Here is a list of all the postings Michael Horner has made in our forums. Click on a thread name to jump to the thread.
Thread: 'average model engineer' |
23/08/2014 08:48:42 |
This could be a Monty Python Sketch along the lines of the three Yorkshire men. I lad you used a file to make it fit, I used me teeth. Your not a proper Engineer.
Cheers Michael. |
Thread: Tangential lathe tool holder |
14/08/2014 19:50:37 |
Posted by Vic on 14/08/2014 12:59:22:
Thanks Norman! Couple more pics, how it started out: Clamp setup. Nice work Vic. I don't have that kind of artisic talent My version is a Mike Cox variant. For the clamp I have counter bored a hole similar to what you have done but pull a tapered wedge into the hole, a bit like a cotter pin on a push bike crank. I have only just made it so I don't if it clamps better than a traditional clamp, only time wll tell. Cheers Michael. |
Thread: Insert Image from album not working for me! |
14/08/2014 19:25:41 |
Posted by JasonB on 14/08/2014 07:33:02:
Try compatability view on your browser. You are only getting the top line of what should be a drop down box. Thanks Jason you were spot on. Compatability view was ticked. I think it's for my CAD package. Cheers Michael. |
14/08/2014 06:11:37 |
Posted by Ady1 on 14/08/2014 00:58:47:
How d' ya mean? Edited By Ady1 on 14/08/2014 00:59:41 Hi Ady The picture is what I get when I press the camera icon! I am sure it used to work. Bikini. What bikini? Cheers Michael. |
14/08/2014 00:17:06 |
Hi When trying to use a picture from my album to insert into thread it doesn't work. Used to. Anybody any suggestions? Cheers Michael |
Thread: What did you do today? (2014) |
12/08/2014 15:17:33 |
Didn't make the actual rear tool post just the sub table and riser block got the inspiration from here **LINK** It is certainly a lot more ridgid Cheers Michael |
Thread: Two short videos of a VFD in action |
12/08/2014 12:10:30 |
Posted by Russell Eberhardt on 11/08/2014 15:34:00:
Posted by Ian Phillips on 11/08/2014 09:59:56:
if the motor torque remains roughly constant through the speed range then at higher shaft speeds surely motor is producing a greater amount of power? That's correct. In other words if you run the motor slower you get less power. It's a bit of a simplification but a 1 hp motor running at half speed will only give about 1/2 hp. I have put 50% bigger motors on both my lathe and manual mill when fitting VFDs. The motor on the mill does get hot to the touch when cutting hard at low speed. If it gets too hot to keep my hand on I go more gently or have a cup of tea and let it cool down. Never notice a hot motor on the lathe. Russell. I have a Denford ORAC lathe which as far as I am aware has the original motor and VFD. When running it at 300 RPM for a while the motor got hot enough so that I couldn't hold my hand on it. I don't recall there being a smell of burning, I was concerned enough to put a fan to blow air over the casing. Cheers Michael. |
Thread: Not what you expect. |
09/08/2014 18:56:37 |
Posted by Chris Denton on 09/08/2014 18:50:34:
Link doesn't work? Worked for me. Took a while to load on my snailband. Cheers Michael. |
Thread: Carbide insert tools for lathes. |
07/08/2014 07:55:11 |
Posted by JC Uknz 1 on 07/08/2014 07:43:46:
This talk of tangential tools has lost me .. anyone got a link to a picture? Hi JC Have a look at the ads to the right of your post, up about 2.5 at the moment for Excentric Engineering . Cheers Michael |
Thread: needle roller bearings |
28/06/2014 17:48:27 |
Posted by John Stevenson on 28/06/2014 17:18:35:
You must have an old computer Jason
John What are those dotted lines at the bottom of the mag outline? |
Thread: Which drill chuck to use for a Sieg C2 lathe ? |
20/06/2014 07:49:55 |
Hi Brian !. The drawbar is typically for milling machines because the vibration of milling can unlock the taper. It just a big bolt that pulls the tapers together. 2. If you wind the tailstock back to its retracted position when you get to 0 the internal threaded bar SHOULD release the taper. there are different lengths of taper so can happen before 0, if a short taper it wont release. 3. Yes. HTH Cheers Michael. |
