Here is a list of all the postings Raymond Ascroft has made in our forums. Click on a thread name to jump to the thread.
Thread: Y axis problem |
15/02/2019 18:02:48 |
Barrie just tried the 100mm square as soon as it started moving in Y m/c was making a horrendous noise and eventually stopped on the 4th side heading Y+ about 3/4 way up from comments this noise it is making is it losing steps? Martin didn't get a chance to try your prog yet computer is Acer Aspire with Windows XP bought 2nd hand for the job no wifi or internet the only thing loaded is cad/cam & Mach3. Any ideas on what to do next appreciated |
14/02/2019 20:35:53 |
Thanks everyone I will try in morning 10mm/min was to try & see what is happening but 200mm/min too much for this m/c there was no load whilst cutting as DOC was 0.2mm to see what shape was being produced not sure about losing steps as my job was programming & machining 1st article any fault I was back programming & maintenance took over m/c until fixed
14/02/2019 18:26:48 |
Jason set Z inhibit to 10mm and also swapped I&J for R to define circle centre with no difference when run ballscrew stopped turning. Looking at Seig parts diagram confident I could replace stepper motor but if it didn't work as plug & play I'm lost electronics might as well be written in Chinese. Notice that helpline finished now too |
14/02/2019 14:56:21 |
Just tried again & Y axis ballscrew just turned a few degrees & motor sounded like it was struggling while cutting rad it stopped as it started up the angle face although the readout showed movement of both axis the cutter returned along path of 1st cut, stopped it after about 10mm homed m/c & Y axis moved normally manually |
14/02/2019 10:08:56 |
Good morning all |
13/02/2019 20:45:39 |
Jason DOC 0.2mm to check shape then 2.0mm, L61 Al, Brand new centre cut Carbide Garryson 4.0mm endmill, dry cut Andrew & Barrie
13/02/2019 19:24:25 |
Could someone point me in right direction please. Milling an internal triangle shape with 9mm corner rads with the Seig KX3 the cutter did not go round rad but returned along the path it came, when trying to cut rad the usual up & down sound of the motors was different mainly just one level sound, stopped m/c & returned axis to zero & Y axis was out by about 3mm the axis were all running OK manually but Y axis sounded a bit rough. the Mach 3 simulation showed correct path. Is there a minimum rad size these m/c's can handle it was 4mm dia cutter. |
Thread: Washers |
20/12/2009 20:44:05 |
Hi Guys
To prevent damage when assembling parts made of anodised aluminium etc. with hex bolts where the corners of the hex digs in to part and damages the finish an alternative to washers is to turn a 15 degs chamfer to about .01" below the a/f size on the mating face of the bolt head or instead to turn a washer face again .01" below a/f size x .015" deep. An areospace solution to prevent galling with combination of stainless nuts & bolts is to silver plate the male thread.
Merry Christmas
Ray |
Thread: Plastic abrasive sheet |
17/12/2009 20:45:19 |
Hi Martin
Have been in touch with local tool supplier he is going to source a trial sheet 468l silicon carbide sheet, the psa backing should make it easier to use on an old surface plate will let you know how it goes .many thanks
regards
Ray |
04/12/2009 17:38:43 |
Hi Martin
Thanks for that, I have the dark brown Crocus Paper on a cloth roll similar to emery cloth but the plastic sheet gives a better polished finish and the surface texture is different to Crocus Paper unfortunately I have only a small square of the plastic left
Ray |
03/12/2009 20:31:08 |
Could someone identify an abrasive sheet I obtained about twenty years ago please. It is on a thin plastic film similar to acrylic is a pale blue colour and the abrasive is more of a polish grade than an abrasive a lot finer than 1200 wet & dry. I think it was made before diamond dust became widely used. |
