Member postings for Andrew Johnston
Thread: why does my makita go pop occasionally ?
16/01/2020 16:10:33
Posted by Maurice Taylor on 16/01/2020 15:28:42:
I wouldn’t worry about interference............
Depends upon the type of motor. A brushed DC motor is quite likely to be way noisier than a switch-mode PSU on a PCB.
Was the trip over-current or earth leakage?
Electrolytic capacitors are reknowned for swelling before failure. But I've not seen the same with other types of capacitor. Normally one would expect to see an X-rated capacitor across the supply and Y-rated capacitors from live and neutral to earth. If the equipment is double-insulated then there is no earth and no need for the Y capacitors. Both X and Y capacitors are metallised film and are self-healing as a short circuit failure is unacceptable. If the film is punctured the local metal film is designed to evaporate, removing the short circuit.
A picture would help identify the components, and possibly the problem.
Thread: Drilling holes using pillar drill - work wobbling
16/01/2020 12:58:14
Now you''ve got a man sized drilling machine just drill 8mm and be done with it.
Thread: Hobbymat MD65 - help figuring out accessories (photos)
15/01/2020 10:52:09
Any industrial tool stockist should have, or be able to get, keys for Jacobs chucks. Here's a link to the manufacturers technical page:
The stockists they list are in the US, but plenty of UK stockists for chucks and keys. I'd be suprised if the same wasn't true for Europe.
Thread: rolling brass strip in the lathe
15/01/2020 09:21:53
Posted by Clive Brown 1 on 15/01/2020 08:54:38:
GHT addressed this issue with his design in ME using pinch rollers. This much reduced this effect.
You get the same flat, but only on one end. So the work needs to be swapped end for end on each pass.
Thread: VFD Question
14/01/2020 20:11:05
Mark: Thanks for the explanation.
Gerald: It should run fine in star. If you look at your diagram in high speed mode wires 4, 5 and 6 are connected together, but they don't go anywhere. You don't need a neutral line to run a motor in star. In theory the current in a neutral wire would be zero.
Thread: Face Mill for lathe
14/01/2020 20:00:23
Good grief, that's going to be flexible. I don't think you need worry about spindle loads, any sort of cut and you may well get more chatter than an Islington luvvie. And there was me worrying about whether a 50mm face mill would be too big for a Bridgeport.
Thread: Bottled Gas Suppliers
14/01/2020 15:31:54
Thanks for the additional information. I read somewhere that oxy-propane isn't great for brazing, but can't remember where. Superficially one would have thought it would be fine, as the temperature is much lower than needed for welding.
Much to my surprise the Air Liquide lorry turned up at lunchtime with my refill bottles. Unfortunately I was so surprised I injured myself falling off the chair! Naturally the delivery was a foul up. One, the delivery price was not what I thought I was paying and two, he seemed surprised that there were two bottles to collect. He was pleasant though. Said he'd delivered to me before. Quite possible as when I bought my DC/AC TIG welder I had the argon bottle delivered, as it is too large and heavy for me to lift. But that must have been 10 years ago. He also said I'd be better off with Albee bottles as I'd own them and there's no delivery charge. I mentioned the regulations and the fact that I'm a hobbyist and he agreed I am exempt, but said it was company policy not to allow pickup. He related a story of someone turning up at the shop with a trailer full of propane and acetylene bottles all rolling around in the bottom of the trailer. It's idiots like that causing the blanket ban on collection.
14/01/2020 15:15:30
Posted by john fletcher 1 on 14/01/2020 14:16:07:
........with POLE changing switching to give the two speeds,and NOT Star/ Delta.
Clearly the switch is changing the number of poles. But if that's all it's doing why aren't the low/high powers also in the ratio 2:1?
14/01/2020 14:11:52
Posted by Gerard O'Toole on 14/01/2020 13:06:17:
My motor, which is the original motor fitted, is marked Siemans-Shuckert , 380V, 2.7/2.8 A, 0.8/1.1kW, cos ó 0.64/0.8, 700/1420 U/min
There is a switch to switch it from low speed to high speed. This switches it from Star to delta ( or Delta to Star - I will have to check)
It may be switching from star to delta, but is also pole switching from 4 to 8. The key is the last part of the plate:
700/1420 U/min
In other words 700 and 1420 rpm in low and high speed respectively.
Thread: Bending brass
14/01/2020 13:58:43
I expect the original was cast. The angles look far too tight for the thickness of material to be bends, and the thickness of the material seems to vary a lot.
Thread: PM Notification Issue
13/01/2020 16:20:10
Not my end; my operating system is no longer supported. So definitely no updates I didn't know about. I'm normally logged out, and only login when I want to make a post or read a PM. I don't have a 'spam' folder. Thanks for looking anyway.
