Member postings for Andrew Johnston
Thread: Measuring Gears (including pressure angle)
22/06/2020 09:14:10
Posted by Alan Charleston on 22/06/2020 07:36:31:
I'm not sure how to measure the span across the flanks.
Use a disc micrometer.
The underlying maths is simple. The disc micrometer will measure the distance across the teeth, but not on the pitch circle diameter. By varying the number of teeth the exact point of measurement will vary. The thickness of a tooth, away from the pitch circle diameter, is determined by the pressure angle. So by comparing the results to the theoretical values the pressure angle can be determined.
Thread: Digital angle gauges
22/06/2020 09:02:59
I have a clone angle gauge - works fine and the battery lasts for ages. I've had to repair it once to fix the 'click' mechanism that angles the display. It's ok for rough work, like bending the spokes for my traction engines or setting the angle plate for basic work. If I need better accuracy I've got a Taylor Hobson clinometer.
I've just finished machining the valve chests on my traction engine cylinders. The cylinder was bolted to an angle plate, but there is no reference surface to set the valve chest face parallel to the table. I used the digital angle gauge to set zero on the face, relative to the table, and then indicated in X and Y with a DTI to eliminate the last few thou of error.
Thread: Curiosity Tap and Die
20/06/2020 23:01:06
Both BSP and BSF threads are Whitworth, so 55 degrees.
Thread: machining acetal
19/06/2020 16:41:20
Acetal machines beautifully; use low speeds and high feedrates or it'll melt. What do you mean by accurate, 1mm, 0,1, 0.01mm?
Thread: NPT27
17/06/2020 16:14:11
I've never cut an external NPT thread but have tapped them. As you'd expect the tap quickly gets more difficult, followed by impossible, to turn. The tapping drill tends to be slightly larger than one might expect. I expect a die would be similar. I'm not sure if a taper on an external item would work. The die will go on further before it cuts, but I suspect it'll come to a halt more quickly. So possibly not much gain.
This is how I cut external tapered threads:
I was screwcutting BSPT threads but I think they're the same taper as NPT. I thought NPT threads were specified by a nominal imperial dimension representing the pipe size rather than tpi?
Thread: Stuart 10V Build Log - Complete Beginner...
17/06/2020 11:08:54
Posted by Dr_GMJN on 17/06/2020 10:17:51:
Not sure of the best way to find the centre of the cylinder bore............
Osborne's maneuver as detailed in "The Machinist's Second Bedside Reader" by Guy Lautard. Or just pick up on each side of the circle in X and then Y and use the 1/2 function on the DRO at each step to get the centre. Once at the centre a sanity check is to touch off plus and minus X and Y; the readings should be the same. Or, for the lazy, you can use a co-axial indiccator:
Thread: Mild Steel Rod in Metric Sizes
16/06/2020 22:34:32
Posted by larry phelan 1 on 16/06/2020 18:40:38:
I suspect Andrew has a van with a roof rack.
Glider trailer!
I can get a 3m length in the car without a problem. The 6m lengths of aluminium were always delivered. For 6m lengths of hot rolled steel it depends on size. If I can lift the 6m length then I have it delivered. If I can't then I'll ask for it to be sawn into thirds or quarters so I then have the option of delivery or collection. Same goes for plate. When I ordered a 2m x 1m sheet of 6mm steel I asked the supplier to guillotine it in half.
Thread: What Did You Do Today 2020
16/06/2020 22:27:47
Been working on the cylinder castings. The regulator recesses are done:
Also the valve and regulator packing gland locations and the bores started:
Both bores are undersize by about an 1/8" and only go an inch deep. In due course I'll use the machined part of the bores to pick up the locations on the horizontal mill and use the Wohlhaupter boring head to bring the bores to size. The Bridgeport quill movement isn't big enough to machine the complete bore.
I know the centre to centre distance of the bores from the drawings and my 3D CAD model. As a sanity check I measured the bores as they are now and also measured the width of the web between the bores. Adding half the measured bore diameters to the measured web agrees with the theoretical centre to centre distance to 2 tenths of a thou. I don't believe that for a moment! It's not easy to get an accurate reading with an internal micrometer and likewise the vernier calipers used to measure the web. However, if I'm within a couple of thou I'll be happy.
