Member postings for Philip D
Here is a list of all the postings Philip D has made in our forums. Click on a thread name to jump to the thread.
Thread: 1ph to 3ph Electrics
20/04/2018 20:57:46
Brian,
If you have 3phase to the house why run an inverter ???
Philip
Edited By Philip Devonport on 20/04/2018 20:59:23
Thread: Adding a DRO to my mill
01/11/2017 10:22:27
Richard, single phase motors ?? horizontal and vertical.
I too have one of these machines and fitting the DRO is the next job.
Be aware that the X axis fitted to the back of the table, ideally needs to be as shallow as possible so as not to lose travel. The Y axis is tricky to fit and the Z normally ends up on the column side.
There is a Yahoo group for Elliott owners **LINK**
A photo gallery which has quite few Omnimills fitted with DRO should help with design / fitment
Thread: Metric vs Imperial - Practical or Traditional?
28/08/2017 18:05:18
Posted by Terryd on 06/12/2010 21:58:40:
Hi Dino,
(Hope you don't mind the shortening but my typing gets tired at this time of night). I'd certainly agree with you on the very small sizes but there are suppliers on the continent who will post to the UK and seem to be cheaper than here.
I think that hex head screws and bolts are very specialised and in quite small production runs. Most very small stuff seems to be cross or torx heads. I just think that we have to grit our teeth and bear it like it or not. Actually I just looked at the Bruce Engineering catalogue on the Polly site and m1.2 (about 13BA) set screws x 12 mm long are quoted as around 15p each for scale hex head rolled thread screws. I didn't think that too bad. But they're not ht. The French supplier mentioned in another thread seem to have a good range of high spec screws at reasonable prices.
Terry
Which French supplier as i can't find anything by searching the forum ??
Thread: Disappearing companies
16/08/2017 19:05:08
A quote from an advert on homeworkshop posted 2 days ago... read into this what you will
Edited By Philip Devonport on 16/08/2017 19:05:32
Edited By Neil Wyatt on 17/08/2017 16:50:49
Thread: brass wanted
08/06/2017 18:23:23
Garry, where are you based ??
Thread: What web browser
24/01/2017 10:29:05
Clive India and others, can I suggest a free program called Ghostery which I use in Firefox, It works a dream and is easy to use if the odd website doesn't function you just pause it and reload the page.
Philip
Thread: Elliot Omnimil DRO's
18/01/2017 19:52:29
Nigel, would love to see some pics, my uncle owns one and mentioned the issue with the vertical head. I'd be interested to look at your increasing rigidity design.
Philip
18/01/2017 13:10:55
Thank you Mark, This really has helped me and I hope to be able to progress to fitment on my machine.
Mine is of the later design, the same as you used for milling the aluminium on, with the motor on the table. Two handles on the table ..luxury
Philip
Thread: Centec 2B Mill
15/01/2017 20:38:06
Hi Jay,
The motor that is on the machine now will forward and reverse it just needs suitable wiring. If you weren't using an inverter you would just have to wire it through a suitable switch, but the inverter will control speed as well as forward an reverse.
Edited By Philip Devonport on 15/01/2017 20:38:39
15/01/2017 13:05:38
Mark,
More pictures would be most welcome, thanks for the explanation. To be honest my machine was running perfectly well but with the strip down to move and the motors off, it seemed ludicrous not to tackle everything whilst it's in bits than doing it later. Painting wouldn't have come into it had it not been for this as well..
Philip
15/01/2017 12:47:00
Hi Mark,
Yes it was me that message you regarding the DRO, have you bonded that piece holding the front of the X axis ?(behind the knee handle). Currently on to sorting out the electrical side and have the base casting in primer.
I haven't got round to thinking out the DRO yet, but this will help
Philip
15/01/2017 12:32:45
With regards the Table motor, I recently got a Elliott Omnimill and paid a local motor rewinders to pull the star point. The cost per motor was £60 this including replacing the bearings, pulling the star point out and a re-varnish.
So I am not sure were you are located but this maybe a viable option, thus enabling you to run on inverters as planed.
Thread: Milling machine for 10-1/4 in. gauge
11/12/2015 12:55:39
Ralph, interested in your build. Just start to budget for patterns !!
