Here is a list of all the postings Vincent Shaw-Morton has made in our forums. Click on a thread name to jump to the thread.
Thread: Newport 0-6-0 Tank Loco in 7 ¼” by Don Young; a beginners perspective. |
22/05/2012 19:45:27 |
Silver soldering, on a hot summers day.
Well I had all my bushes prepared and ready. Read Don's articles on the boiler construction, and found myself ready to do my first bit of silver soldering. I have soldered before, when I did the Polly course at SMEE. I also practiced on some scrap. However this was a different league.
WIth some trepadation I set up ready to go. Two cyclone burners and a massive cylinder of gas. Lots of flux and off I went. I had one burner burning down the middle of the barrel and took my time allowing it to build up to temperature. It was a mistake. The advice I had about preheating the barrel with a second burner was good advice, but completely unnecessary at this stage of construction as I simply didn't yet have the mass of material that needed a huge amout of preheat. I ended up exhausting the flux, and nothing would flow. Too slow a build up of heat, and then too fierce local heat when it was too late.
After a re-pickle and clean up (6% Sulphuric) I tried again. This time I used just one burner. I didi preheat the whole job, and watched the flux turn nice fluffy white. (I was doing this job outside in the shade btw) I then saw the whole barrle start to darken and take on the 'oily, irridescent' look. I then focuussed the heat on one bush. Pretty quickly the darker colouring spread out and the flux turned to a 'dirty washing up water.' I broght in the solder and with a bit of persuassion it suddenly flashed round, with my rod of solder rapidly vanishing into the joint.
In one sitting I managed to solder the dome bush and joining ring. After another slow cool, pickle and clean up I tacked the remaining bushes.
I found a few voids on a couple of bushes so, tried again, this time using far too much solder, but got good penertration. Phewww!!! I feel like I've been barbecued. However I think I've been succesful so I just need to get my work checked. I'm glad to have finally had a go at a large soldering job, and whilst I can't say it was fun, I feel more confident in progressing the boiler.
Checking the dome bush is parallel
Dome bush; soldered.
Too much solder!
Joining ring and good penertration on the dome bush
20/05/2012 19:03:20 |
AN APOLOGY Well, there is taking a break, and there is blinking and finding over sixteen months has gone past. For reasons I won't go into model engineering was no so much put on hold, but very nearly killed stone dead.....well not quite. Not even to access the forum. Its too long and dull a story to go into, and anyway I am now back to building Newport. Having not logged onto my account for over sixteen months I see that several people e-mailed me over a year ago, and all I can do is apologise, and I will be in touch with everyone who mailed me about construction articles straight away. In any event I started working again this week back on the boiler, exactly where I left off, and have manged to put a fair amout of work in; in terms of bush making. I have been using phosphor bronze for all the smaller bushes, and gun metal for the larger dome bush on top of the boiler barrel. The attached pics are on progress so far. Including the boiler barrel bush, which has been soft soldered to the dome bush in preparation for drilling of the pair, and the subsequent taping of the boiler barrel bush. It took quite a bit of practice to get my eye in with the first two smaller bushes taking several hours and a handful of cock-ups. The following day I could create a bush in a little over twenty minutes. I had my hands full in creating the boiler barrel bush as with my first attemtp at boring I found that after a couple of minutes the boring bar refused to cut. I then found that the Glanze tip had snapped off and vanished i inside the work. DOH!. With a new tip I was soon sailing throught the boring, creating a real shower of chips.
Various bushes. All bushes have only been tapped three or four turns.
Dome bushes and dome tube Anyway I'm back building after over a years delay. Once again apologies to anyone who got in touch and I will be in touch with you straight away. BTW, with some sound advice from my good friend John Dean I have been silver soldering outside in bright light using some scrap material, and in actual fact I found it easier to silver solder in direct light than in a shaded room. No longer looking for the cherry red glow I waited for two stages. The first for the flux to 'Puff Up.' and then simply for it to turn into 'Dirty Water' At this point I brought in the solder, and zip I was creating nice thick fillets of solder with no problem at all. After an hours practice I feel quite confident in soldering in direct light, in fact I don't think I will ever bother solderingt in dim light again. That's all for now
Best Wishes
15/01/2011 07:27:45 |
Hi Everyone,
its been a bit of a slow time in the workshop over Christmas, (like most people I expect)
Anyway I have made a little progress and have uploaded some more pictures to my album.
