Member postings for Brian Oldford
Here is a list of all the postings Brian Oldford has made in our forums. Click on a thread name to jump to the thread.
Thread: Loco hand pump casting from Reeves
21/05/2019 15:56:09
IIRC LBSC's tender hand pumps tended to rely on nothing more that a few turns of graphite rope in a groove near the inner end of the ram. Simple but effective.
Thread: Casting brass
21/05/2019 15:43:03
A risk associated with the casting of brass is the possibility of over-heating the melt and evaporating the zinc content. Even as a semi-retired pattern-maker it took me quite some time to find a non-ferrous foundry that would take on small volumes. Please feel free to PM me.
Brian
Thread: Door knob collar
16/05/2019 14:13:06
Posted by Ian S C on 16/05/2019 12:45:08:
Get them cast, make one as a pattern, or even a number of them, they can be made of metal, aluminium or brass, or plastic or wood, leave the back flat is the easy way that's what I did when I had 200(twice)horse brasses cast for the souvenir shop at the local museum.
Ian S C
With small stuff that's OK but doing that with larger stuff creates dimensional errors due to shrinkage between solidus and ambient.
16/05/2019 11:29:05
Posted by Plasma on 16/05/2019 11:26:22:
Definitely not spun or pressed on the original.
Paul I am fancying your idea, I have one of Eccentric engineering Turnado turning systems for free hand sphere turning and I think I may be able to utilise it in this project
I will let you know how I get on and the results .
Many thanks
Mick
Looking at the unseen face the originals definitely look sand cast. Everyday stuff.
Thread: A train of engines
16/05/2019 08:35:20
[grouse mode] IIRC they did something similar a year or so back at one of the Llangollen Railway's galas. Great fun, great showmanship but of little practicle benefit.[/grouse mode] wink
16/05/2019 08:16:33
Posted by Michael Gilligan on 15/05/2019 20:49:43:
With those quantities ... Casting might actually be a realistic proposition
H&S legislation limits what can be done in the UK, but India does a lot of Brass.
As a patternmaker I find no shortage of brass foundries. I'm always geting small runs of broadly similar bits cast. Once  polished they'd be virtually indistinguishable from the originals. PM me if it helps.
Edited By Brian Oldford on 16/05/2019 08:18:02
Edited By Brian Oldford on 16/05/2019 08:18:58
15/05/2019 19:26:56
How many do you need to make?
Thread: Shackerstone - Battlefield Line - Outside storage
07/05/2019 11:58:34
Without knowing the full facts I think it wrong to be overly critical.
From personal experience I know well meaning companies have donated life expired machines to heritage railways.
Thread: Turning Cast Iron question - Health & Cleaning Up
06/05/2019 10:36:23
If you have a lathe without a screw-on chuck try using an inverted tool and run the machine backwards. Or if it has a screw-on chuck use the tool in a rear tool post. The chips tend to be directed downwards and far less carbon/iron dust gets into the air.
Thread: Dialect expressions
28/04/2019 21:16:28
Posted by Michael Gilligan on 28/04/2019 19:15:28:
Posted by SillyOldDuffer on 27/04/2019 09:37:08:
... a silent 'p' as in psychiatrist and pneumatic.
... and swimming pool devil
Not silent from the top diving board. devildevil
Thread: stepper driver
15/04/2019 20:16:25
More recent info on these boards here. **LINK**
15/04/2019 18:17:49
Duncan
Is the 5v derived directly or from the higher voltage supply?
Thread: Removing a grub screw
15/04/2019 16:07:33
"Easyouts". . . . . .Invention of Satan.
15/04/2019 15:42:48
There's a well documented issue with these inexpensive stepper driver boards., The fact is the designers of those boards did not follow the recommendations set by Toshiba for the power-up and power-down sequence.
There are other minor design faults but this is the one that can lead to total TB6560 failure.
In simple terms the logic (5v) supply onto the IC should be established and stable before the stepper drive voltage is applied to it and should be maintained until the stepper drive voltage is removed . These boards derive the logic voltage from the higher voltage via a 7805 (or similar) making this impossible as supplied.
There are mods that can be done to overcome this problem but they involve cutting of PCB tracks and the construction of a delay module.
The solution to the issue may be to hand by using spare pins of the Arduino, a MOSFET and a few more lines of code.
In depth discussion here. https://www.cnczone.com/forums/stepper-motors-drives/139306-can-tb6560-driver-design-violate-chips-specs.html
Good luck
Edited By Brian Oldford on 15/04/2019 16:08:56
Thread: broken calipers
14/04/2019 11:30:06
You could use something removed from these perhaps? **LINK** devil
Edited By Brian Oldford on 14/04/2019 11:30:50
Thread: anealing piano wire
10/04/2019 19:28:35
Grind a groove and use a miniature circlip or similar.
Thread: Would you mesh with this?
10/04/2019 08:05:12
As a complete aside, please can someone tell me why most horologists seem to use the cycloidal tooth form yet mechanical engineers mainly use the involute form? There's bound to be a simple reason.
Thread: Todays DUMBO award
04/04/2019 19:18:23
Posted by Mike Poole on 04/04/2019 18:17:58:
Just turn the tool upside down smiley
That's the "putting on" direction. cheeky
03/04/2019 17:35:01
There might some pearls of wisdom on the degree of temper here.
Thread: Non-Drip Gloss Paint
29/03/2019 12:15:12
I'd bin it anyway. I can never get a good finish from non-drip paints.
