Here is a list of all the postings G.E.M. has made in our forums. Click on a thread name to jump to the thread.
Thread: 4 WHL BOGIE CENTRE PIN |
01/08/2012 15:40:04 |
No need to reply just realised the barrel pin is for a pony type bogie where their is a leverage back to the pivot pin, on a four wheeled bogie the loads are equal either side of the pin. Regards Gordon May |
Thread: Loco Design Co |
31/07/2012 18:14:13 |
Build it with piston valves as Nigel Gresley did if you really want it to perform. Regards Gordon may |
Thread: Wheel crank pin |
31/07/2012 09:18:19 |
Basically a flat washer of dia 1/8" larger than the crank pin dia, c.s.k. to take a 2ba c.s.k. screw. The crank pin of course tapped to suit, Locktite in. Hope this helps. Regards Gordon May p.s. washer thickness 0.070" |
29/07/2012 16:24:27 |
Designed the above for 5" gauge but have just seen a drawing where the pin is radiused on the diameter where it fits into the slide block, i do not see how this works as the slide block is up against one of the main frame stretchers or have I just got a blind spot ? Hope someone can help. Regards Gordon May |
Thread: VACUUM GROOVES |
11/09/2009 17:58:15 |
Thanks for the info, Ian all is now clear
Regards Gordon. |
11/09/2009 11:06:05 |
HAS ANYBODY ANY INFORMATION ON VACUUM GROOVES IN SMALL VALVE PISTONS. RATHER THAN FIT O RINGS OR PACKING YARN. ie HOW THEY WORK AND WHAT SPEC, IS REQD.
REGARDS GORDON MAY |
Thread: Separating oil from steam and condensate |
28/07/2009 20:31:57 |
I am currently designing a 5" V2 type loco where I hope to return the exhaust steam back into the tender via a heat exchanger, but before I can accomplish this I need to extract the hot lubricating oil from the exhaust steam. Can anyone suggest a fast way of accomplishing this. |
