Here is a list of all the postings Simon Rundsvoll has made in our forums. Click on a thread name to jump to the thread.
Thread: George Adams 2 1/2 questions |
05/08/2023 19:48:47 |
The underside of the tailstock looks alright. It is not in the same state as the bed. and yes, James is right, the 2nd tailstock I just placed on a piece of granite. It is not a part of the actual tailstock |
05/08/2023 10:14:18 |
Posted by Michael Gilligan on 05/08/2023 07:35:04:
Simon
You have already received a lot of sage advice here, so I thought I would just chip-in with an historical note about the maker of your chuck: **LINK** https://oldtoolheaven.com/related/goodell-pratt-history.htm Damaged and worn as the lathe bed may be: It appears that you have good headstock bearings and a fine chuck … With your obvious enthusiasm for it; one way or another that machine will surely end-up capable of doing good work. MichaelG. Thank you for the article. I sure hope it will. |
05/08/2023 10:09:38 |
Posted by Bazyle on 04/08/2023 11:12:19:
Wow - shiny. It looks like you have been polishing it on a buffing wheel. Didn't we have a thread on this lathe model a couple of months back when I mentioned I have never seen any spare parts on ebay for it. The spindle thread is unusually fine so not similar to any of the other small lathes. It is not a screwcutting lathe. Therefore the bed is only to hold bits together and you could use a bit of angle iron instead. It is completely pointless to regrind the bed. All the real work is done by the saddle/cross slide/topslide assembly. It is a good lathe for clockmaking, model railways, small engineering up to G1, not just an ornamental antique except for the fact that it is so shiny. Use an industrial sewing machine motor to power it; which also gives you variable speed. That second tailstock is interesting - can you provide a better photo of just that please.
Yeah i did this yesterday. And it seems to have worked quite well. Now to look into the jaws.. |
05/08/2023 10:03:58 |
Posted by SillyOldDuffer on 04/08/2023 10:43:15:
I recommend starting by using the lathe to cut metal rather than measuring. Measuring is difficult and understanding the results more so. Getting either wrong can lead to unnecessary remedial work and making the lathe worse. In contrast, cutting metal is relatively easy to do and it makes faults very obvious. Bent spindle, knackered bearings, head and tailstock misalignment, loose headstock, unacceptably worn bed, worn jaws, damaged chuck internals, cracked parts, broken keys, broken & maladjusted gibs, worn worms, backlash, broken shear pins, jambed collars, missing parts, blocked oil-ways, damaged nose thread etc. Running a lathe reveals problems that are hard to measure - like overheating bearings and horrible mechanical noises! Many of these are cheap easy fixes, others difficult and expensive, possibly show-stoppers. Although she looks lovely, that lathe could be BER. (Beyond economic repair.) I advise putting the lathe 'as is' through it's paces to identify as many faults as possible before deciding what to do about them. So don't start by laying a straight-edge on the bed and going immediately for an expensive regrind! Cutting metal highlights other issues, and the bed may not be worth fixing. A rust pit under the tailstock is unlikely to matter, whereas a deep hollow ground into the headstock end is trouble. But note it's possible to do good work on a rather badly worn lathe - how important the wear is depends on what the lathe is used for. Don't fixate on the bed or anything else: before spending money, cut metal and evaluate whatever it reveals. With luck cutting metal will allow everything that matters to be fixed in short order. But cutting may only the first step. Although a good way of identifying lots of problems and giving a rough idea how serious they are, measuring is the next step, and essential for fine adjustments. For example if a DTI or micrometer shows the happily working lathe cuts a taper, measurement is needed to identify and correct the cause - might be bed-twist, which is fixed by "levelling", or the headstock needs realigning. Both are delicate adjustments. I would only buy the lathe in it's present condition as an ornamental antique. It's obviously been beautifully cleaned up, but she's a very old lady, and condition as a working precision machine is unknown - could be anything between good or scrap. Unfortunately it's not difficult to tart lathes up, and anything of that age looking that gorgeous makes me suspicious. Appearance is secondary to me. Buying a second-hand lathe for work rather than decoration, I'd insist on seeing it run before buying it. That said, lathes are fairly