16/06/2020 14:13:00
Posted by Dr_GMJN on 16/06/2020 11:46:15:
....how do you make the bush?
Simples!
Turn the spigot to the wanted diameter and length. If I'm going to be facing I leave the spigot slightly short of the work. Drill and tap the hole. Ideally use a taper tap and only go in a few turns. You only need a couple of full threads and then the thread needs to taper off. So when the screw is inserted it binds and forces the spigot apart. Slit the spigot with a hacksaw. Clean up the saw lines with a needle file. Job done.
Thread: Best places to buy metal for machining
16/06/2020 14:04:26
I use Parkersteel for basic steels. Although they have an outlet near Cambridge the head office is in Canterbury. However, they have got a bit silly on delivery charges recently.
16/06/2020 14:01:10
If buying from commercial stockholders it's often cheaper to buy the standard length; 3m for steel and 6m for alumiumium. For small sections, less than ~25mm diameter, that's what I do. Over time you build up a good stock of basic steel and alumimium.
16/06/2020 11:30:16
Posted by MC Black 2 on 15/06/2020 00:37:50:
The nearest metal supplier is Mackay at Cambridge.
I bought my first batch of steel from Mackay's after getting my lathe and mill - never again. I had all sorts of problems getting a consistent finish when turning. Eventually I asked a commercial machine shop (that I was using for work) where they bought their metal. They told me and commented they didn't use Mackay's as their steel was carp. I bought from their recommendation and immediately got a lovely turned finish.
I buy from a variety of sources, but mostly Parkersteel and M-Machine.
16/06/2020 11:20:03
A split bush is easier, and quicker, to make than a tapered arbor for holding work:
The split bush shown was used to face the gland to length, turn the boss to diameter and face the back of the flange. Width of the flange and height of the boss are parallel to better than 0.02mm. A split boss can also provide a high clamping force. Here's one being used to cut a 6DP gear in EN24:
6DP Pinion Gear
Thread: 3 Phase in a Model Engineers workshop
16/06/2020 11:10:07
Posted by Phil Whitley on 16/06/2020 09:38:41:
what is the HP of the mill motor and the lathe motor?
RTFP!
Thread: ER32 COLLET SETS
15/06/2020 20:09:35
Posted by JasonB on 15/06/2020 13:08:08:
I doubt many of the sizes are that close to what was on the drawing but I do know it will work...........
Which is precisely the point I was making.
15/06/2020 20:04:42
Out of idle curiosity I thought I'd measure the variation in width on my two recently squared up cylinders. Taking three points on each, one has a maximum variation of 0.1mm and the other is 0.05mm. Of course the variation doesn't matter. What is critical is that the bore is perpendicular to the face that controls piston alignment. What the other face, which is just a cover, does isn't important.
15/06/2020 12:37:50
Posted by SillyOldDuffer on 15/06/2020 12:21:07:
Bear in mind that the old guys did excellent work on worn or indifferent machines without calibrated dials & micrometers.
It would be interesting to know if anyone has actually measured an older model to see how accurate it is, as opposed to parts made to fit.
Thread: R8 or morse taper 3?
15/06/2020 10:45:08
Posted by not done it yet on 15/06/2020 09:48:09:
.............or get a larger machine.
Done. thumbs up
14/06/2020 22:30:16
Posted by DiogenesII on 14/06/2020 21:52:04:
..what degree of tool height repeatability is available with R8?
Depends on how you hold the cutter. In a Clarkson lookalike chuck on my CNC mill I reckon better than a thou. When the Tormach CNC mill came out there was some work done on this (on CNCZone I think) which came to the same conclusion. In a R8 finger collet I've no idea as I rarely use them. But since they're not dead length collets I suspect that repeatability would be poor.
Thread: WM16 cutting conundrum
14/06/2020 22:19:24
Posted by ron vale 1 on 14/06/2020 20:57:19:
.......a four flute end mill brand new from Tracy Tools........
I've bought from them in the past, but no longer do so. Make of that what you will.
Why two DTIs? I only use one and just run it down the back of the fixed jaw tapping the vice until there is no movement as the table moves.
