Here is a list of all the postings Roland Boyle has made in our forums. Click on a thread name to jump to the thread.
Thread: Super X3 Mill spindle |
02/12/2009 20:10:14 |
Thank you John for your suggestions. It will be a week before I get home to do some more testing. I will come back with the results. |
01/12/2009 20:14:07 |
I am not near the mill at the moment but as far as I can remember the test bar is about six inches long supplied by Arc Euro Trade. I measured at the top and bottom of the bar with the same result. I did remove the spindle and it appeared to be tight but as you mention it Jason I can move the test bar about 10 thou each way at the bottom of the bar.
Unfortunately I did not know that a test certificate should come with the machine. Good point about measuring the inside of the taper. Thank you all for your help so far. |
30/11/2009 20:12:38 |
I purchased a Super X3 mill last April and I am now in the process of setting it up. I checked the spindle using a test bar in the morse taper and I find that with the mill running at low speed it appears to be running 1thou out. I am only starting to get around to Model Engineering and I am wondering if this result is acceptable for this type of mill. Any help would be appreciated. |
