Just my own thoughts.
Thread: Bead blasting a chuck?
29/02/2012 19:16:13
Hi There,
How abouy dry ice blasting - leaves no residue as the dry ice goes through sublimation and evaporates to CO2.
An alternative is soda blasting - the soda can be washed off with water and simply disolves and leaves surface clean.
Many thanks,
Thread: Alpine Mill/Drill
26/02/2012 21:12:07
Hi There,
Could you machine up a solid bar to run up inside the minor ID of the open ended sleeve and cross drill it to accept a pin that can be inserted through the ejector MT3 slot. Insert the solid cross drilled bar and then the cross pin and locate against the back of the open ended socket. Then use either a sleeve/drawbar to pull out, or a simple sliding hammer and a few knocks might pull it out?
Thread: Colchester Bantam Lathe
21/02/2012 15:30:45
There was an article in a recent MEW about rebuilding and adjusting the saddle trip mechanism on a colchester lathe (cant remember if it was a student or a bantam) - might be worth a look.
Thread: Opus die filer
15/02/2012 22:01:43
Hi There,
I have a vague recollection of an article a few years back in MEW describing a strip/rebuild/usage of a die filer - it was a thiel machine. I checked a web index and it was in issue 37 page 14. This may be useful as a starting point.
Hope this is some use.
Many thanks,
ps there is also a series on building a die filer with some help on usage in MEW
Thread: Mig Welder Caught Fire
08/02/2012 18:37:32
Here is a UK supplier - bigger connectors but lower price and supplier in UK.
08/02/2012 18:34:57
Hi There,
I would either make it from tufnol sheet with a brass conductor passing through, or you could maybe get some paxolin board from an electrical wholesaler.
Alternatively a welding supplies supplier may have insulated bulkhead connectors that could pass through a welder panel. Another alternative is to fit your welder with two dinze sockets on the front panel that can accept dinze plugs on your welder leads - see an example at http://www.ebay.co.uk/itm/panel-socket-connector-10-25mm2-100-200A-1-PCS-/110553434766?pt=LH_DefaultDomain_3&hash=item19bd7f8a8e.
Hope this helps,
Thread: 3 Phase Tripping
04/02/2012 22:34:11
Sorry - I forgot to add - for test purposes only you could remove the earth connection from the inverter to see if that will permit the thing to run without tripping the RCD. I say this is purely for test purposes only. If it runs and doesnt trip the RCD then you know that there may be leakage currents being generated.
Lastly I know there can with some manufacturers be startup procedures to follow for inverters that havent been used in some time - this is so as to not cause damage to capacitors etc that havent been used in some time - eg 2 years+.
Thanks,
04/02/2012 22:22:05
Hi There,
I have had problems running inverters from an RCD protected supply - some inverters can "generate" earth leakages due to the electronic design internally, and this can be as much as 20mA. With other electronic devices in a domestic scenario (e.g.washing machines) also generating small currents to earth this can push the current to earth beyond the 30mA leakage current to earth that the RCD monitors and isolates supply in the event of levels above the limit. The 20mA value stated above was found in a siemens micromaster manual for an inverter I have, but other makes may be more or less. Siemens state only one inverter per RCD as the 30mA limit would not be adequate to run more than one inverter with each having leakage currents of 20mA or more.
This could be part of the problem. If you had a split load consumer unit you could feed the machine from an MCB or fused supply on the unprotected side of the consumer unit.
Hope this helps.
Thread: Soldering Hearth
10/01/2012 21:20:55
Hi There,
How about this stuff? I bought a sheet for replacing the firebricks in our woodburner - used the old stuff for soldering on.
Many thanks,
Thread: Storage of machine tools
02/01/2012 22:38:26
Hi,
A number of years ago I moved a few items of large workshop equipment - unfortunately the floor in the shed wasnt ready when the truck was moving the machines, so I sprayed everything (well the bright machined surfaces anyway) with aerosol waxoyl and the machines sat outside with just a canvas tarp covering from the weather. The only problem we had was that it was so cold the waxoyl wouldnt spray and we ended up letting the can sit in a jug of warm water for a while. It just wiped off with cloths when ready.
Thanks,
Thread: Lard Oil or it's modern day equvalent?
02/01/2012 10:25:55
Was Houghtolard a product from http://www.houghtonglobal.com/? I worked in a company who used houghton products extensively for metal cutting.
