Member postings for Martin 100
Here is a list of all the postings Martin 100 has made in our forums. Click on a thread name to jump to the thread.
Thread: Magnetic base LED machine light - WARNING MAY BE UNSAFE
11/04/2016 14:28:23
The point I was making is you can very easily achieve isolation using injection moulded plastics with separate primary and secondary sections on an E-I core, whereas with the toroid isolation is only achieved through the use of very specitic deliberate actions and materials during the very complex winding process.
With a toroid the means of isolation are always without exception buried within the construction and are not suitable to later non destructive visual inspection, the exact opposite of a transformer with separated bobbin E-I construction.
The claim that a pair of toroid windings will somehow achieve better isolation than an E-I core is one I cannot agree with.
11/04/2016 10:56:54
Posted by Malcolm Parker-Lisberg on 10/04/2016 21:58:23:
As toroids are used for the majority of small inverter applications, for reasons you may or not be aware of, will have creapage and clearence distance greater than can be achieved with an iron cored transformer. But you also need good layout practises
With proper levels of design the type of core used is immaterial. An E-I design is inherently more tolerant of assembly issues than a toroid, there is really nothing to stop the former being assembled with nothing other than wire windings on each half of the bobbin and it fully meeting isolation requirements, whilst the latter must have a multi layer taping separating the windings to achieve any reasonable level of isolation.
Thread: James May and the telephone
06/04/2016 13:35:28
I've one of those screwdrivers somewhere and while I have used it I prefer magnetism or a blob of blutak or grease.
I was surprised he made no mention of the Post Office standard issue screwdrivers he used at one stage.
Phone dismantling articles here
and here
Thread: Another BBC4 series
29/03/2016 16:01:47
Apparently this is 'slow TV' BBC Four have shown many bits of 'slow TV' over the years, all of which have been excellent,  'Handmade' being the most recent
**LINK** (no episodes there but a few clips)
In my view just about every bit of telly and writing May has done over the years has been interesting. Can't see this been any different. It's a pity he's been lost to the BBC after this (or so I hear)
Edited By Martin 100 on 29/03/2016 16:02:29
Thread: Electronic Artisans ELS Article
28/03/2016 13:40:40
Posted by Ajohnw on 28/03/2016 11:45:39:
That chip with a label on it is almost bound to be a rom which suggests another micro. I also thought that these machines did have controlled spindle speeds. The usual DC speed controller works pretty well, even better with an encoder on it.
If it can work with one pulse per rev
On the Boxford TCL 160 (and maybe the 125?) it's more than one pulse per rev (32 minus one missing) and yes it is a processor on that board, a Z80 (or equivalent), can't recall if it's the lathe, the Boxford mill or even both that also have another processor on smaller board with an 8051 (or equivalent) for the turret changer on the lathe or the Z axis on the mill.
Boxford TCL 160 head assembly showing encoder disc.
Edited By Martin 100 on 28/03/2016 13:43:26
Thread: Model Engineer – Editorial direction
15/03/2016 12:38:56
Posted by John Stevenson on 15/03/2016 10:44:26:
Posted by Ady1 on 15/03/2016 10:36:57:
Actually, if you really think about it, what products have survived from 1898 and are still going today??
Not much
MARMITE
1902
I'm a professional engineer for mumble mumble decades in a totally unrelated field, but have had a workshop at my parents house and then at home for as long as I can remember (no, despite the alzheimers I don't mean 2 minutes ago)
I used to regularly read ME through most of the 1980's, MEW and EIM too. But 100 hours weeks, often working overseas, and lots of other distractions brought all magazine reading to an end in the early to mid 1990's after subscription copies were just piling up at home a few feet high still in their wraps. Many went in the bin or off to the local doctors surgery.
I still grab the odd copy of ME or MEW now and again, but it's not a regular purchase, most of my recent reads have been hand me down second hand ones a few months after publication.
I've produced monthly / quarterly newsletters in the past on another hobby, not much more than half a dozen pages and even with modern technology it's a mammoth task, even worse if you have to originate the content yourself. The idea of having to produce a magazine every two weeks, even with content provided by others fills me with dread.
Thread: Boxford Little Giant Toolpost Grinder Drive Belt Source?
15/03/2016 12:17:52
Many thanks for those. 1st link despite being a 'co.uk' is actually based in Austria! with a choice of 270 or 290mm, 2nd one based in the UK but with 300mm the shortest belt on offer.
