Here is a list of all the postings Michael Gilligan has made in our forums. Click on a thread name to jump to the thread.
Thread: Modelmaking threatened in MEW in issue 189 :-( |
05/07/2012 07:12:58 |
Things change [and of course they should], but it's worth reading the Editorial in Issue_1 of MEW. ... The scope of the new magazine was specified there.
Personally, I would much prefer MEW to concentrate upon more demanding projects for the Workshop. The current "StepperHead" series is a superb example and [assuming there are no problems with Copyright], I would suggest a reprint of some Geo. H. Thomas articles. If there is a need for change then it would be better to "spin off" the simpler articles into a supplement [maybe published quarterly] which is a "give-away" with MEW: After a quick read, this could be passed-on to youngsters and newcomers; who would doubtless be encouraged to subscribe to MEW in due course. Striking the right balance in a "Technical Hobbyist" magazine like MEW must be an Editorial nightmare [keep up the good work, David]; but if you allow the core content to be diluted too much then you will lose the more experienced readers. MichaelG.
Thread: Milling Copper |
04/07/2012 08:27:57 |
Chris, "They are not cheap either !!" If you mean the Blades; the best ones [Vallorbe] seem to be about £4 per dozen, and the cheap ones about £4 per gross ... which seems pretty good to me. MichaelG. |
Thread: Open Source models |
04/07/2012 08:04:59 |
Please have a look at my recent post on the "Milling Copper" thread. Yes, I know that EDM WireCutting is probably the "right" approach, but ... MichaelG. Edited By Michael Gilligan on 04/07/2012 08:11:48 |
04/07/2012 07:31:03 |
Now ... there's a thought ... a CNC Piercing Saw !!! Maybe one for an "Open Source" Design Project , as proposed in another thread. Tricky, but by no means impossible. Most of the youngsters would probably expect to use a Cutting LASER, but there is so much very fine work that can be done with a Piercing Saw. [Clock Hands being an excellent example.] Is anyone up for this ?
Edited By Michael Gilligan on 04/07/2012 07:34:37 Edited By Michael Gilligan on 04/07/2012 07:41:27 Edited By Michael Gilligan on 04/07/2012 07:43:26 |
03/07/2012 22:54:47 |
Chris, This video on YouTube makes it look easy But he's using thicker material than yours
... you may need to stick it down to a sacrificial base [but then the sticky could clog the cutter] MichaelG.
P.S. This, from another forum, might help. Edited By Michael Gilligan on 03/07/2012 23:04:38 |
Thread: Wiring a single phase motor switch? |
03/07/2012 11:18:28 |
John, An excellent summary ... MichaelG. |
03/07/2012 10:15:18 |
James, The unit you have bought appears to be for use with a Motor Starter, not for direct connection to the motor. MichaelG. |
Thread: Shaper drive |
02/07/2012 21:33:52 |
Adrian, I can't help regarding the shaper itself; but I would recommend that you look at converting to Poly V belt drive. I have only used the small profiles myself, but the principle applies at all scales: ... Very efficient, and capable of handling large pulley-ratios. You may even be able to machine the grooves into your original flat-belt pulleys. MichaelG. |
Thread: Haimer Measurement Probes |
02/07/2012 07:45:35 |
These do look superb! It's interesting to see details of How it Works [Patent on Espacenet] Shame they don't make something much smaller ... My little BCA MkIII uses 11mm o/d collets. MichaelG.
01/07/2012 20:35:35 |
Hansrudolf, I think you will find the Z axis lets these probes work as a cost-effective substitute for one of these. i.e. for Metrology rather than Machine set-up I remember we had a massive CMM at Kodak in the late 1970s [probably one the first in the country], mostly used to check the plastic mouldings for the little cameras. MichaelG. |
Thread: Optical Encoders |
01/07/2012 20:19:07 |
Thanks for the comments The motors do look cheap; although the plastic gears are very well moulded, and I was delighted to find the micro-pitch belts and toothed pulleys [these seem very difficult to buy, and I need some]. What intrigued me was those Encoders [Strip and Disk] ... there must be somewhere we could re-use them. MichaelG. |
01/07/2012 16:08:08 |
I have just stripped down a Hewlet Packard 1350 All-in-One Printer/Scanner, for the "Useful Bits". To my surprise; there are no Stepper Motors in this device. Scanner Drive, Print-Head Positioning, and Paper Feed are all done with DC Motors. The Paper Feed has an Encoder Disk on the end, and the Print Head reads a Linear Encoder that runs the full width of the paper. ... Both of are printed transparencies ... I have not yet checked the resolution, but they are very fine. Both run through Slotted Encoders. The motors drive through a mix of plastc gears and micro-pitch toothed belts, and there the usual shafts and rollers to salvage. Definitely one to Recycle ... BUT "Caveat Dismantlor" there may be some ink residue inside; so don't wear light coloured Chinos. MichaelG.
Thread: Latest subscription gift for UK subscribers to Model Engineer |
01/07/2012 11:45:10 |
Posted by Richard Marks on 01/07/2012 09:30:26:
David Cant read the post, adverts all over it!
Richard, What Browser are you using? MichaelG. |
30/06/2012 22:16:22 |
Nice clarification, thanks David. On balance, I'm best sticking with my Direct Debit. ... Others may decide differently. MichaelG. |
30/06/2012 20:48:02 |
Reminds me of the recent T.V. advertisement "Brand New Customers Only" MichaelG. Edited By Michael Gilligan on 30/06/2012 20:50:48 Edited By Michael Gilligan on 30/06/2012 20:55:53 |
Thread: Solar Power for the Workshop |
30/06/2012 19:42:00 |
[that should probably read Orchard] MichaelG.
Thread: Not fit for purpose |
30/06/2012 13:29:36 |
Thanks John ... I was unaware of that. However,I still think it "proper" for the ME/MEW forum to host its own review of the drawings. MichaelG. |
30/06/2012 11:45:38 |
Thanks David, Much appreciated Provided you can keep posters "on-topic" ... I think that's a practical way forward. MichaelG.
Edited By Michael Gilligan on 30/06/2012 11:48:31 |
30/06/2012 10:17:54 |
Pete, Excellent comments ! However, in the absence of Errata from the Publisher ... perhaps this forum is the place to log all of those errors & omissions that builders find; together with their proposed fix. MichaelG.
[David Clark 1] Would you be prepared to create one thread for each of the available drawings? ... kept specifically for this purpose, and using the Drawing Number as its title.
Edited By Michael Gilligan on 30/06/2012 10:18:29 |
Thread: Digital edge finder |
30/06/2012 07:59:59 |
Ady 1, There is another Digitizing Probe, very nicely drawn-up by Shaun Wainford; available via Lester Caine's website. MichaelG. Edited By Michael Gilligan on 30/06/2012 08:12:27 |