robust, and quite a few ancient survivors are in remarkably good condition. It depends on the machine's history - many were thrashed by men working hard to earn a crust and were scrapped decades ago. Others were used for light repair or prototyping work. A few sat on a bench, or in a crate, for 50 years. Lathes owned by hobbyists mostly have a very easy life. Not unusual for good lathes to end up rusting slowly away in a damp cellar, in which case the damage varies from fatal to cosmetic. When an item becomes BER depends on how much time and effort the owner wants to spend. In my case, not much, because I own tools to use them. But restoring old equipment is a respectable hobby in itself. Men cheerfully spend years bringing historic gear back to life. Heritage repair may not be for me, but I admire those who do it, and their results. Regrinds - anyone able to name any firms doing this work at the moment? They seem to be disappearing. Dave
Yes, i hear you. Trying to run the lathe, and use it for cutting first was always the plan. I will not use this machine for tasks that require a massive amount of precision (at least for now). So the bed not being perfect will likely not cause me all that much of an issue. That being said, it is one of those things that i want to do down the road, if the machine turns out to be useful. I guess i am just one of those guys who care for both usability and looks. |
05/08/2023 09:58:06 |
Posted by Howard Lewis on 04/08/2023 10:38:33:
Backplates. These are most unlikely to be availabe "off the shelf". Recently, to enable a friend to mount a 4 jaw chuck on his small lathe, we had to make a backplate. The nearest that we could get as raw material was a 100mm plate with a 26.5 mm central bore. Having measured the bore, a plug was made to have a 0.00!" interference. This was fitted by the "Heat and Freeze" technique. The backplate was then put into the 3 jaw chuck on a larger lathe to be bored ready to be tapped 3/4 x 10 BSW to suit the spindle on the lathe.. When this had been done a dummy spindle was turned and screwcut, before being finished with a die. (This entailed making a Die Holder for the 2" diameter Die! ) The backplate was then screwed onto this dummy spindle, tfaced and to reduce the diameter to 80 mm and to produce the register. Fortunately, the backplate had been tapped M6 on the required PCD, so it was just a matter of opening up the holes to clearance, to enable chuck and backplate to be united. You are going to have do somethinbg similar for your lathe. finish machining the backplate, once it has been fitted to your lathe. Hopefully, the chuck will then hold work closer to true. Howard. Machining a new one is currently out of my capabilities, as i dont have another lathe, or the necessary knowledge to do this well. |
04/08/2023 10:23:00 |
04/08/2023 10:17:39 |
Yes, I have seen some of his videos. And I have been considering to reach out to him, as he is a fellow Norwegian if I am not mistaken. I tried just placing a ruler on it. Now this probably isn’t perfectly level by itself, but just using that, the bed got noteworthy gaps. I will upload a picture of the tail stock side so you can see what I mean by pit rust. As it is in my view quite extensive |
03/08/2023 20:44:19 |
The worst of it you cant see, as it is under the tail stock. But it has very large, and quite deep pit rust there. So the tailstock is basically just resting on the high spots. But no, i havent really measured it. I am pretty new to all of this, but i have invested an immense amount of time into the rest of this lathe, to restore it into what it is now |
03/08/2023 19:51:32 |
Thank you! And thank you for your feedback. I would generally like to have the more sturdy option of using a chuck with a backplate, so i will try to work something out in that direction. |
Thread: George Adams 2 1/2" Precision |
03/08/2023 19:35:56 |
Lovely. I want to have a go at scraping too. But need to invest in a good surface plate first. As of now, I have just watched videos on how to do it. Regarding your EBay seller experience… makes me wonder if it is the same seller I dealt with. Who failed to mention that mine would come with outerworldly wobble in the chuck. It was supposed to be functional, but I suppose that is relative |
03/08/2023 19:18:14 |
Hi everyone. I am sure i have many more questions, but these are what i could remember when i tried to write this post. i havent done anything with the bed itself yet, other than remove the surface rust that it had. But i plan to find someone who can re grind it for me. I also need to make a new “nut” for one of the lead screws in the cross slide, as the threads are badly worn. |
03/08/2023 06:22:42 |
Hi James |