With postage it's working out at around 8 quid a belt when buying five. I'm almost convinced a belt from a Dyson would be the right size, I have one somewhere!
13/03/2016 23:41:05
Boxford don't seem to list these on their website and being down to my last one that is more than a bit perished I wondered if anyone knew of a source for them (length 280mm, 10mm wide, maybe 1mm thick.
First thoughts were vacuum cleaner belts
Thread: 'Hacking' an inverter
07/03/2016 14:54:56
Posted by Michael Walters on 07/03/2016 14:05:21:
Maybe i've been a bit daft or something because i dont remember needing to enter current rating into my inverter, it only stipulates the frequency. I'm using an IMO idrive2 so maybe i've gotta flick back through that cryptic manual and see if i missed a setup step quite important and just willfully overlooked. perhaps i'm not getting what i should out of it because of my operational error
It may vary (I've personally not used IMO drives) but OMRON inverters drives for example have a parameter n036, Motor Rated Current, 0.0 to 999.9 "Set to the rated current from the nameplate." which in conjunction with parameter n037 and n038 is used for motor thermal overload protection.
Users Manual Here
Thread: steadies
07/03/2016 13:02:47
This difference in the thread form is what made a shedload of direct nose fitting ER32 chucks unusable. Despite being unfit for purpose that didn't stop someone who shall remain nameless selling them to UK customers for many many months.
Fortunately ER32 chucks from the likes of arceuro are easily fitted to a boxford backplate, a bit bulkier but not really a problem.
07/03/2016 10:21:44
There is also the possibility that the hardware could be totally identical to one with a larger output capability, but knobbled to a lower level by the firmware. It's often far easier to run one larger volume production line with the exact same bill of materials and just apply a different label and level of firmware before it exits the factory gates. Such an approach has become quite common in recent years with test equipment such as oscilloscopes.
Thread: Tubal Cain broke my taps...
06/03/2016 13:47:29
From the listing of his publications at https://en.wikipedia.org/wiki/Tom_Walshaw I'd guess I'd have the 1st or 2nd edition Model Engineers Handbook from 1981 or 1986, most likely the latter.
Nearly 30 years on one thing I recall is opening the parcel and not only receiving the book but also a huge number of die cut sticky corrections, possibly extending to two or three sheets of A5 that were sized to overlay dozens of printing errors.
I've certainly broken BA taps in the past, but I can't blame Tubal Cain as I usually used books & tables from Moore & Wright, Dormer, Presto or Starrett.
Edited By Martin 100 on 06/03/2016 13:48:27
Thread: books re castings.
02/03/2016 22:50:50
I've had "The Complete Handbook of Sand Casting" for many years and there are a couple in the 'workshop practice series' The Backyard Foundry and Foundrywork for the Amateur.
Thread: Boxford A gearbox rebuild advice
28/02/2016 20:08:32
half the teeth missing on the middle 16t gear (partno 292) on the intermediate shaft.
I can't see how to get the intermediat shaft out - does it just drive out from the headstock end? There's a central boss or bush on the intermediate shaft but it appears to be pinned with a blind pin rather than a removalble grub screw. (You can also see it in your photo Martin) . Any ideas?
http://www.boxford-software.com/spares/3656GearBoxEng.html
£54 from Boxford not sure about VAT or postage
Sorry I can't recall the dismantle process, last time mine was touched was about 5 years ago but it was relatively straightforward. A good degrease and wipe might reveal taper pins or grub screws. There is nothing silly like left hand threads etc and nothing more required than spanners, pin punches and a copper/hide mallet
I seem to recall a taper pin on the leadscrew but outside the confines of the box, but I could be wrong
A QC box is way better than changewheels for altering feed rates!
Edited By Martin 100 on 28/02/2016 20:13:43
Thread: Useless light bulbs.
28/02/2016 15:03:55
Mains halogens (GU10's) are very sensitive to failure with overvoltage. MTBF remains a matter of a few weeks regardless of supplier.
I know of four halogens in a bathroom that are 12v MR16 fed though an 'electronic' transformer aka switch mode power supply that are at least 15 years old and are still on the original lamps.
I've had a BC compact fluorescent that lasted maybe 40 ms before it went bang.