Thread: Victorian Whitworth nuts. |
09/06/2014 12:06:44 |
Posted by Ian S C on 08/06/2014 11:43:30:
I think you will find that the size of some nuts on some old machinery was made to fit the space by individual makers. The thing I have with nuts of this vintage is the square ones, people put them on up side down ie., flat side down, chamfer up, where as it should be the other way. Ian S C Hi Ian Is this something to do with the technology of the time. I.e. the side we are calling flat, wasn't. The side that was chamfered has been machined and so that was the side to use. All modern referance to square nuts I found shows the chamfer to the top. Cheers Michael. |
09/06/2014 00:42:49 |
Piqued my interest this one, so did some googling and found this link. It's JasonB and Bogstandard giving their input to making a steam model with square nuts! Another site I visited suggested that if the nut was going into wood the chamfer would be on the wood side. All modern stuff says chamfer to the outside H&S! To my mind a bolt would give the diffinative answer because it can only go one way round. One web site said in the days before my father was a twinkle in his fathers eye a black smith would make a square nut from bar stock by heating it to red heat and punching the middle out, didn't say how they got the threadding done but the dished side would be the clamping side and this would cause the square to bind stopping it comming loose. Ah armchair engineering at its best. I can go to bed happy now. Cheers Michael |
Thread: Arceurotrade Tailstock Turret |
08/06/2014 15:29:23 |
Hi Paul My wife bought me one for my birthday many moons ago. For the money I don't think the quality is bad. I notice on mine that it has six shiney grub screws to hold the tools in position. So looks like I have replaced them. They are not expensive. The other tools have ground surfaces and all fit together well. It comes in useful for drilling and tapping on the same part. HTH Cheers Michael. |
Thread: Mach 3 DRO question |
07/06/2014 23:28:38 |
Hi Richard Found this link on the Mach 3 website **LINK** Someone wanting to do the same. Not much to go on though. Les Jones may have a better idea he has done a lot of work on DRO's. He's on holiday till the 10/6. You may have to build and interface to match the output voltages and the encoding if any. There is a YADRO which does want you want but doesn't use Mach 3. HTH Cheers Michael |
Thread: what's the difference in taper, second and plug taps? |
01/06/2014 08:21:15 |
Hi David Your tap question has been answered.. To get the near interferance fit can you use a dowel? That is what I have seen in the car world to align housings. I have seen dowels with a hole in the centre for the bolt to pass through. HTH Cheers Michael. |
Thread: Rhombic Stirling Engine |
01/05/2014 21:16:05 |
Hi Ian I can't help with the mag search but you also were looking for ideas, have you seen the article by Andy Ross on making Stirling engines? Cheers Michael |
23/04/2014 20:01:16 |
Sorry about the misdirection Graeme. I remember reading what you wrote but could I find it afterwards! Cheers Michael. |
23/04/2014 19:27:53 |
Posted by wheeltapper on 23/04/2014 18:19:37:
Hi Going back to page 9 of this thread John Steveson describes a tailstock conversion. I am interested in doing this but I'm confused by the first picture. It shows the replacement block that fits on the end of the tailstock and I can see the brass clamp that locks the barrel BUT it appears to go right through the bottom fixing holes. Could someone please shed some light on this. thanks Roy.
Hi Roy I think that it goes through the counterbores so the screws will be infront of it. I am making the same for my minilathe. I am going to try the Bogstandard2 method which is to screw into the key. Cheers Michael |
Thread: Drill grinding jig design |
22/04/2014 18:35:59 |
Hi Rik Harold Hall wrote some words on using these jigs on his website. From what I can remember he thought they were ok but there were some key points to take note of. Cheers Michael. |
