Member postings for Michael Gilligan
Here is a list of all the postings Michael Gilligan has made in our forums. Click on a thread name to jump to the thread.
Thread: Annoying Adverts
18/07/2012 21:11:37
David,
First; apologies for messing-up the shape of this page ... it wasn't intentional.
What I did [on that occasion only!] was to: Select and Copy the text from the other thread, then Paste it into this thread.
It evidently came across as html; and any spurious characters will have been carried over from the earlier post.
... As I mentioned last night that includes the width: 590px; that caused the problem.
Edited By Michael Gilligan on 18/07/2012 21:12:11
Thread: Mystery Slide
18/07/2012 08:50:23
Bob,
Do you think the stamped number looks like a Record part number, or is it just someone's own id mark?
... note that something has been obliterated, at the other side.
17/07/2012 23:56:54
O.K. folks ... I think I may have located the problem.
In editing my post of 23:03:00, I copied and pasted from the other thread.
If you look at the Source Code for THIS page, you will find that there is now one occurrence of
..... width: 590px;
That's what is now setting the width of the "table" that holds the messages.
"They" have changed the coding for the pages, but I have effectively overwritten the new design by pasting in a copy taken from the earlier page design.
Hope that makes sense ... it's bedtime.
17/07/2012 23:22:57
Fifer,
You can read David's first post because the lines of text are short !!
The "message box" still goes under the adverts.
17/07/2012 23:12:23
Sorry David ... our posts crossed in the æther !
If it's any help THIS thread is now displaying the problem [on iPad]
17/07/2012 23:03:00
There is something rather Spooky going on here.
I have just looked back at the forum link that I posted earlier ... it now displays correctly.
MichaelG. I see what has changed ... David has removed the long hyperlink that was causing the problem. I don't have relief on my saw and the blades seem to last forever!
There is a stop that you can set (carefully) so that the drop at the end of a cut is minimal. I also built a retractable pin to hold the saw in the position. There were some articles by Duplex many years ago - I think these went with the Duplex machine. There was also an article in MEW about some sort of damping device for a hacksaw. If you download the ME and MEW indexes Indexes you should be able to search for the articles that you want. They are Excel spreadsheets.
Edited By David Clark 1 on 18/07/2012 19:33:01
17/07/2012 22:44:22
Thanks both ...
Interesting possibilities.
17/07/2012 22:36:54
Posted by David Clark 1 on 17/07/2012 19:49:02:
Hi There
They use strict html and are very careful when they make changes.
What they can't control is the way people post.
regards David
Oh well ... I offered.
Edited By Michael Gilligan on 17/07/2012 22:55:29
17/07/2012 18:19:25
Posted by David Clark 1 on 17/07/2012 16:22:28:
Hi There
I think the fault is caused by overlong links or large photos.
Each link or photo is different which is why the variation if it shows or not.
regards David
David,
I am sure that you are right in your first comment; but I think the variation is down to poor "browser compatibility" in the html ... which is something your web-developers need to check.
There are many of us that are interested in this problem, so; why not let the developers make a few test postings ... we could then report on performance in different browsers.
iPad / iOS, Safari
MacBookPro / SnowLeopard, Safari
17/07/2012 15:05:31
David,
That's interesting !
17/07/2012 14:23:59
Just one point of pedantry ...
The size and position of the Adverts remains constant.
The problem is actually that the width of the Posting expands [going under the Adverts]
There is a good example here ... Scroll down the thread to see the problem.
17/07/2012 13:07:21
Please see Photo Album
I bought this at the Car Boot Sale
I know what is going to be but I don't know what it was.
The paint colour shouts "Record" and I suspect that it came from a Woodworker's Mortising Machine, but I would be grateful for confirmation [or alternative ideas].
Thread: Lathe ... Manufacturer unknown
17/07/2012 13:01:43
About 25 years ago, I bought this lathe from a friend ... He had given-up on the restoration.
Since then; it has lain at the back of my bench!
It is roughly the size of a Myford ML7 and, I suspect, was probably supplied as a part-machined kit ... some of the engineering is excellent, and some looks decidedly home-made.
The Headstock is unusual for a small lathe, in that it has an internally mounted Tumbler Reverse. Hopefully that will let someone identify it.
I do have a vague recollection of seeing a photo in an old Model Engineer, announcing its availability.
Most grateful for any advice
Thread: BANI Chuck
17/07/2012 09:30:11
Chris,
Does it also have independently adjustable jaws, like this?
... or is it the knurled-ring style?
P.S.
Have a look at this Gallery of Six-Jaw "Bezel Chucks"
... including one made by BANI, for Bergeon
Edited By Michael Gilligan on 17/07/2012 09:41:22
P.P.S.
Probably off-topic, but I just found this Maprox brochure
Aahh! ... those are sweet
Edited By Michael Gilligan on 17/07/2012 09:54:40
Thread: hacksaw blade mounting
17/07/2012 08:49:36
Posted by Michael Poole on 17/07/2012 07:30:53:
.... The most important thing I find with a hacksaw is the frame, I inherited a frame from my grandfather which is an old Eclipse pistol grip type with the frame made of solid flat bar, fitted with an all hard blade this is a pleasure to use ...
... As an apprentice I bought an eclipse pistol grip saw with a tubular frame, this is awful, the frame is not rigid enough and the blade seems able to twist too easily, almost no hope of cutting true and square.
Excellent point, Mike
I have a rather nice Sandvik frame that I bought nearly 40 years ago. The solid flat top bar makes a big difference. ... It also has pins to hold the blade at 45° in the frame, which can be very useful for awkward cuts.
17/07/2012 00:19:31
Fair comment, Sid
When I said "more energy efficient", I was thinking Ergonomics
... It's much easier to exert downward pressure and push, than downward pressure and pull.
16/07/2012 22:41:37
I suppose it's a matter of putting the "hack" into hacksaw.
The hacksaw is a rough & ready implement, and cutting on the forward stroke is more "energy efficient".
... Japanese pull-saws are, I agree, excellent for precision woodworking.
... Likewise, the Jeweller's Piercing Saw cuts on the downstroke [i.e. Pull].
If it works for you ... Do it.
Thread: How accurate is your lathe?
16/07/2012 08:31:35
Ray,
In a self-centering 3-Jaw Chuck ... that sounds fine.
If you want better, you will need either an inedependent 4-Jaw, or Collets.
Thread: How to cut tungsten carbide?
16/07/2012 08:26:53
Ian,
There is a useful discussion [circa 2010] on the Practical Machinist forum.
Thread: Note to self. Dont put thinners into Ultrasonic cleaner......
15/07/2012 14:48:40
Graham,
Walker Electronics advertise in the Horological Journal, and are well respected.
http://www.walkerelectronics.co.uk/
P.S.
Being a cheapskate, I have a couple of cheap units, and have never bought specialist cleaning fluids ['though, given Clive's recommendation, I might try Micro]. I usually put a few drops of "Alberto Balsam TeaTree Tingle" shampoo in the US bath. This wonder-fluid is about £1 for 400ml from the Supermarket.
I don't know if it's the surfactants or the herbal additives, but it works a treat.
Edited By Michael Gilligan on 15/07/2012 14:50:35
Edited By Michael Gilligan on 15/07/2012 14:52:22
