Here is a list of all the postings heinz Immer has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford Super 7 power x-feed Apron reassembly problems |
07/09/2011 17:35:34 |
Hey K, due to extensive holidays it took quite a long time until I got into my Myford again. Finally I made it with your advises. Thank you very much again. Regards, Detlef |
25/07/2011 21:16:39 |
Hi K ! That is what I thought and tried. I`ll check the things you poined out. But thank you for acknowledging that. I´ll keep on trying. Regards, Detlef |
25/07/2011 16:54:28 |
Hello! I`m needing some help with reassembling my Myford Super7 apron. For cleaning purposees I disassembled the whole apron when one washer fell out somewhere. Most likely it was the one that sits on the stud gear cluster, between the bevel gear cluster and the apron housing itself. That´s what it looks like when compared with the picture in the manual. However, I don`t get it fit in there with the bevel pinion in it`s place or I do not get the bevel gear cluster in place with the washer together. If you go into my photos, I do point with the tip of the screwdriver on the mentioned washer. Is there anybody to give me a hint? Does the washer belong there and/or any suggestions why I don`t get in properly reassembled? Thank you! Regards, Detlef |
