Member postings for Matthew Chapman 1
Here is a list of all the postings Matthew Chapman 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Part Time Machinist Employment Opportunity in the New Forrest
25/09/2017 13:14:45
Hello,
A good friend of mine works in the UK Space Industry R+D in the New Forrest area. He has need for a part time CNC Machine Tool operator to supervise machining of parts for rocket pumps and associated components.
As this would be only as and when required it would be perfectly suited for a local retired engineer. For those without CNC experience training will be given however what is crucial is significant machinist experience even if on manual tools.
Please let me know if you would be interested in learning more about this opportunity.
Matt
Thread: Moving a lathe
05/12/2011 18:26:40
Thanks all for your help, i carried out the operation on Saturday!
It all went well. I used a Leyland DAF HGV with 1000Kg tail lift and a simple palletiser. As I said before i could use the gantry crane where i bought the lathe from to lift it onto a pallet. Ratchet strapping the lathe to the pallet worked really well and increased stabilty.
Loading the lathe on the truck was a breeze with just two of us. Took some thinking of how to get the (suprisingly heavy) palletiser on the truck ahead of the lathe mind, as they wouldnt both fit on the tail lift together!
Getting the lathe out my end was the only nervous part of the operation. It took a bit of a push to get the palletiser + lathe over a small lip and onto the tail lift - the obvious danger being the momentum would take it over the edge! I used a couple of ropes around the lathe secured to the truck as fail safes.
The lathe is now in position in my garage... on a pallet! The M300 instruction manual says that the lips of the collant tray are also lifting points (with strops) so i will borrow some bottle jacks from work to act on the four corners to release the pallet and lower the lathe but am in no rush at the moment. Needs a good clean first!
Thanks again
Matt
27/11/2011 15:13:06
Well thank you all very much for your help!
I went up today to have a look and make a plan. They have a gantry crane so we easily put it on a pallet. The plan now is to palletise it on to a tail lift van and then use the palletier my end to manoever it into position.
Im not looking forward to the tail lift operation and i still need to figure out how to get it off the pallet!
Cheers
Matt
26/11/2011 21:20:11
Help!
I have aquired a Harrison M300 lathe at a good price for me. The seller can get it into a van but then im on my own getting it out my end, down a small incline, and into my garage! Having looked it up on the net i can see they weigh approx 650 kg!
Any advice? Im thinking of hiring an engine hoist or scissor palletiser?
Many thanks
Matt
Thread: Boiler tubes
30/03/2011 15:49:09
J,
Thanks very much, that contains a wealth of good information. Clearly it must not be a problem but i would have thought that the copper would expand more than the steel, unseat the tube and thus disturb the seal.
Thanks again,
Matt
30/03/2011 15:48:42
J,
Thanks again,
Matt
30/03/2011 14:45:24
Hello,
My question relates to fitting boiler tubes - I believe its possible to use copper tubes in an otherwise steel bolier? If so how would they be fitted? I have an excellent book by KN Harris and he mentions expanding the tubes but gives no further detail. Is this process simply flaring both ends to trap the tube? Wouldnt this type of joint leak in a copper tubed steel boiler due to different thermal expansion rates?
Many thanks in advance for your help.
Matt