28/02/2016 14:33:37
Sounds like lack of lubrication or gummed up old oil on the gears top right hand side in the boxford drawing, or on the gears on the levers. The shaft 303 is held in place by a taper pin visible on the gearbox outer casing boss
It's significantly easier to work on than a bike or car gearbox, worst bit is refitting to the assembly to the lathe bed when two pairs of hands make it so much easier
Boxford parts drawing
Photo here showing the taper pin location http://modelengineeringnorge.weebly.com/uploads/2/2/8/6/22864734/8407460_orig.jpg
Edited By Martin 100 on 28/02/2016 14:47:29
Thread: Slip Gauges
27/02/2016 08:17:36
Posted by Michael Topping on 26/02/2016 18:48:59:
The most boring job I had as an apprentice was whilst working in the metrology department, checking slip gauges. It was all done in a temperature controlled room mostly using a comparator. I seem to remember
For flatness presumably with the use of these
https://en.wikipedia.org/wiki/Optical_flat
I find slip gauges useful but only for checking calibration or as big feeler gauges and never for packing purposes.
Edited By Martin 100 on 27/02/2016 08:19:49
Edited By Martin 100 on 27/02/2016 08:21:36
Thread: Which lathe?
18/02/2016 22:20:04
"Myford Super 7 (with gearbox and power cross feed), a Harrison M250/M300 or later at the right price and an equivalent Colchester."
A huge range there and no obvious reason why. If you have the space for anything bigger than a Myford then why wouldn't you choose it.
Many decades ago I was denigrated by a workmate for us choosing a Boxford rather than a Myford. At the time neither my father nor I could afford anything else. But the work that lathe took on over the years was way ahead of anything I could have ever ever handled on a Myford. A bigger lathe or a gapped bed that could have handled brake disc skimming would have been nice in the past but I can easily cope without.
After messing with changewheels for years I now find the gearbox I retrofitted essential, not for screwcutting but for quickly adjusting feedrates. Power longitudinal and cross feed is also a must have for me. Far better this doesn't have the potential to cause leadscrew wear as some implementations do (yes you Myford)
Another essential is a quick change toolpost (arc euro etc) . The 4 way toolpost that cost me a fortune back in the 1980's is really only fit for the bin. Horrible things designed by a masochist. The age of shimming tools long consigned to history. Same with the vertical milling attachment, for the Boxford it cost a lot of money, and it was used quite a bit for small jobs but it's never ever a substitute for a proper genuinely rigid milling machine.
So unless I was limited to a very tiny shed and model making a Myford in any form would never be on my list, the likes of the M250/300 would always be on the list.
Edited By Martin 100 on 18/02/2016 22:23:00
Edited By Martin 100 on 18/02/2016 22:27:06
Thread: Picking one UK show to attend..
15/02/2016 00:59:01
Posted by Ajohnw on 14/02/2016 16:28:48:
In order to visit Doncaster from London my immediate thought would be by train. It will cost more than fuel and may need a taxi but the time scales are likely to be both shorter and a lot more reliable. The location could be miles from Doncaster's actual centre. This means thinking about where transport links are but all UK cities get totally clogged up at some times in the day. That can involve rather a lot of time getting in or out of most of them. I'd guess it's the same in the USA, maybe worse in some.
Booked ahead (max of 12 weeks) it's just £17 single by train from London Kings Cross to Doncaster, 1 hour 30 mins for the fastest service, nearer 2 hours for the slowest. Then maybe £5 for the taxi to the Racecourse where the show is, just a mile and a half from the station or use online mapping / interrogate a local (who should be friendly!) and walk there. If you can follow the finger signs to the Mansion House (and it's on your right) just keep walking south until you get to a big roundabout, turn left and in a couple of hundred yards is the racecourse on your right hand side.
Doncaster to York for the National Railway Museum is less than 25 mins by train (£7 advance fare single)
Steam Train to Scarbrough on the coast is then another possibility
Or Coastliner 840 Bus from York to Pickering (£9 on the day single) for the southern terminus of the North York Moors railway to Whitby
For booking main line trains use virgineastcoast.com because it will be cheaper than other options. Tickets can be picked up by using your credit card in a ticket machine with the reservation number at Kings Cross.
Buying your train ticket on the day will cost about £70 single London - Doncaster
Edited By Martin 100 on 15/02/2016 01:00:24
Edited By Martin 100 on 15/02/2016 01:00:57
Thread: surface rust on lathe ways
15/02/2016 00:25:01
ACF50 (google it, it's available on ebay) sprayed everywhere in a thin film, or if you are hell bent on a shiny look, grey ultrafine scotchbrite and a very thin oil.
