Member postings for Robert Butler
Here is a list of all the postings Robert Butler has made in our forums. Click on a thread name to jump to the thread.
Thread: Readers Tips for MEW
03/11/2022 22:11:12
Posted by Neil Wyatt on 03/11/2022 17:15:23:
Corrected now, I used the old text by mistake...
Still mistyyped.
Robert Butler
Thread: Help needed with stiff Pratt Burnerd 3 jaw chuck.
03/11/2022 22:05:11
The OP refers to attempting fitment " and without the scroll in place".
Robert B utler
03/11/2022 21:38:14
Not sure Ultrasonic Cleaning would be my first choice. Paraffin, stiff brush and lollipop stick would be first choice.
Robert Butler
03/11/2022 13:04:09
A tyypographical error!
Robert Butler
Thread: Chester Super Lux advice
02/11/2022 09:18:55
Taf - Z Axis?
Robert Butler
Thread: Test dial brand query
01/11/2022 22:51:27
Not Moore & Wright,Mercer or Mitutoyo
Robert Butler
Thread: Removing and dismantling a Myford 254S apron - advice?
01/11/2022 22:44:01
Dave if you have managed to download the complete Myford handbook I doubt much else exists. The Handbooks were usually well written but not quite "workshop manual" material. If you have a specific query someone on the forum will be able to help. 254's not endlessly disected in the same manner as the 7 series (an observation not a complaint).
Robert Butler
01/11/2022 22:31:57
Julius, I wouldn't get too excited, stylus and screw marked/rusty no guarantee it hasn't been round the block several times. Not necessarily ruinously expensive to purchase new.
Robert Butler
Edited By Robert Butler on 01/11/2022 22:34:17
01/11/2022 21:41:10
Dave try Googling Myford 254 Handbook, www.lathes @ £48-00 but there are other sources.
Robert Butler
01/11/2022 18:29:53
Posted by larry phelan 1 on 01/11/2022 12:46:05:
Hi Robert,
Yes, I think you are right about those screws, so I just put everything back together again. Still have a little tightness in the quill, but I,ll live with it. That return spring takes some effort to rewind, while just waiting to chop your fingers off ! I ended up making a clamp with a handle to wind it back. Works great, no more cut fingers.
All in all, it was time well spent, I now know the machine a lot better.
Regards and keep well.
Larry, not sure if you have discovered the lubrication point at the rear of the quill in the gearbox casting. On my mill you have to remove the guard, microswitch linkage and a blanking panel you will then find a hole through which to squirt oil.
Robert
31/10/2022 22:25:02
Posted by larry phelan 1 on 31/10/2022 14:39:03:
When I had a problem with my Lux Mill some time ago [still never solved it ], I received great help from Robart Butler, but strange to say, no one else seemed to have anything to offer. [ Thanks Robert ]
That manual mentioned by Robert is well worth downloading, the Chester one is useless.
Larry thank you for enhancing my reputation!! My view regarding the spare screws remains the same. Clearly they could not escape from the gearbox and therefore maybe left by an absent minded operator or fitter at Chester or the manufacturers.
Robert Butler
30/10/2022 23:22:08
Taf I have a link to a complete strip and rebuild of the head and hearbox, not that you will need it for this issue, but I printed it off for future reberence and you may care to do the same.
I fitted the DRO reader to the quill and this takes up little space and connects direstly to the three axis DRO screen. I used linear bearings to mount the reader and have some rough drawings which may be helpful. I can never manage to upload anything on to this site so if you send me a PM with your email address I can email them to you directly.
Robert
30/10/2022 22:33:33
Taf I have a Super Lux and find it acceptable in most instances.
I fitted a Chester power feed which makes life easier and produces a better finish. Gibs, are the adjuster screw heads engaged in the slots correctly. Is there any crud under the table or dovetails? I have read somewhere that the Gibs can distort which can also cause the symptoms you describe, the cure was to machine the bow out of the strips.
The Gibs or crud may also produce the tramming error in spite of the weight of the table so perhaps investigate first which will hopefully leave the column undisturbed.
I found the backlash in X,Y and Z axis a bit irritating and whilst it is possible to adjust X and Y there is no provision for adjusting the Z Axes. I therefore fitted a Machine DRO covering all three axes, with the reader fitted to the quill. This has improved the functionality and accuracy of operation and as i tinker in metric and Imperial units a useful bonus. If you would like images of the Z axis installation send me a PM
Download the Grizzly manual far better than the Chester version.
Robert Butler
Edited By Robert Butler on 30/10/2022 22:34:30
Edited By Robert Butler on 30/10/2022 22:36:12
Thread: Casting and machining motorcycle risers
29/10/2022 18:37:49
Uncomfortable if you come off without gloves, ask me how I know.
Robert Butler
Edited By Robert Butler on 29/10/2022 18:38:11
Thread: Unknown tools
12/10/2022 14:51:29
Thanks Jason, Buffers query has been dealt with.
Robert Butler
12/10/2022 11:29:39
Posted by Grotto on 11/12/2018 21:54:14:
Louis Eichmann (2 n's) lists woodworking toos etc.
Robert Butler
12/10/2022 11:23:52
Posted by Buffer on 12/10/2022 11:15:36:
Hi, does anyone know what these unknown tools are for. We have been given a box of them at the club. They seem to say Lushington 1175 on them. Thanks.
Machinists Jacks
Robert Butler
Thread: Back gear cluster replace
02/10/2022 11:24:04
Posted by Pete Rimmer on 02/10/2022 10:13:49:
Posted by SillyOldDuffer on 02/10/2022 10:09:27:
Your second point is totally incorrect Dave. Firstly, it would only cause a skip if there were no other teeth engaged which you'd need to be missing several in a row for that to happen. Secondly, the back gear is only a mechanism for slowing the spindle. It has no effect on the threading ratios which are all done on the end gears and gearbox if fitted.
? Surely the drive for the gearbox comes from the headstock which in backgear operates at a reduced speed otherwise the headstock rpm would make a nonsense of the gearbox output rpm??? for screwcutting???
RobertButler
Thread: Lux milling machine
30/09/2022 14:00:50
Larry I have sent you a PM with my email address as it is as difficult to upload images as to post on the forumn. If you respond I can just upload the images and forward them to you directly.
Robert Butler
Edited By Robert Butler on 30/09/2022 14:01:01
29/09/2022 17:36:22
My cover is securred by two cap head screws which engage in key-slots in the plastic cover to hold it in place. I wonder if the cap is non original and the screws either vibrated out or are a red-herring. I can't see how screws can have exited from the gearbox.
Are there any vacant threaded holes in the gearbox top cover around the spindle? Did you buy the machine new or used? If you would like an image of my machine and also of the Z axis DRO, send me a PM as I can't be bothered with uploading images on to the site.
Robert
Edited By Robert Butler on 29/09/2022 17:38:11
