Member postings for Allan Plant 1
Here is a list of all the postings Allan Plant 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Viceroy 280 VS Inverter
27/11/2020 10:17:27
Can anyone tell me if the left hand part is likely to be a transformer 400v to 230v? I think it is but no labelling.
If it is I can sort the wiring easily but just worried in case it a voltage drop lower that 230v
thanks
Allan
27/11/2020 10:12:17
26/11/2020 22:07:54
Thanks Pete, I'll take some more photos tomorrow as for some reason I didn't take one of the other electrical relay type components
thanks
Allan
26/11/2020 22:03:15
20201126_211451.jpg20201126_211445.jpg20201126_211436.jpg20201126_211429.jpg20201126_211408.jpg
26/11/2020 21:53:32
Hi
I've swapped an IMO Jaguar CUB5A-1 from my old Viceroy lathe to this one, I bought the kit originally and really don't remember setting it up, in fact the company I bought it off may have supplied it set up with the pendant already fitted.
My question is how do I power the 3 phase board that works the other stuff on the lathe like the tacho, pump, E stop & safety switches etc.
Can it be wired somehow to the inverter or would I have to get another? I've taken some photos and will try to upload them
thanks in advance
Allan
Thread: Bridgeport Clone Spindle Bearings
22/02/2015 09:37:20
Thank you John
21/02/2015 23:36:57
Does anyone know how tight to do the bottom collet/ nut? the one with the grub screw, cheers
18/02/2015 09:33:44
I watched that video and a few more, the spindle was easy to remove but the Allen bolt which holds the top of the quill stop had to be removed which I had seen on another video as it was stopping the spindle coming out. also the big nut was left hand thread.
Once out I knocked the shaft through all the bearings and spacers together with a nylon hammer, came out easy but will be using the press to re-install.
Allan
17/02/2015 22:36:54
Thanks for your comments, I'll go with the SKF 7207 BEP's then, What grease should I use, might as well order some while I'm at it.
Allan
17/02/2015 18:05:50
Hi
I need to replace my spindle bearings on my Bridgeport (clone) mill, the bearings that have come out are SKF 7207 B, there's an A opposite, 72mm X 35mm X 17mm.
I've looked these up and there seems to be lots of different variations?
any help would be much appreciated.
many thanks
Allan
Thread: Duomo VM-20 (Bridgeport clone) power feed
12/02/2015 15:37:16
12/02/2015 15:36:59
Hi John & Neil
108 teeth for sure!
Wow, didn't expect the offer to make one, would love to see that on You Tube! I'm willing to pay obviously.
I don't have anything to measure the degree angle at work but have put marker pen on it and rolled it out, I will measure it later.
Thanks for all your help and comments
Allan
12/02/2015 09:27:29
I've spent some time looking at the Align gears and they seem to be 107 teeth and the hole is larger.
11/02/2015 17:12:16
Thanks for the rapid replies!
@Neil - it's the gears that have stripped
@Ted - I sent them over some details and gave a rough quote of £100 for a blank & £140 - £160 with milling.
I do have a dividing head that I bought from Axminster a few years ago but would have to study on how to use it and to work out what the pitch DP etc etc.
Allan
11/02/2015 17:06:04
Posted by John Stevenson on 11/02/2015 14:45:56:
Have you looked in the bottom of the cover as they often pack a spare gear there ?
Edited By John Stevenson on 11/02/2015 14:46:22
The covers were missing from the drives unfortunately.
11/02/2015 14:13:47
11/02/2015 14:07:18
The gear has stripped on the bottom of my power feed, are they available?
it's a Chuan Siang
Type 1000A
Date 1985
No. 5026
Fingers crossed!
