Here is a list of all the postings David Howard has made in our forums. Click on a thread name to jump to the thread.
Thread: 9x20 Lathe Parts |
28/06/2017 03:09:49 |
Posted by David Howard on 27/06/2017 08:38:56:
Hi Alfie, ...Sorry, I don't know what model motor I used as it's hidden behind the lathe and hard to see, all I know is that it is a 550W three phase with the same shaft size as the original. I can't remember if I made a new mounting plate for it or just re-drilled the existing one. I will have a look when I go out to my shed tomorrow and see if I can get more details for you.
Alfie, I've taken a photo of the motor nameplate and a shot of my VFD and control switches, the big round button is an emergency stop. From the motor pic it definitely looks like I made a new mounting plate, but it was a no brainer. The VFD is an SEW Eurodrive, made in UK. I don't know how to add pics so I have put them up here: http://imgur.com/2yMaMIn and http://imgur.com/qy5AVWZ. Hope this helps. Cheers, Dave. |
27/06/2017 08:38:56 |
Posted by Alfie Peacock on 27/06/2017 02:50:55:
I have found this forum post from 2012 about the 9x20 lathe, I to have one of these lathes and would like to fit a VDF to mine. It is not straight forward as the original motor is not a standard fit. I to like David Howard at the time, would like to know if any members on the forum have fitted a VFD to a 9X20 lathe, and what VDF they used and motor. Hi Alfie, I fitted a three phase motor and a VFD to my 9X20 (in late 2012 I think), it works well - should have done it ages ago. VFD is a Movitrac LTE B 0.75kW (1HP) 200-240V. Sorry, I don't know what model motor I used as it's hidden behind the lathe and hard to see, all I know is that it is a 550W three phase with the same shaft size as the original. I can't remember if I made a new mounting plate for it or just re-drilled the existing one. I will have a look when I go out to my shed tomorrow and see if I can get more details for you. I bought the VFD and motor as a package from an electrical shop in Fyshwick, Canberra. I didn't have to modify the lathe in any way except for removing the old motor and all its switch gear, the VFD is controlled via an on/off two way switch (FWD/REV) together with a potentiometer for dialling up whatever speed you want and I also have two inching buttons fitted (FWD/REV again). It is programmable and I have it set so that I can switch to a preprogrammed low speed for screw cutting. Cheers, Dave.
16/04/2012 03:16:48 |
Posted by wotsit on 13/01/2012 20:20:58:
Despite my dislike of modding machines
![]() Hi Wotsit, I want to replace the stock motor on my 9 x 20, can you please let me know what motor and VFD you fitted to yours? Specifically, I need to know the motor specifications and make, and the VFD make and model. All I know about the stock motor is that it is a 550Watt, single phase, 240V, 1500RPM but I don't know what style of mounting foot it has (could be a B3 or a B3/B5?) and what diameter and length the shaft is. I can't take the motor off at the moment to check those details as the lathe is in store pending installation in my new shed when it's finished. I'm hoping to get a direct physical replacement so I can just bolt it straight on without any messing around. Did you have to modify the lathe motor pulley to fit the new motor? Did you retain the original gear train?
Many thanks, |