13/01/2020 14:44:01
For ages I've been getting an email to say I have a PM. In the last few days the emails seem to have stopped, even though I have PMs waiting. I've checked that I still have the notification box checked. Also unchecked, saved, checked and saved again. It still doesn't work. What gives? Smacks of an IT 'upgrade' to me!
13/01/2020 14:39:37
RUN IT AT 50Hz - IT WILL BE FINE!
I've just had a quick look at the link again. Got as far as the first paragraph where it says motor speed is dependent upon voltage and frequency. No point in reading any further.
Thread: What Did You Do Today 2020
13/01/2020 13:35:45
Posted by SillyOldDuffer on 13/01/2020 13:26:45:
There's no value in mourning spilt milk............
Unless you're machining copper. smile
Thread: magic 127 TOOTH ?
13/01/2020 12:01:22
Posted by Gerard O'Toole on 13/01/2020 11:04:11:
Are the TPI on it based on a longer inch? i.e. the pitch is slightly longer?
Possibly, in theory. But in practise the standards used in the factories would have been orders of magnitude less accurate than the variations in the definition of the inch.
13/01/2020 11:50:54
Posted by SillyOldDuffer on 13/01/2020 09:57:05:
A typical wall-wart contains a switch-mode power supply. These oscillate at several tens of kHz
I would think that they're up in the 100s of kHz these days. Even 100kHz is so passé. smile
Low power DC-DC buck and boost converters are up to the low MHz, and use inductors rather than transformers. An offline switcher may need a transformer depending upon isolation requirements. Inductors are preferred as they're small and surface mount and don't need fancy formers for the windings. Higher power converters that need bridges tend to use transformer based designs, although the transformer windings can be part of the PCB.
I don't know what a 240V in, 415V out VFD uses to boost voltage. But given that more expensive VFDs probably incorporate a power factor corrector at the front end rather than a simple rectifier it would be simple to use the PFC to generate the higher voltage needed for the DC link. A PFC is basically a boost converter. There are two big cost impacts caused by the higher DC link voltage. The bridge transistors and DC link capacitors need to have much higher voltage ratings.
Thread: vice thread efficiency
12/01/2020 19:27:26
The manufacturers data for my machine vice shows that the clamping force (lbs) is very roughly 90 times the torque (ft-lbs).
12/01/2020 15:39:52
The Air Liquide (AL) saga continues. Naturally no delivery by late Friday afternoon. So I called AL customer service and explained the situation to a very pleasant lady, who commiserated. She must have called the agent because she said delivery would be next Tuesday. I explained that while that is sort of ok for me any sort of commercial welding outfit would be mighty pissed. Also said that I was pissed because I didn't know when, which makes it impossible to plan activities. It's a real waste of time if you're expecting a delivery and have to wait in. Even nipping out for 10 minutes could be a disaster. My number one rule in these situations is to be polite, but be a polite PITA to the extent they realise you're not going to fobbed off. Then it's easier for them to sort the issue rather than woffle! The issues have been sent to the sales manager and, in theory, he's going to call me to discuss service and delivery pricing. I also said they were wrong on the ADR regulations as I was a private individual using gas for leisure activities. She said she'd contact the AL safety group for comment. I don't suppose I'll win the battle, but at least I've raised the issue.
After a bit of confusion over dates I confirmed that my rental agreement ends on the 31st of October 2020. So I've got time to look around elsewhere. I've got a lot sheetmetal flanging and welding to do on my engines so I aim to get on with it so I can refill bottles while I've still got a current agreement.
Roll on Tuesday!
12/01/2020 15:01:45
DD is correct, it's a hydraulic copy unit. The tool on the back of the cross-slide is driven by a double acting piston. The T-shaped extension below the tool slide carries a stylus that replicates the shape of the tool. Through a series of valves and channels the tiniest movement of the stylus unbalances the piston so that the tool slide moves until the pressure on both sides of the piston is equalised. The effective gain is high so there's almost no error in following the path. The movement of the tool in and out is controlled purely by the template. The axial movement is controlled purely by the lathe feed mechanism. The slide is at an angle to the work so that at the end it can move perpendicular to the work. If the slide was perpendicular the feedrate would need to be infinite.
The shape and, to some extent, surface finish is determined by the quality of the template. Although my template is filed as I don't need great accuracy it would be surprising if I'd got a small ridge almost exactly every 5mm. Especially as I finished by draw filing in short lengths.
I've used the unit on other parts and not seen the same effect, albeit the parts were much shorter.
The mystery remains unsolved.
12/01/2020 14:49:26
Posted by Michael Gilligan on 12/01/2020 11:06:23:
Have you considered the possibility that the gear driving the slotted shaft is slightly eccentric ?
In a word 'no', but I haven't seen the effect before, either sliding or facing.
