Member postings for Ramon Wilson 1
Here is a list of all the postings Ramon Wilson 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: ED Racer 'times two'
28/04/2010 22:18:22
Hi Terry
'and there I was thinking that rap on the fingers had put you off
You might be interested in how this goes!
Had better success with the second piston today. I confess to 'taking a shortcut' (I know I know)  last night and lapped the piston down with a very fine stone. It transpires the pistons had distorted very slightly when machining the internals and lapping that first piston to the liner revealed it's ovality. Took the time to bore a simple piston lap today and the second is a big improvement. The first is possibly usable - it is a very tiny amount - but if it proves not to have reasonable compression it may be salvageble by 'growing it' with heat and re lapping - failing that its another piston. This time though I shall not finish turn the OD until after the insides!
All the parts are ready for anodising and I have all the neccesary except some green dye. Having spent some time looking I have not found anything so far that 'fits the minds eye'. In that case it might be blue!
Regards - Ramon
PS All pics are up to date on here
Edited By David Clark 1 on 27/05/2010 16:04:36
