Member postings for Clive Joseph 1
Here is a list of all the postings Clive Joseph 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Which Sievert Torch ?
20/04/2021 15:13:47
Thanks to all for advice
Sievert pro 86 kit ordered 2941 burner, variable regulator, 3941 burner and neck tube
3 different suppliers to achieve 'in stock' and best price
Thanks again Clive
16/04/2021 07:30:03
Hi,
Looking for advice please
Which Sievert torch do I buy ?
I am in the process of building a steam engine and will need to silver solder a boiler in the near future. The boiler dimensions are approx 3" dia x 6" long. I would also like to get a burner suitable for smaller jobs i.e. fabrication of a small crankshaft (3/16 dia shaft 1/8" mild steel webs)
Any guidance would be greatly appreciated
Thanks in advance Clive
Thread: Which Slideway Oil 68 or 32
31/12/2020 21:15:19
Looking for advice on which slideway oil for my newly acquired WM250 lathe & WM16 Mill - would like to use the same oil for both machines, slides and general lubrication. Should I get 68 or 32 - is it only the viscosity that's different ? or should I use something different altogether ? Thanks in advance
Thread: Lathe Tools Carbide Tip - which ones ?
22/11/2020 11:33:36
My thoughts are that 12mm provides increased rigidity, that's the only reason. Are there benefits in buying 8mm ?
22/11/2020 07:35:12
Thanks all for your help/advice really appreciated
What are the experiences of the Chinese tooling - seems very cheap ! not always a good sign but are they OK for the hobby engineer who may not demand heavy cuts or the speed of production that industry requires ?
Still require a good finish though smiley
Thanks again Clive
Thread: New to site :)
21/11/2020 17:47:22
Hi Everyone,
New to model engineering after many years building and flying model aircraft, first project will be a steam engine for a model boat.
Looking to build Miranda engine & boat
Cheers for now Clive
21/11/2020 17:41:31
Hi,
I am in the process of purchasing lathe tools to use on my Warco 250 - 12mm tooling
I will be turning Bar stock - Brass, Mild Steel, Stainless & Aluminium, I appreciate I may need a different tip for certain materials
I would like to standardize tips across a range of tools - there are so many !!
Any advice would be appreciated
Thanks in anticipation Clive
