Here is a list of all the postings Ivan Prince has made in our forums. Click on a thread name to jump to the thread.
Thread: Motor issues |
22/11/2015 17:56:15 |
John Thats a single phase motor you have so you should be able to reverse it you just need the connection diagram for the drum switch Ivan |
22/11/2015 08:41:59 |
John If you have 3 wires and your instructions are telling you you need to swap over two connections to change rotation , then you will have a 3 phase motor fitted to your machine Have you 3 phase in your workshop. Regards Ivan |
Thread: Boiler life |
14/03/2010 15:45:05 |
I am looking at buying a second hand loco and have a question about boilers
I know that the boiler will require a test certificate but what is a reasonable life expectancy of a copper boiler
Ivan |
Thread: What type of oil to use on a Milling machine |
13/01/2010 16:54:10 |
Hi Alvin
I have used oil and i have still had the problem.
The only way to stop it rusting is to keep it in a heated workshop.
Failing that keep your eye on it every day and make sure it is well oiled.
My warco milling machine bed rusts a lot quicker that my myford lathe bed
Maybe the quality of the cast iron has a lot to do with it.
Ivan |
Thread: Model Engineer 4369 |
11/01/2010 17:46:17 |
Hi all
This is my first issue of my 2 year subscription.
Very pleased to get it Early , and i dont have to go looking for it at WHS
I hope it always comes this early
Very Happy Ivan |
Thread: Model Engineer 4366 |
06/12/2009 11:34:04 |
Tried all 3 smiths in Hull and could not find a copy.
I am going to subscribe , not bothered if it comes a few days late as long as i get a copy
Ivan |