The throat plate
The Smoke box tube plate
and here is a photograph showing some of the notch work in the edge of the smoke tube holes (as advised by Alec Farmer in his book).
For those that didn't know, the notches are cut into the hole sides so as to prevent the holes from contracting too much when heated, thus still leaving a sufficient gap for the silver solder to fill. The smoke box tubes should be drop straight through the holes without being pinched or trapped. According to Alex's book this is the correct fit before soldering.
Finally a photograph of the Fire box tube plate on the mill. Milling the smoke tube holes with a slot drill.
thats all for now, and a happy new year
Best wishes
Vincent
Edited By Vincent Shaw-Morton on 15/01/2011 07:34:11 |
13/01/2011 11:23:16 |
Hi Louke,
If you mail me with your contact details I will send you a disc with all the articles and plans on it.
BTW, for those that are interested. I've only made a small amount of progress over Xmas, but will be putting some new posts and photographs on soon.
Best Wishes
Vincent
16/12/2010 22:01:04 |
Hi Terry, my mistake, it's not that I don't want to say Hi to you twice, too tired and on my sherry nightcap. ![]() Anyway here are some first postings to my album on the making the Newport boiler Thats all for now Best Wishes Vincent Edited By Vincent Shaw-Morton on 16/12/2010 22:07:42 Edited By Vincent Shaw-Morton on 16/12/2010 22:08:33 Edited By Vincent Shaw-Morton on 16/12/2010 22:09:10 |
16/12/2010 21:39:26 |
Hi Terry, I should have know the 'lathes in schools ' information would be incorrect. That's what I get for listening to my sixteen year old daughter! ![]() Hi Kwil, I started with the boiler as I'm following Don Young's articles, and he did the same. Hopefully all the drawing measurements are accurate and everything will fit Best Wishes Vincent Edited By Vincent Shaw-Morton on 16/12/2010 22:01:51 |
Thread: A beginners locomotive |
16/12/2010 10:02:07 |
To see how I am making progress on the Newport follow this link
Best Wishes
Vincent
16/12/2010 09:56:51 |
Hi everyone, After my last post requesting help on projecting a circle onto a cylinder I’ve decided to document the building of my first locomotive; which is Don Young’s Newport in 7 ¼” gauge. Perhaps an overly ambitious first project I can hear you say, well this is the locomotive I have chosen, and to outline my reasons read on. (For those who are interested). I am approaching fifty and have always felt that I would like to build a model steam locomotive when I retired. Well this date came forward a little when I got made redundant about a year ago, and came into a little money, which coincided with a visit to Chichester & District Model Engineering Society. I just turned up at the place to see if it still existed after visiting it as a child, and on arrival I found that the club was indeed still there along with a well equipped workshop. This fired my interest further and after a few weeks of visiting I met a member who had just completed the Polly Course at SMEE. Now my professional background is one involving the arts and computing, and I am currently a web designer, with very little engineering knowledge other than an enthusiasm for Sky TV documentaries, in particular ’Industrial Revelations’ with Mark Williams, so I needed some kind of basic training within model engineering, so I booked myself onto the SMEE Polly Course. Over the course of this year I have gone from no engineering experience (other than basic lathe work at school....... back in the days when Health and Safety hadn’t deemed that lathes were too dangerous to be in schools,) to having a basic grounding in model engineering; and a completed and running Polly Engine, which I was rather pleased with. (I cannot recommend the Polly course highly enough but that is a different story.) This then lead me to try and decide which locomotive to first build. Now for every locomotive that I had suggested to me someone would shake their head disapprovingly from Titch to Simplex, everybody had a comment of some-kind. However the best piece of advice I had was from a Chichester club member who said ‘It doesn’t matter which locomotive you build in terms of complexity. What really matters is you have to really want to make it as you are going to be working on it for a long time.’ Well I have always had a love for Victorian locomotives, and this is purely from an aesthetic point of view. To me they are objects of great beauty, and this felt to be as good a starting point as any to make my choice. Around this time I met another member, who has become a close friend, John D who built a Beattie Well tank in 7 ¼” and who won a gold with it at Bristol in 2007. His view was that a Boxhill Terrier might be a good place to start, which was also the locomotive I had begun to warm to. Well around the same time I had also started to look at Don Young’s Newport. It turned out that my friend John D had the entire set of construction articles which I gratefully borrowed and copied. On reading the articles I discovered that Don’s intention was that the Newport should not be beyond the scope of a reasonably competent beginner. Also despites being a 7 ¼” gauge loco, it is still comparatively small. The only down side as John D pointed out was one of weight and expense. If anything he felt that the larger scale was easier to work in due to component size. So after several months of thinking, along with visiting the IOW Steam Railway and the NRM (I fell in love with the Wainwright D at this point, but this is too ambitious,) I decided to build Newport. Ultimately I want to build Newport as Freshwater and paint it in the green livery of the FYN railway company. So my decision was based on the following. I like the design. There is a comprehensive set of construction articles. I have a great friend who will give me a hand and advice if I get stuck. So far my progress has been to make a start on the boiler and it is my intention to use this thread as a diary to document my progress, including any mistakes. My next post will includes some photographs on forming the boiler plates and the method I have used to cut holes in the smoke box tube plate. I hope this thread will be of interest, and please feel free to comment. BTW Hi Bill, I know you will be reading this; so Hello there. Best Wishes Vincent |
Thread: Pprojecting a circle onto a boiler barrel |
09/12/2010 09:44:51 |
Thanks for your help everyone, there are some great solutions here that I can use
Best
Vincent
07/12/2010 21:03:41 |
Hi everyone,
I've started on my first loco and have just finished flanging all the boiler plates, and I'm quite pleased with the results. Anyway on looking at the dome bush I can't for the life of me figure out how to project the cylinder diameter of the bush, ( a circle of course) down onto the boiler barrel. Simply scribing a circle on the barrel with a compass will of course distort the circle. How do people approach this (what appears to be simple) but for me baffling problem?
thanks
Vincent
Edited By Vincent Shaw-Morton on 07/12/2010 21:05:27 Edited By Vincent Shaw-Morton on 07/12/2010 21:05:53 Edited By Vincent Shaw-Morton on 07/12/2010 21:06:26 |
09/08/2010 18:00:28 |
Hi Everyone,
I can't belive it was April when I made my the first post, and thanks for all your replies.
Well I made a decision around two months ago, and since then have been just been mulling over my choice, along with chatting to various people in the know ever since.
I have decided upon Don Young's 7 1/4" Newport.
Now this is quite a jump up the scale, not least in terms of cost, let alone weight.
However I am very fortunate to have John Dean as a good friend who won a gold a couple of years ago for his Beatie Well Tank in 7 1/4". Also he has a copy of the original construction series published by Don Young in the nineties, which I have scanned in and now have a copy of my own.
On reading the articles I found that it is actually intended as a relatively simple model, not stricly aimed at the beginner, but should none the less should be a relatively straightforward build, despite having inside cylinders. The builder is actually also pretty simple too, having a straight barrel, and is 'unwasted'
So in any event I have decided to go with the Newport, after having succsesfully completed my Polly course with SMEE (which I can thoroughly recommend)
Best Wishes
Vincent |
17/05/2010 22:07:17 |
Hi Everyone,
I was all settled on the Y4, then i went to the NRM and it was 'love at first sight'
Wainwright D Class 4-4-0.
