Member postings for PIERRE COURBOULEIX
Here is a list of all the postings PIERRE COURBOULEIX has made in our forums. Click on a thread name to jump to the thread.
Thread: TOOLS TO MAKE FORMERS FOR A SMALL PIPE BENDING MACHINE
05/07/2022 14:00:26
Hi All,
I have to make formers for a pipe bending machine for copper tubes 3 mm to 6 mm but I do not know the cutting angles, rake etc to be grounde by hand. The kit is from Hemingway.
Who can help ?
Thanks and regards.
Pierre
Thread: UNIMAT SL 1000
22/12/2020 16:11:20
Hello,
In the last issue of MEW ( N° 299 December 2020) Terry Gorin describes some interesting die holder for the small UNIMAT SL 1000.
Few years ago few articles were published about improvements for this lathe but I cannot find them due to destuction of part of my collection of MEW .
Does somebody can remenber the issues n° in which they were published ?
As I have now time to return to my favourite hobby this seems a nice project to modify my UNIMAT sleeping on the shelf ....
Thank your for your help and keep safe in this strange period !
Pierre Courbouleix
Thread: AERO ENGINES
07/07/2019 17:42:04
To Thor,Hopper, Jason and Ron,
I thank you all the fellows who respond to my querry ( I'm a bit lazy to answer to each of you, the temperature is nearly 39 ° C outside ………&hellip.
Now lets strart to make a crankshaft from the solid. I tthink it is a similar procedure ( work instruction) for a twin cylinder ?
I 'll post the results of the "disaster" I can produce ! (just a joke).
Cheers…
Pierre
06/07/2019 17:10:57
Hi,
I'd like to make a small internal combustion engine but my problem is how to machine the crankshaft ?
I have a small lathe from Warco and a small milling machine from the same supplier.
I already made steam engines and a small steam loco in 45 mm.
Thank you for your advices.
Pierre
Thread: LOCOMOTIVE BUILDING STAND
10/07/2015 18:33:04
Hi to All MEs,
I'm in need of a building stand for my Sweet Pea.
Few years (months) ago I read a very interesting article in Model Engineer about the subject.
Impossible to remember in which issue as I'm far away from my Library.
Is someone can help?
Thanks in advance.
Pierre
Thread: Brass and Paint
16/10/2009 13:26:34
A simple question (?). May be of some interest to all of us!
How to pepare a brass part to be painted.
What kind of surface preparation before coating,
What kind of primer to use ? ? ?
Thank you for your kind reply
Pierre Courbouleix - F75015 PARIS
