Here is a list of all the postings David P has made in our forums. Click on a thread name to jump to the thread.
Thread: Replying to enquiry from a classified ad |
25/05/2023 15:22:42 |
Hi Dave
Just seen your post and have resent email, I think it was my fault, I deleted the block of text….oops. Dave. |
Thread: Inverter help |
21/05/2023 15:44:05 |
So if I wire it as the motor plate picture by Pixel_Porpoise it will look something like my attempt at an electrical drawing, sorry. I have done a test and get a reading when the multimeter is put between A red and black N, also get a reading between B yellow and brown N and C blue and white N. |
21/05/2023 09:18:33 |
Posted by DC31k on 19/05/2023 19:20:19:
Posted by David P on 19/05/2023 16:17:33:
My simplified explanation is as follows, first change the motor to Delta, I have taken the 3 wires off terminal N and checked for a circuit (continuity) between A, B and C and the wires from N being Brown, Black and White, so I presume I connect the Brown, Black and White to the A, B and C terminals where there is continuity and that will set the motor in Delta mode 240 volt 3 phase. It is possible to misinterpret your description above, so you might have to be more clear in the way you describe the connections. In particular, you need to list clearly the relationship between the six wires. I _think_ you are saying: red (A) and brown are connected; yellow (B) and black are connected; blue (C) and white are connected. However, my (or anyone else's) thinking is a particularly bad way to proceed. Certainty and clarity is required. If this is the case, and you connect brown to terminal A (red), as you appear to be saying above, you are just connecting the two ends of the same coil together. No harm will come by doing so, but the motor will not work. You have the delta triangle on the data plate. Each side of the triangle is one of the three coils. Each vertex of the triangle can be labelled sequentially A, B, C. So the 'start' of the first coil goes to 'A'. The 'end' of the first coil goes to 'B'. The start of the second coil goes to 'B'. The end of the second coil goes to 'C'. The start of the third coil goes to 'C'. The end of the third coil goes to 'A'. One each of the incoming phases goes to A, B, C. so how do I test which of the free wires, Brown, Black and White go to the correct terminals A, B and C for delta? I do not have the original plate that covered the wires but looking online it seems most of the Brook Crompton 3 phase motor are wired the same as the picture shown by Pixel_Porpoise. |
19/05/2023 16:17:33 |
Ok, I am new to the forum and have spent the last few days looking at all the topics on inverters, I have picked up some valuable tips but still not sure if my planned approach is correct. I have a Fobco bench drill that is 3 phase 370 watt 400 volt @ Hz50 which I want to run as 1 phase 230 volt. My simplified explanation is as follows, first change the motor to Delta, I have taken the 3 wires off terminal N and checked for a circuit (continuity) between A, B and C and the wires from N being Brown, Black and White, so I presume I connect the Brown, Black and White to the A, B and C terminals where there is continuity and that will set the motor in Delta mode 240 volt 3 phase. Then purchase this **LINK** can I then just run a cable to the inverter input from a 3 pin domestic plug and the 3 phase out to the motor terminals A, B and C. another thing I am not sure of and that is, do I need to set the inverter to Hz 50 to keep the speed the same and will the switch on the side of the drill still work for forward and reverse. Thanks for any guidance/help, David |