Probably rather too ambitous for a first model, none the less has anyone out there ever built one as a scale model, not that I'm thiking of it at this stage........just curious.
Vincent |
Thread: Trouble turning brass by a very inexperienced engineer |
14/05/2010 06:38:51 |
PROBLEM RESOLVED.
Hi all and many thanks for coming back to me, problem resolved.
The solution was definitely covered in your replys.
It was a combination of a relatively blunt tool, use of neat cut oil and too fast a feed speed.
I ground a new tool and made sure it had no top rake on it. The neatcut was aggrivating the problem, causing the tool to sip on the work, pushing the metal ahead of it. Once the wave had built up in height it would dig in and cut, this would reduce the wave height, the tool would once again then slip pushing the metal before it until the wave was so big the tool would once again dig in, slip, push, cut, slip, push, cut etc etc
A really sharp tool with no top rake, no cutting oil and a slow but steady feed speed and I am getting a mirror finish. BTW my spindle speed was 1340, as fast as my lathe will go.
Many thanks
Vincent |
12/05/2010 19:34:43 |
Hi Everyone,
well my new lathe is now in my workshop (new to me that is) and I am trying some initial turning of the brass bushes for a flywheel axel on a polly model.
I am encountering a problem, yet I have used the lathe before without any trouble.
Anyway the problem is that on turning the brass rod I find I am getting a strange very noticeable ( to the eye and feel) rippling effect. The ripple peaks at around 1/8 intervals, but the actual finish is ok. I am using plenty of neatcut cutting oil and a hss/silver steel ( I can't remember which material, but it's a standard cutting tool that can be ground) The actual turning speed I haven't yet established, but should be able to do so soon, but it is as fast as the lathe will go (sorry about the vagueness on the speed) I am feeding by hand at a nice slow speed and have tried taking cuts of between 5-20'. The rod sticks out from the chuck about 1/2".
Any clues as to my problem?
thanks
Vincent
29/04/2010 18:44:39 |
Doug Hewsons y4 looks ideal!
It is a nice looking engine, well proportioned and simple, and of course the right gauge.
This loco has gone to the top of my list. Does anyone have any finished pics of the y4. The only one I have found so far is on Doug Hewson's own site
28/04/2010 21:30:57 |
Hi Everyone,
thanks for coming back to me on this one.
I am settled on one thing so far, and that is the gauge. I don't really want to do a 3 1/2" gauge for the reasons already mentioned. (more fiddly to build, due to smaller parts, and not so powerful as a working engine. Looking at the Reeves site they have a couple of models recommended for the beginner at 5" gauge:-
Jack an 0-6-0 tank,
Scamp 0-4-0, or Dougal 0-4-0.
Did anyone have any comments on the complexity/difficulty of crank axels and inside cylinders on more advanced engines?
Vincent |
26/04/2010 19:42:03 |
Hi Everyone, I'm a novice with model engineering, although I am steadily gaining experience.
Currently I am on the Polly course with SMEE, (which I can thoroughly recommend) and am also currently putting a workshop together.
Anyway I joined my local club(s) Chichester and Worthing only around six months ago, and I am spending the rest of this year completing the Polly course and continuing to put my workshop together.
My background is not engineering btw.
Anyway my question is this. What would be a good first locomotive to build?
The thing that has been impressed upon me more than anything else is to pick a project that will keep my interest, but this of course leads on to levels of compelxity.
Practically speaking I was thinking of a Simplex. Now I know it might not be considered a beginnners model, but it struck me that it is a well documented model that has been built many times over, and that I am likely to find other builders out there who I can chat to if I get stuck.
But; from the 'I like the look of this loco' point of view, I have always loved the look of Victorian locomotives.
However all the models I haver considered so far have inside, rather than outside cylinders, which of course involves crank axles.
Now to cut a long story short (too late!)
Would one of these inside cylinder 'early' locomotives be a foolish first model to attempt, and what level of complexity does an inside cylinder add?
many thanks for reading this ramble
Vincent
