Here is a list of all the postings bernard towers has made in our forums. Click on a thread name to jump to the thread.
Thread: Replacement lathes. Recommendations? |
11/05/2023 13:14:58 |
Can't agree more Tristan but we not that persuasion seem to be going the way of the dinosaur Edited By bernard towers on 11/05/2023 13:15:49 |
Thread: Meridienne Exhibitions Show Dates |
11/05/2023 12:48:30 |
Yep Forncett !st OCT, Midlands !2th to !5th.OCT and LOWMEX 28th and 29th Oct, just like buses. Edited By bernard towers on 11/05/2023 12:48:55 |
Thread: Anybody like weird plants? |
10/05/2023 19:11:15 |
Speedy builder 5 your morph is very similar to dragon arum which seem to grow like weeds in my garden and when flowering they stink to high heaven . |
Thread: Motorcycle General Discussion |
10/05/2023 14:35:44 |
Servicing the Chief today and wouldn't you know it the thunder is rumbling all around, well maybe tomorrow! |
Thread: Book Of The Week - Watchmaking. |
10/05/2023 14:23:19 |
George Daniels "Watchmaking" one of my best ever reads! |
10/05/2023 14:18:20 |
Not quite so exotic but did manage this from seed, its took five years and I get loads of tubers but so far only one flower |
Thread: Whittling down round bar stock with emery paper. |
08/05/2023 23:08:40 |
Any chance of using a skiving tool as they will take off tenths, which you can do quite successfully if you compound is set to 5.5deg or so which will give you a ten to one ratio of bed travel to infeed. |
Thread: What did you do today? 2023 |
05/05/2023 23:04:17 |
Nice job for home anodising! |
Thread: Myford cross slide leadscrew info needed |
05/05/2023 21:27:11 |
Which Myford and which crosslide? |
Thread: Back plate dimensions and tolerance |
05/05/2023 21:19:13 |
If you set your compound slide to approx 5.75 degs it will give you a tenth cut for every div. Edited By bernard towers on 05/05/2023 21:19:59 |
Thread: Bright steel |
03/05/2023 18:36:16 |
Try the spark test on your bench grinder |
03/05/2023 12:44:42 |
Used to be in D&T, never seen a school lathe or mill that’s worn out yet! |
Thread: Grit value for honing carbide tools |
01/05/2023 20:32:55 |
By the looks of the label could be 100 grit |
Thread: Rotary tool accessory set at Lidl |
30/04/2023 15:25:31 |
Beat me to it John, |
Thread: Myford Lathes |
29/04/2023 20:29:38 |
You can get an awful lot of ER equipment for that sort of money, and it will be new. |
Thread: hot black oxidation |
29/04/2023 18:54:11 |
29/04/2023 18:52:03 |
I think as most people are saying that 33/34 tooth gears should cover most of what you should need |
29/04/2023 17:25:32 |
Im afraid that using a microscope for looking at tool tips will have you chasing your tail.! |
Thread: Vertex VTA13-3 tapping head |
29/04/2023 17:22:38 |
The part that say open?close is adjustable for size of square on tap ,front chuck holds tap central.The way I use mine is to fit tap in outer chuck jaws as a sliding fit then slide tap to the rear and adjust rear jaws to clamp square on tap, tighten front jaws and you are good to go. |
Thread: ccgt060204 tips |
29/04/2023 17:16:37 |
emgee its in the title, or not Edited By bernard towers on 29/04/2023 17:17:25 |
