Here is a list of all the postings Tony Mills 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Starting the Q1 |
21/11/2009 10:40:36 |
hi all
Corrections to inner radius
The correction I am refering to relates to corrections under heading, 'Crank axle assembly (6 lines down)', that appeared in Model Engineer Vol. 203 No. 4357.
I've located the centre of the radius with new measurments, but the new position puts the radius about 2 mm away from the large stetcher hole: Model Engineer drawing of frames in issue Vol. 202 No. 4353.
On the subject of castings, I had to give up building a loco due to comany not being able to supply or tell me delivery date for castings, it would be nice if companies adopted a more professional approach to business: it seems UK suppliers are indifferent to customer care. |
Thread: Charlie Q1 |
20/11/2009 14:04:36 |
I've located the centre of the radius with new measurments, but the new position puts the radius about 2 mm away from the large stetcher hole: Model Engineer drawing of frames in issue Vol. 202 No. 4353. |
