Member postings for Matt Harrington
Here is a list of all the postings Matt Harrington has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford DRO and Taper Turning attachment
20/01/2016 16:50:45
Thanks Brian. I'll give Newall a buzz tomorrow.
Kwil, I have just looked at the Micosyn product and it looks very neat! Will send you a PM
Rgds, Matt
20/01/2016 16:17:52
Can anyone point me in the right direction to achieve a suitable scale for the rear of the S7 that has the taper turning attachment fitted?
Anyone acheived it?
Thanks, Matt
Thread: Centre finder?
04/12/2015 17:24:38
I think I will make a collet and knurled closer similar to yours and see how we go.
Matt
04/12/2015 08:57:16
Thanks Gary,
In your centre finder is the pin fixed or does it slide along and the knurled part used to fix the pin in situ? I'm obviously missing parts here and I still cant see how the small attachments (stored in the body) are used on it.
Matt
01/12/2015 23:20:11
Thanks. Do you think the finger/needle is within some sort of collet? Interestingly the gimble is spring loaded in one direction.
Matt
01/12/2015 11:23:11
Hi,
I was given this tool the other day:
It is more than likely a centre finder (?) but does anyone have a similar tool and able to tell me what bits are missing? (It is made by J Whitworth & Co)
(There are a few more photos in an album I have just created)
Matt
Thread: Myford Motor Swarf Guard
06/11/2015 10:46:24
Bandersnatch, that is an elegant solution - two guards in one!
Norman, where to buy those bits? Myfords?
Thanks guys, I'll probably go off and buy some ally sheet.....
Matt
05/11/2015 17:12:38
sad I was hoping to lavish something on the lathe......
05/11/2015 16:39:27
The time has come to replace the modified saucepan that protects the motor on my S7 ! Whilst it is functional, it is not very attractive and is now rattling like mad.
Does anyone have an alternative suggestion?
Matt
Thread: Screw cutting Advice
05/11/2015 12:32:04
James,
I have found that using the threading tool in this set : **LINK** gives me an excellent finish - My one wasn't in this set but it looks identical. It is a preformed v tool (HSS) and saves any grinding! THese even worked really well on stainless steel. I also use Dormer Super Cut asa lubricant - its thick and sticky and stays on the thread well.
Matt
Thread: modifying Schaublin collets
17/09/2014 12:13:48
Have a look here:
https://www.youtube.com/watch?v=6WSAZtphQc4
I bought one from a famous auction site for £15 and have found it useful for the sort of job you want to do on hardened steel.
Matt
08/09/2014 12:16:31
You will probably have to grind the keyway as they are hardnened. A pencil air grinder with a suitable wheel is chaeap and effective for this.
Matt
